D15 Low profile handle and latch needed for starboard window
mccml
City/Region: Montoursville, PA
Vessel Name: Crystal Sea
Photos: Crystal C
PostPosted: Sat Jan 06, 2007 5:16 pm    Post subject: D15 Low profile handle and latch needed for starboard window Reply with quote
I plugged in my shore power for the first time today and was looking around and checking things out in the boat and noticed that the handle on the starboard side sliding window was completely missing. Does anyone know where I could get a replacement?
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Sat Jan 06, 2007 8:21 pm    Post subject: Reply with quote
I have to ask....where did it go?? They don't have toes so I am guessing it didn't tip toe away. Therefore I would start looking behind seat cusions or under seats or the sort.
On the otherhand, if you purchased the boat used, you might check with the previous owner or dealer you got the boat from.
The windows are made by:
DIAMOND SEA-GLAZE MANUFACTURING LTD.
26995 GLOUCESTER WAY,
LANGLEY, B.C.
CANADA V4W 3Y3
PHONE: (604) 607-0091 OR 1-800-770-0455
FAX: (604) 607-0092
e-mail: info@diamondseaglaze.com
Good Luck
Mike Taylor
330-936-1030
PostPosted: Sat Jan 06, 2007 8:42 pm    Post subject: Reply with quote
...<stuff clipped>
Good Luck
Actually those handles fall off quite easily and given that they don't float....
This came up at least once before on this thread. For one owner, the factory sent him a set.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Jan 06, 2007 8:54 pm    Post subject: Reply with quote
Mine walked away a couple of months ago. Good riddance .I'm glad it's gone! No more beating on the window and power jetting the sliding groove. I just slide the window back and forth. It's a pleasure. Smile
MartyP
mccml
Photos: Crystal C
PostPosted: Sat Jan 06, 2007 10:17 pm    Post subject: Reply with quote
Thanks for the info, the handle was off when I bought it. I'll call the factory, and see if they will send me a new one.
PostPosted: Sun Jan 07, 2007 10:49 am    Post subject: Reply with quote
Another factory supplied handle fell off. I got some double sided tape (heavy duty, for carpet,) cut a piece to fit, and put it back on. Seems to be holding.
It isn't a bad lot from the supplier. I don't know what the window supplies is using, but it doesn't stick to glass too well.
The southern (warm) Boris
astasky
City/Region: Albany,
State or Province: NY
PostPosted: Thu Jan 11, 2007 7:37 pm    Post subject: missing window handle Reply with quote
Mark,
The missing handle mystery is now solved. I went to close the window one day and the handle just flew off, right out the window and sank in the Hudson River, gone. I forgot all about it. Any other questions please feel free to ask me.
I should take the time now to tell all the other C-Brats that the title issues are worked out and the new ones are on the way. New York State was very cooperative and understanding. Good luck Mark!
Andrew
chromer
C-Dory Model: 19 Angler
Photos: Checkpoint II
PostPosted: Sun Nov 08, 2009 11:28 pm    Post subject: Reply with quote
My port side window handle is loosening up. Is double-sided carpet tape the consensus best choice for putting it back on solid?
Checkpoint II (SOLD 10/2020)
Alure Bertram 28
PostPosted: Mon Nov 09, 2009 12:12 am    Post subject: Reply with quote
So far I've tried:
1. new handles, a waste of time, since they ain't free anymore.
2. Double sided tape, this was so long ago, I forget exactly what happened, but it didn't work.
3. Epoxy glue recommended by a glass place. Fell off last summer.
4. Tried to drill a hole. Tempered glass, don't do it.
5. One more thing I can't remember.
Since I saved a couple of handles, I think I'll try silicone seal next. Tried a dab on a window, and can't get it off.
SGIDave
City/Region: St. George Island
Vessel Name: Seadation - SOLD 09/2013
Photos: SeaDation
PostPosted: Mon Nov 09, 2009 8:56 am    Post subject: Reply with quote
Hello,
When one of my window handles came off, I scraped all the remaining adhesive off the handle and window. I then reattached it using HONDA WEATHERSTRIP CEMENT and it is holding strong after 5 months.
I bought it from this place: http://www.boats.net/parts/detail/H-08712-0002.html
YMMV and I have no material interest in the above product or business,
/david
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Nov 09, 2009 9:38 am    Post subject: glue Reply with quote
I would try the glue they use for auto mirrors Go to a parts store and try to get some use the mirror by skrewing it in and then use the glue to reattach the window handles
chromer
PostPosted: Sat Jan 09, 2010 8:08 pm    Post subject: Reply with quote
Diamond has agreed to send me a new handle, for a price $10. Just thought I would document it here. They do call the window a D15.
Page generation time: 0.0619s (PHP: 66% - SQL: 34%) - SQL queries: 29 - GZIP disabled - Debug on
