Esmi2
Joined: 26 Aug 2016 Posts: 96 City/Region: San Luis Obispo, CA
Photos: Esmi2
Posted: Sun May 11, 2025 10:35 pm Post subject: 120V-15a (household) plug behind plastic cap in transom |
On my new-to-me 2006 Cape Cruiser 23, I have a plastic cap in the transom just below the engine. Under the plastic cap is a 120V-15amp plug.
When I put power to the plug, nothing happens. When I put power to the plug AND turn on the inverter switch at the helm, I get power to a 120V outlet on the starboard side of the cockpit (and nowhere else that I have been able to determine).
Can anyone help me determine what the nature of, and benefit of, this circuit is? What purpose does it serve that would make my boating experience better?
It seems completely separate from the 120V-30a twist-lock circuit that powers the rest of the boat.
Thank you. _________________ 2006 Cape Cruiser 23 w Yamaha 115 -- "Scoot" |
Joined: 02 Nov 2003 Posts: 21508 City/Region: Pensacola
Posted: Mon May 12, 2025 11:45 am Post subject: |
This would have been installed by a previous owner--not factory. My best guess is that this is an inlet for a battery charger. I have had several small boats which had this setup. _________________ Bob Austin
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1278 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Mon May 12, 2025 3:51 pm Post subject: |
https://inverterservicecenter.com/products-by-brand/marinco/battery-charger-inlets
If its a plug like this its usually something found on bass boats for their onboard charger. It is hard wired directly to the charger only and must never be wired to any other live source. A live male end is very dangerous and illegal.
I requested one installed when I ordered my new boat. The marina refused to install it as they did see it meeting code and didn't want to be liable.
Rob _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
Esmi2
Photos: Esmi2
Posted: Mon May 12, 2025 4:35 pm Post subject: |
Thank you, gents.
I will need to go research it a little more closely. It makes perfect sense that it would power the battery charger (which resides in the transom locker nearby). But it doesn't. It runs past the charger and into can't-see-ville. By observation and process of elimination, I thought I had discovered what it did (without discovering WHY it did it). But now I am thinking I missed something. Stay tuned... |
Joined: 27 Oct 2012 Posts: 3593 City/Region: SW Michigan
Posted: Mon May 12, 2025 7:34 pm Post subject: |
Are you sure is it not an outlet from the inverter to get 120ac into the cockpit? |
