Cleaning Trailer Rims
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Nov 02, 2006 2:45 am    Post subject: Cleaning Trailer Rims Reply with quote
I've got a nagging problem that's just getting worse. My trailer's galvanized rims have turned from their original bright finish to a dull black. I have 4-wheel SS disk brakes, it is surely disk brake dust that seems to be baked into the metal. I've tried 409 and Simple Green with little to no effect. Before I get out the bigger chemical guns like acetone, laquer thinner, etc, any ideas from others? Thanks in advance.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Thu Nov 02, 2006 6:20 am    Post subject: Reply with quote
Steve-
If you're hesitant to use any of the "hot" solvents, you might try to use straight oil based paint thinner/solvent first.
Soak 'em good with solvent rubbed in with a brush, then use a pressure washer with warm water if you have it.
Good Luck!
AstoriaDave
City/Region: Astoria
PostPosted: Thu Nov 02, 2006 7:26 am    Post subject: Reply with quote
Could be Soft Scrub will do it. You might also try oxalic acid paste ... sold in commercial forms to remove rust stains.
Dave Kruger
Astoria, OR
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Nov 02, 2006 9:27 am    Post subject: Reply with quote
I used to have a BMW M-3 whose disc brakes continually buried the fancy wheels with brake dust. There is a special cleaner you can get at the auto parts store to loosen bonded brake dust that works great. However, it may also be an acidic product which is likely to reduce your galvanized layer. You may have to just pull the wheels and paint them flat black!
Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Nov 02, 2006 11:43 am    Post subject: Reply with quote
John --- I really like your style, thinking the same thing. But first will have to get down to a clean surface so the paint will stick. I'll check some auto stores also, thanks.
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Thu Nov 02, 2006 12:26 pm    Post subject: Reply with quote
Having alot of farm equipment I know they sell paint that sticks to galvanizing. Most of it is gray. I think they sell other colors. You may have to check with a small town hardware store or a Farmer's Co-Op.
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Thu Nov 02, 2006 12:44 pm    Post subject: Reply with quote
I have the same problem and was thinking of using one of the anti-rust/galvanizing spray paints that you can get at any hardware store. I have used one to touch up (after cleaning) minor rust spots on fencing and on my trailer where the original coat got scratched. Seems to work fine.
Do you also get problems with the pads sticking to the disks if the trailer has been sitting a few days ?? I do and the darned thing has been rinsed 2 times and also washed with Salt Away.
Merv
Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Nov 02, 2006 7:06 pm    Post subject: Reply with quote
I haven't had any trouble with sticking disk pads. After pulling forward sharply just before backing into my driveway (uphill), I put on my brake disabler I fabbed. Even though I have a lockout solenoid hooked to my backup lights, if I ever have to stop and pull forward to reposition without the mechanical disabler, the brakes will lock on hard -- that's because the lockout solenoid is only a valve that prevents FURTHER hydraulic pressure from being applied. If the brakes are ON when the solenoid energizes, the brakes just stay at that same pressure, they won't release.
Page generation time: 0.0349s (PHP: 64% - SQL: 36%) - SQL queries: 25 - GZIP disabled - Debug on
