Repainting Honda BF90 outboard
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Sat Feb 08, 2025 4:38 pm    Post subject: Repainting Honda BF90 outboard Reply with quote
My motor cover has weather damage and I want to repaint it. Can someone tell me where to find the right “Honda silver” paint in a rattle can? Or something close to it?
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
PostPosted: Sat Feb 08, 2025 6:17 pm    Post subject: Re: Repainting Honda BF90 outboard Reply with quote
I'd contact Boats.net and give them the details on your motor, they can probably help. It might be this:
https://www.boats.net/catalog-product/collection/honda/24E1BBE52B817BDA8E205EA16AF8D4993838211B?manufacturer=HONDA&titan_sku=08707-NH190M&ref=1fa885a56b989f8f81474e26a5235abd733ef7ed&attr_collections_=24E1BBE52B817BDA8E205EA16AF8D4993838211B
You might want to contact a body shop for painting if it is a large area. Just get them to repaint the whole thing. You'd have to redo the decals though.
PostPosted: Sat Feb 08, 2025 6:58 pm    Post subject: Reply with quote
I have used a rattle can. Sand cowl where it is faded (mine was just on the top), so I masked this off). Start with 320 on up to a 600, 1200 and 3000 wet and dry paper. Keep the paper wet--I did it all by hand.
Then a plastic primer and silver--there was a Rust-Oleum for plastic which was very close to my 2006-90 hp. Moeller and Honda OEM both make several different silvers by year. Then a clear coat and blend it in with light sanding at the edge where the tape was.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Sat Feb 08, 2025 7:19 pm    Post subject: Reply with quote
Thanks, pals! Some good tips here.
olekils
City/Region: Goleta
C-Dory Year: 1997
C-Dory Model: 24 Tomcat
Photos: olekils
PostPosted: Tue Feb 11, 2025 5:55 pm    Post subject: Reply with quote
I recently re-painted the lower cover on my 2013 silver Honda BF135's. I used Moeller Marine 025516 Engine Paint Color: Honda Oyster Silver Metallic and Moeller Marine 025519 Clear Coat Lacquer both in spray cans. It was pretty easy job, most of the old paint peeled right off with some compressed air, then a light sanding. The silver speckles in the paint match the OEM surprisingly well and the clear coat helps the color match a bit better. It's not a 100% match, probably a 95% match and if you do an entire part (rather than a spot repair) it looks totally fine. The paint is easy to work with and it's a pretty quick job.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Tue Feb 11, 2025 9:12 pm    Post subject: Reply with quote
Olekils: Thanks for the part numbers. Very helpful!
Page generation time: 0.0762s (PHP: 29% - SQL: 71%) - SQL queries: 23 - GZIP disabled - Debug on
