Jim from New York
Joined: 03 Feb 2019 Posts: 31 City/Region: Kings Park
State or Province: NY
C-Dory Year: 2018
Vessel Name: MarTika
Posted: Thu May 08, 2025 3:32 pm Post subject: Upgrad AGM Battery’s to lithium instead of the solar route |
Has anybody upgraded to lithium and found it adds that little bit more time on anchor and not needed to go the solar route? I usually stay two days on anchor without starting the motor and of course, my battery drains to a point where the refrigerator won’t operate. If lithium has worked for anybody in this situation please chime in would appreciate your input.. It’s a lighter set up and about the same cost of a good solar system. I think my 2018 23 would have the right charger needed but I would need to check. Thanks for any input Jim |
Posted: Thu May 08, 2025 6:09 pm Post subject: |
I did that in a slightly different way--in that I added the LiFePO4 (2-100 amp batteries) to carry the load of my freezer chest and the Refrigerator chest. This will carry this load for at least two days. That left the FLA house batteries with very little drain--and thus gave me up to 3 days with out battery charging. That is pushing the envelope a bit. But possible. The other house load (LED Anchor Light, and LED cabin lights) are minimal, and plenty of power for that--even enough to charge the Torqeedo if necessary. Recharged with a full days run with the engine. Off this same system, I had a Victron multiplus 2000 watt inverter to run the induction burner and the microwave. The victon inverter also has an 85 amp battery charger and mains power boost of 50 amps if necessary to sync with mains power for low voltage, low amperage at a dock.
I have never had solar on the boats I have owned. For my house essentials I built a 600 amp hour battery bank (12 volt) and 1200 watts of Solar panel to run deep freeze and refrigerator, as well as LED secondary house system (Has 3000 watt PSW inverter). _________________ Bob Austin
Jim from New York
C-Dory Year: 2018
Posted: Thu May 08, 2025 8:13 pm Post subject: Thanks for taking the time Bob good information |
I’ll be pricing out three batteries and checking the battery charger to see it handles lithium. I would like to keep the cabin top clear of solar and use for storing kayaks and such. If I do it I’ll let you know how it worked out
Jim |
Posted: Thu May 08, 2025 10:00 pm Post subject: |
With li batteries. Be sure and follow all of the instructions, and ABYC rules. Essential to have good fuses, make sure that the wires are short as possible, proper gauge, and well insulated. Have a good appropriate battery switch near the battery. Have good monitoring systems. |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Fri May 09, 2025 4:25 pm Post subject: |
I went with lithium on my trawler. Get the ones with Bluetooth so that you can really see what they are doing. I went with 4 280AH batteries (bigger boat, bigger battery bank). It was right before the recent tariff increase, so a bargain. An extra battery is an extra day at anchor.
Fusing is an issue because of the amount they can discharge in a short circuit. You probably should have a MRBF on each terminal for 100Ah batteries. Larger ones need more complex fusing because of the need for higher AIC (amperage interupt capacity).
LFP batteries can be placed on their sides, stacked, etc. in ways that lead can't be. Plus lighter and easier to place in remote places. The initial cost of an extra battery and cables will pay out if you own the boat for any length of time. If you use them only as house and charge with shore power, that simplifies a lot.
Don't think that you have to have a special LFP charger. An LFP charger might be more convenient, but isn't always necessary. Charge LFP and don't float. A "full" charge isn't always required and doesn't shorten battery life. With Bluetooth, you can hook up your old charger and simply unplug it when the batteries are at 95%. Don't need no stinkin' float. |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1051 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Fri May 09, 2025 4:48 pm Post subject: |
Hi Jim,
We had enough clear roof space that a $149 100W Renogy panel, Victron MPPT controller and Blue Seas circuit breaker gives us unlimited nights for under $250 grand total if there is some sun during the daytime. The typical marine fridge uses no 12v power (other than the LED door light) unless the Danfoss compressor is running. We keep the thermostat (marked 0-5) at 3 during the day, but after the last fridge door closes at night, we dial it back to 1 with full oversize ice cube trays for temp ballast, which cuts the compressor usage by about 50% without the ice melting. Defrost when the icebox gets ¼” of ice frost to also improve efficiency.
