Air-Tight Hub Protectors
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Mon Dec 04, 2006 9:13 pm    Post subject: Air-Tight Hub Protectors Reply with quote
Anyone have thoughts on these ? http://www.airtighthubs.com/products-commercial.php
Pete
Chester
City/Region: home
Photos: Chester
PostPosted: Mon Dec 04, 2006 11:59 pm    Post subject: Reply with quote
Call me skeptical. Those will likely leak lube sooner than later. If you want a proven upgrade go with oil bath hubs.
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Tue Dec 05, 2006 9:45 am    Post subject: Reply with quote
I've thought about oil bath hubs to eliminate the mess that goes with the grease-gun type, but I have yet to research them. What is the recommended brand(s), how much are they, how difficult are they to install, and how well do they work?
Al
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Dec 05, 2006 1:59 pm    Post subject: Reply with quote
Like most others, I always used the bearing buddies. Then this last trailer (an EZ Loader) had the oil bath hubs and I was skeptical. But, amazingly, after a year of use, and a lot of miles, these things are still working perfectly. I am REALLY skeptical of the Air Hubs. I had bearing buddies that fell off with some regularity, and under little or no pressure. Don't know about these. But they could surprise us as well.
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Tue Dec 05, 2006 2:16 pm    Post subject: Reply with quote
I have been looking at those...and they look pretty nice...I have always used bearing buddies... the oil kits are $57 each and include the hub and all... for us that travel, probably a good deal. I think the first thing I want to do on my trailer is change out the drum brakes for a disk brake setup...(about $150 each)...first on the two braking wheels then later if needed I will do the 2 others...........
Adeline
Photos: Adeline
PostPosted: Tue Dec 05, 2006 4:26 pm    Post subject: Reply with quote
I lost two this summer which is why I'm searching for a new system. Just to add to the confusion I add this link.http://www.fishingworld.com/GoneFishin/BuyingBoat/Read.tmpl?SKU=11142209821115126
Page generation time: 0.0304s (PHP: 61% - SQL: 39%) - SQL queries: 23 - GZIP disabled - Debug on
