Fishcatcher907
Vessel Name: Legacy
Photos: Legacy
Posted: Mon Mar 16, 2020 6:44 pm Post subject: Cons to a freshwater wash down? |
My 22’ cruiser doesn’t have a wash down installed yet.
Normally I just use the good ol bucket trick, but I don’t love throwing all that saltwater in the boat on purpose. I primarily salmon and halibut fish along with shrimping there’s always a mess on deck.
I don’t use my freshwater tank for much. We do go overnight often, but we normally have lots of other water sources on board. Between frozen water jugs for the cooler and bottled drinking water I doubt we’ve ever used more then 5 gallons out of the tank.
So I guess my question is... Why wouldn’t I want to plumb my wash down pump into my freshwater tank? _________________ Cheers |
JMacLeod
C-Dory Year: 2018
Vessel Name: C-Shalom
Photos: JMacLeod
Posted: Mon Mar 16, 2020 9:37 pm Post subject: |
I've been planning to do the same thing.
Thinking about putting it on the other side of the box, opposite the raw water washdown.
Figured it'd be better for rinsing down the reels, and everything else before getting back to the dock.
You'll probably get it done before me, so I'm following along. |
CC Rider
Joined: 19 Nov 2013 Posts: 164 City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
Posted: Mon Mar 16, 2020 9:45 pm Post subject: |
When I bought my 23, she already had a washdown system plumbed from the freshwater tank so I didn't need to do an install. It certainly has been great to have it, so I would recommend it if you use the boat for fishing.
Con: Another boat project! (Although some boat projects can be fun, others not so much.)
Slight Con: More plumbing connections that might leak.
Slightly more Con: It's amazing how much water you use from the tank for just a short washdown of the deck and gunwales after a catch. (Or the odd window wash). But, I like things that can serve dual purposes on these boats. If we are cruising and don't have access to water to re-fill the tank, I don't use the washdown system at all, reserving the water for us. If I know I can get a re-fill easily, or just day-fishing then of course I let it rip.
Chris _________________ MMSI#: 316033635 |
Teufelshunde
Joined: 27 Aug 2019 Posts: 139 City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
Posted: Mon Mar 16, 2020 10:14 pm Post subject: |
I have a raw water wash down on my Angler and if I were to have a freshwater tank I would plumb a T into the hose with a valve to use both tanks to one hose sprayer. ( 2 pumps required ).
Rinse fish / wash blood ect.. off deck with the raw water while fishing and when done fishing for the day blast everything with the fresh.
I figure you would save weight having to carry / fill a bigger fresh water tank. _________________ What ever you are, be a good one 🇺🇸 |
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Tue Mar 17, 2020 12:45 am Post subject: |
My 22 came with a separate washdown pump that was connected to the fresh water tank. There was a valve that set the water to the house services or to the washdown. The washdown was also useful in emptying the tank for winter.
Removed all that when I took the water tank and hoses out. Haven't missed it. Found it was much more useful to have the cabinet space (under the aft dinette seat) for storage than the water tank. |
tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed Mar 18, 2020 9:07 am Post subject: Re: Cons to a freshwater wash down? |
Fishcatcher907 wrote: | My 22’ cruiser doesn’t have a wash down installed yet.
So I guess my question is... Why wouldn’t I want to plumb my wash down pump into my freshwater tank? |
No "cons" to a fresh water wash down. Unless you want to replace all your fishing gear every year The only problem with having both fresh & salt wash downs is a helpful youth passenger using the salt to clean off your favorite $500.00 reel Time for kings in Homer as we speak!! |
ChapaRRal Cock
Joined: 22 May 2019 Posts: 30 City/Region: Port Orchard
Vessel Name: Knotty Lady
Photos: Knotty Lady
Posted: Wed Mar 18, 2020 4:42 pm Post subject: freshwater washdown |
I had thought about this to be able to run the motors with fresh water at the end of the day. Didn't consider using to wash gear! Now I am definitely going to do it. I am just going to T into the supply for the toilet. It already has an on-demand pump. So. it should be simple! Thanks for making me reconsider an Idea that had been passed over. _________________ James Speidel
Proud New Owner of the Knotty Lady |
bschell
Photos: bschell 2003 22 Cuiser
Posted: Wed Mar 18, 2020 10:59 pm Post subject: |
Yep.... We did that about 10 years ago. Used it to take fresh water showers on the swim step at the end of the day over at San Clemente after a long day of fishing. When I got back to the ramp, if it was busy at the wash down I would just use the tank to wash down the boat and trailer and head home. Same thing at Lake Powell in fall. |
Posted: Thu Mar 19, 2020 2:38 am Post subject: |
I have had a raw water wash down on SleepyC since I bought the boat. Finally fixed that problem. When I took her up to Bellingham for the Bottom paint job, I had that stupid hole in the bottom of my boat cured Yup, pulled it out, plugged (patched) the hole in the bottom of the boat, and now I have one less worry on my mind when I'm half way across Juan de Fuca (12 miles in either direction to the closest land).
I do intend to not loose the pump though. It will stay, but it will get a hose that I can put overboard if I want to pump water either onto my boat our out of another boat. . . or what ever.
So, I am looking for a good recommendation for a non-collapsible hose, preferably light weight, and easily coil - able, somewhere in the 10 to 15 feet length. Any ideas are considered. Thanks
Oh, and the cons of a raw water pump -- the hole in the bottom of the boat.
The Pro's of a Fresh water pump. Nice idea but it will go through some water gallons -- quickly.
SleepyC
Fishcatcher907
Vessel Name: Legacy
Photos: Legacy
Posted: Thu Mar 19, 2020 2:44 am Post subject: |
That’s it! I’m going to do it! |
Fishcatcher907
Vessel Name: Legacy
Photos: Legacy
Posted: Thu Mar 19, 2020 2:46 am Post subject: Re: Cons to a freshwater wash down? |
tsturm wrote: | Fishcatcher907 wrote: | My 22’ cruiser doesn’t have a wash down installed yet.
It is time for winter kings! If the forecast improves I’ll go down this weekend. |
Posted: Fri Mar 20, 2020 8:06 pm Post subject: |
We have a fresh water washdown on Thataway. Have not used it--but is there if we want. _________________ Bob Austin
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
Posted: Fri Apr 07, 2023 11:25 am Post subject: |
I installed a fresh water wash down on our 22. Nice to have but it is amazing how fast it emptied the water tank. for the purpose of cleaning boat after fishing it didn't work out well for us since no access to refill water tank where we fish. I ended up taking it off and it is sitting on a shelf in my shop. _________________ Doug & Susan |
WCF
Posted: Fri Apr 07, 2023 11:47 am Post subject: |
I use a garden sprayer connected to a normal 3/4 hose fitting with a normal garden selectable-sprayer thing.
Very inexpensive, no electricity, very reliable, can be filled with warm water or left in the sun for showers, can be filled with whatever water is available and appropriate for the task. Can be taken anywhere on or off the boat without a long hose.
Can also be left at home when not needed.
For salt water, I keep another one in my truck with pre-dilluted salt-away. |
