Bomar Berth Hatch
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue Aug 22, 2017 9:53 pm    Post subject: Bomar Berth Hatch Reply with quote
Inspected my hatch today and found the seal (gasket?) That seats the hatch to the hull is disintegrating and is very likely source of my rainwater intrusion (though the cushions are never wet). Would appreciate a walkthrough of removing hatch. Is this in fact a gasket? Available? Or just 4200? It seems substantial, like 1/2" thick or so.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Wed Aug 23, 2017 12:12 am    Post subject: Re: Bomar Berth Hatch Reply with quote
Get the model / serial # off the inside of the hatch, wander down to the Gear Shed, if they don't have one they can order a replacement. Wink
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Aug 23, 2017 12:19 am    Post subject: Reply with quote
Cool. Thanks. So just screw off hatch, scrape off old gasket, put new gasket and replace hatch? Any additional sealant?
PostPosted: Wed Aug 23, 2017 11:25 am    Post subject: Reply with quote
If I interrupt the original post, There is an issue where the hatch frame screws to the deck--not the gasket between the clear opening aluminum frame and the fixed frame. If this is the problem, see below.
There is no gasket between the hatch and deck. This is a sealant. The factory used some Bostec compound in the past--don't know what is used now.
I have removed the forward hatch on every one of my C Dorys, In each boat the cutout was too large. I undercut the wet/damaged core, as well as the screw holes. I filled these with thickened epoxy and then drilled new pilot holes for the screws. In two of the boats, Put a couple layers of glass around the periphery of the cut out, to assure a snugger fit. Then I put the hatch back in using 3M 4000, and tightened the screws back down.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Aug 23, 2017 11:53 am    Post subject: Reply with quote
Thanks Bob for clarifying gasket issue. Yes I was speaking of seal between hatch and deck.
tsturm
Photos: JMR-TOO
PostPosted: Wed Aug 23, 2017 7:33 pm    Post subject: Re: Bomar Berth Hatch Reply with quote
The 1/2 inch thick, must have confused me. I assumed Hatch lid to base seal.
Laughing Wink
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Aug 23, 2017 7:48 pm    Post subject: Reply with quote
No problem. It is a pretty thick bead was put there once upon a time.
Phil Barnes
City/Region: Colorado /San Juan Islands
C-Dory Year: 1991
Vessel Name: Swan-C
PostPosted: Thu Aug 24, 2017 11:30 am    Post subject: Bowmar Berth Hatch Reply with quote
Another question on the Bowmar Hatch is whether they still make a screen that fits over the opening.
Mine is an older model (1991) and the Bowmar Hatch is a 90006390, probably about 20 inches by 20 inches.
I don't find it in Bowmar online literature but haven't called them yet.
Has anyone else found a screen for this model?
Thanks!
PostPosted: Thu Aug 24, 2017 3:00 pm    Post subject: Reply with quote
You don't need to buy a screen. I had given some away a couple of years ago. I use "Army no see-um netting"--had to buy a full tent sized piece. Fiberglass window screen works very well, Put velcro on the around the hatch on the overhead--we used the sticky back white velcro, and it has been on about 5 years. We secure the velcro on the on the net with hot glue.
We use the same technique for the front opening window. These screens are much easier to stow than the fixed aluminum framed screen.
Here is a photo of our front window "no see-um net" Cut outs for arms and latch cams.
Close up of Velcro on the screen:
The factory screens work best with a frame designed for them.
tsturm
Photos: JMR-TOO
PostPosted: Thu Aug 24, 2017 10:56 pm    Post subject: Re: Bowmar Berth Hatch Reply with quote
Thanks!
Bomar will have them, but they are like $80.00 buckos Rolling Eyes
gstraub
City/Region: Callao
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
PostPosted: Wed Aug 30, 2017 7:53 pm    Post subject: Reply with quote
I've done the exact same velcro thing on our sailboat and it works excellent.
Gerhard
Phil Barnes
C-Dory Year: 1991
Vessel Name: Swan-C
PostPosted: Thu Aug 31, 2017 4:44 pm    Post subject: Bowmar Berth Hatch Reply with quote
Thanks for the ideas! $80 Buckos buys a lot of screen and velcro!
Deeplake
City/Region: Sandpoint
State or Province: ID
Photos: Deeplake
PostPosted: Sat Sep 05, 2020 4:09 pm    Post subject: Bomar Hatch Leaking Reply with quote
Homerjack, here is what I did recently on my 1989 22.
1. Removed hatch, 12 screws plus 6 more at hinges
2. Scraped all old sealant off cabin roof, didn’t seem like enough?
3. Cleared underside of hatch of old sealant
4. Injected “gitrot” into balsa surrounding the Full opening, some soft spots, didn’t want to pull it all out and re-do with new balsa as soft spots were only in one corner. Also brushed gitrot around complete opening to seal balsa.
5 When gitrot dried, sealed opening with 5200 to keep water out since cutout was larger than hatch.
6. Over drilled the 12 holes and filled with epoxy.
7. Re-drilled the holes down through bottom layer of glass to use bolts vs screws. Used hatch as guide.
8. Placed a layer of “butyl tape” on under side of hatch
9. Inserted screws through hatch/butyl and wrapped the protruding part with small amount of butyl.
10. Filled pre-drilled holes with 4200
11. Placed hatch in position and pushed bolts through
12. Tightened bolts/nuts to firm, waited 24 hours then re tightened, butyl squeezed out slightly, so I knew I had good seal. Used stainless nuts and bolts , with medium sized washer.
Now I need to tackle the leaking wood handrail screws, winter project. Never ending, the joys of an older boat!
Curt
Deeplake
Photos: Deeplake
PostPosted: Sat Sep 05, 2020 4:15 pm    Post subject: Bomar Hatch Leaking Reply with quote
2. Scraped all old sealant off cabin room, didn’t seem like enough?
5 when gitrot dried, sealed opening with 5200 to keep water out since cutout was larger than hatch.
7. Re-drilled the holes through bottom layer of glass to use bolts vs screws.
Curt
Page generation time: 0.0715s (PHP: 69% - SQL: 31%) - SQL queries: 31 - GZIP disabled - Debug on
