Rub Rail rivet size
Cowman10
City/Region: Gainesville
Vessel Name: Piper Jane
Photos: Piper Jane
PostPosted: Wed Aug 06, 2025 8:06 am    Post subject: Rub Rail rivet size Reply with quote
If anyone has replaced the rivets that hold the rub rail to the hull, what is the diameter and length of the rivets?
Love the C-life
PostPosted: Thu Aug 07, 2025 11:41 pm    Post subject: Reply with quote
This may not answer your question specifically, but may help. This is what I posted in another thread when I had to repair the rub rail on my 25.
"Finished up reinstalling my rubrail today. I ended up using ss machine screws, washers and nylon lock nuts. 1/4 x 20 x 1 1/4"."
See: http://www.c-brats.com/viewtopic.php?t=28738&highlight=
olekils
City/Region: Goleta
C-Dory Year: 1997
C-Dory Model: 24 Tomcat
Photos: olekils
PostPosted: Fri Aug 15, 2025 2:38 pm    Post subject: Reply with quote
I replaced what was left of my rivets with stainless steel binding posts and a sealing washer. This avoids the globs of sealant inside the boat (detailed on page 3 of this thread:
http://www.c-brats.com/viewtopic.php?t=14439&highlight=
DKennaC25
City/Region: Lebanon
State or Province: IN
Vessel Name: .?
PostPosted: Sat Aug 16, 2025 8:57 pm    Post subject: Reply with quote
I removed the rivets ,most were broken off anyway.
The rivets use a steel mandrel. Bound to fail sooner or later.
Also riveted from the inside. Poor design in my opinion.
I Drilled the holes out with a 1/4 drill bit . Used 1/4 stainless steel bolts from the outside.
Lots of 4200 sealant with a medium stainless fender washer and stainless lock nut on the inside .
My wife held the bolt on the outside and I used a Dewalt driver with a socket on the inside to tighten them down.
Cut remaing bolt off with a cutting wheel .
Then with a vinyl glove on my hand, covered the inside nut and washer with 4200 to give them a smoother finsh.
2003 C25
Page generation time: 0.0449s (PHP: 39% - SQL: 61%) - SQL queries: 21 - GZIP disabled - Debug on