If the lithium option turns out to be more expensive than you want, you could consider a quiet inverter 110v generator like the Honda 2300 (which can power a 15K rooftop AC and all other appliances on board) or a used 2000iu. The $599 Firman 2000 appears to be a cheap knockoff, but surprisingly gets a very good Consumer Reports review. I’d get a Harbor Freight extension for the 90 day warranty, a couple of high quality CO alarms and never run it at night or when asleep. Downside is the space required.
https://www.harborfreight.com/2000-watt-super-quiet-inverter-generator-with-co-secure-technology-epa-71343.html
Best of luck in finding a solution that works great for you!
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2 |
Jim from New York
C-Dory Year: 2018
Posted: Sat May 10, 2025 8:56 am Post subject: |
Looks like im staying with original plan of using solar to add a bit more time on the hook. It will be a fun interesting project thinking of starting with 100 watt rigid mounted panel on cabin top making sure the controller will handle a second panel if need more. The lithium batteries would be nice but ends up much more costly, thought of changing refrigerator that won’t solve much ether. So that’s the plan. Thanks for all the information
A bit of information for those looking for a system I found is renogy has a Bluetooth module for checking the battery condition, for safety ect.
But I found a very interesting complaint . It only allows access to the app on your phone with Internet connection which provides the link( no Internet no app visualization)
I could be offshore with no internet access. It is mind-numbingly dumb that thee app that requires login
Just saying |
Posted: Sat May 10, 2025 11:06 am Post subject: |
The Victron smart shunt and other products do not need internet--blue tooth should not need internet connection.
Any of the small refrigerators use a compressor. The Fuji swing motor uses a little less power than the Danfoss compressors, with the rest use.
It was our observation at Lake Powell 200 watts of solar panels were necessary to keep up with the refrigerators. |
kennharriet
Joined: 22 Jan 2009 Posts: 539 City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
Posted: Sun May 11, 2025 11:19 pm Post subject: |
I’ll have more to report soon as we are on day one headed to Skagway from Idaho. This is the maiden road trip/voyage with 2 100ah Li batteries, 200w of portable panel and 20 amp DC-DC charger. We carry an Alaska series dingy so did not want rigid panels. The folding portable panels slide under the stainless dingy rack securely and are available for charging once the dingy is deployed. Our Engel freezer is the primary load along with a Wallas 1300 heater, Starlink mini and other electronics. |
DKennaC25
State or Province: IN
Vessel Name: .?
Posted: Sun Jun 29, 2025 8:48 am Post subject: |
kennharriet wrote: | I’ll have more to report soon as we are on day one headed to Skagway from Idaho. This is the maiden road trip/voyage with 2 100ah Li batteries, 200w of portable panel and 20 amp DC-DC charger. We carry an Alaska series dingy so did not want rigid panels. The folding portable panels slide under the stainless dingy rack securely and are available for charging once the dingy is deployed. Our Engel freezer is the primary load along with a Wallas 1300 heater, Starlink mini and other electronics. |
Any update? _________________ 2003 C25 |
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
Posted: Tue Jul 01, 2025 12:35 am Post subject: |
We are home from our trip and pleased with the upgrade. We had very limited sun and record rainfall the first part of the trip so had little opportunity for solar charging. We could still easily get two days at anchor with the largest load being the Engel cooler. It was cold so we were running the Wallas 1300 at least 12 hrs/day. On the few sunny days we had, the 200w of solar would maintain the Li batteries indefinitely at 100% at 13.6v. We boater homed for 5 days driving to Skagway and the same coming home. Only difference from time on the water was we put the Engel cooler in the truck. Without any charging the Li batteries stayed at 100% with the lowest voltage of 13.1v for the entire trip. We were hung up waiting for weather at the dock a couple times for 4 plus days where I plugged into power to charge with the ac-dc charger. When underway, the new 20 amp dc-dc charger was plenty adequate.
In my set up the agm start battery only receives charging from the alternator with engine start being its only load. I did carry a boost pac and had practiced hand starting the Honda 90, but neither were needed.
Overall it was a very worthwhile upgrade. Ken |
