Bedding down for the night
Goto page 1, 2, 3, 4  Next
captd
City/Region: Chain of Lakes
State or Province: MT
C-Dory Year: 1994
Vessel Name: Kon Tiki
Photos: Hunky Dory
PostPosted: Thu Oct 25, 2007 5:17 pm    Post subject: Bedding down for the night Reply with quote
My Mis Dee (wife) has insisted on having a comfortable sleeping arrangements. At a Cabalas store we found the higher end air mattress and thought we would give it a try. It halfway inflates its self and a few more huffs and it becomes three inches thick. It felt ( to me ) as good as the select comfort ( The sleep number bed ) we use at home and in the camper. Mis Dee has not had any experience on it yet. We also have that real soft closed cell foam, 4 inches thick. When you press on it it leaves your hand print in it for awhile. Mis Dee has a hip problem and the foam works pretty good for her. What I don't like about it is, it is awful heavy stuff. This winter we will be sleeping many weeks on the boat. This problem must be solved or I will be boating alone. I have been warned.
( not only that but I will be sleeping alone.)
captd
100 ton Master
1986 Sport Craft 27 ft , 240 hrs Yanmar sold
2000 22 ft C-Dory (Hunky Dory) sold 2006
2007 25 R Ranger (Mis Dee) sold 2008
2009 25 R Ranger (Lucky Fin) sold
1994 22 ft C-Dory ( Kon Tiki )
PostPosted: Thu Oct 25, 2007 6:45 pm    Post subject: Reply with quote
We got a queen size memory foam 2" thick for the Tom Cat 255--and one side of the CD 25--works well for us. It is a bit heavier, but doesn't seem to present a problem.
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Thu Oct 25, 2007 10:30 pm    Post subject: memory foam Reply with quote
A memory foam mattress is cold and hard when you first get on it but quickly warms up and I think is warmer than a normal foam pad. We keep a ceramic heater in the v-berth and it keeps things cozy
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Thu Oct 25, 2007 10:35 pm    Post subject: Reply with quote
We too have 2 " of memory foam cut to fit the sleeping area of the 22. Makes all the difference between a toss and turn and a good nights sleep waking up feeling rested. Well worth the extra weight.
Rob & Karen
City/Region: Franklin
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Oct 25, 2007 11:29 pm    Post subject: Reply with quote
For those of you that have memory foam in the v-berth, what do you do with it during the day or on day cruises? Is it covered with a sheet of some kind to keep it clean? Are you also using a Travasak or just regular bedding? My daughter likes to play in the v-berth during the day and I am wondering if the memory foam would be in the way. Seems like it might make accessing the porta-potti more difficult as well. The idea of making things more comfortable is appealing though.
Rob & Karen
Hunkydory
PostPosted: Thu Oct 25, 2007 11:39 pm    Post subject: Reply with quote
Rob and Karen
We have it lined and use a travasak too. Porta Poty goes to the cockpit when underway. The area in front of where the porta poty is normally stored is filled in and thats the area where my head rest when I sleep so I can stretch out and be comforable. During the day most of the time the travasak and memory foam is rolled forward. That area when under way is generally filled in with clothing and other soft gear where as if one of us wants to crawl in and take a nap while underway we can.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Oct 26, 2007 2:56 am    Post subject: Re: Bedding down for the night Reply with quote
And you are a wise man indeed, to listen to her! Mr. Green
My question is, what does she find objectionable about the current mattress? Too hard? Too soft? I replaced the foam inside of the factory cushion covers with a higher grade of foam (cost me about $400 and well worth it.) We might try a 2" memory foam topper one of these days, but we have been quite comfortable with the standard cushions, with better foam.
Doryman
M/V Lori Ann
Anacortes, WA
captd
C-Dory Year: 1994
Photos: Hunky Dory
PostPosted: Fri Oct 26, 2007 9:22 am    Post subject: Reply with quote
Factory v-birth was and is to hard, plus it is too lumpy in all the wrong places. Dee has been suggesting having one custom made. One of the problems is having reasonable access to storage underneath. The air mattress works great, but they are not made in "V" shape . In the Ranger , there is enough room for two but everything you put in there must fit or it is lumpy or crawling up the bulkhead.
We ought to offer a reward for the beat idea for making the most comfy front v- birth.
captd
PostPosted: Fri Oct 26, 2007 9:30 am    Post subject: Reply with quote
Best comfy v berth is on a TomCat. Queen sized and square!! Very nice.
jimcinfra
City/Region: Crystal Springs, MS
State or Province: MS
Vessel Name: Delta Belle
Photos: Delta Belle
PostPosted: Fri Oct 26, 2007 11:35 am    Post subject: Reply with quote
We also were very uncomfortable with the v-berth in our 22 and tried to up-grade by using a thin egg shell. We must have some hidden royalty in our blood because we were still uncomfortable. Not until we followed the advice from this site and purchased some memory foam did we get the comfort we were looking for. We got some 3" thick and put on top of the thin egg shell and now its like sleeping on a cloud. We trimmed the egg shell and the memory foam to fit into the v-berth. We cover the bed with a blanket so the we can still use the hatch in the bow without "sanding up" the berth. We also added a small board across the opening (over the poty) so that our heads do not sink into the depression. There is some extra effort in lifting the board to slide the poty out, but this arrangement works for us.
Delta Belle
Crystal Srings, MS
PostPosted: Fri Oct 26, 2007 1:38 pm    Post subject: Reply with quote
To expand on Delta Bell's remark--we have a 7 x 5 foot piece of canvas which works great as a "Bed Spread"--and allows us to step thru the hatch etc--just shake it out, if there is grit--and folds up at night for sleeping.
PostPosted: Fri Oct 26, 2007 3:14 pm    Post subject: Reply with quote
I use the foam in the Susan E also and it has been great. I can not sleep unless Iam on my side and unless we have the foam my hipps hurt all night. the first year I got little sleep on the boat until we got the foam. I ened up rolling over on to the other hip every two hours, now with the foam I sleep thru the night. Susan even sewed a cover for the foam out of fleece. really works well for me.
Rob & Karen
PostPosted: Fri Oct 26, 2007 4:21 pm    Post subject: Reply with quote
So is 2" of memory foam enough, or would 3" be better? We often fall into the "if some is good, more is better" routine.
Rob & Karen
Doryman
Photos: Lori Ann
PostPosted: Fri Oct 26, 2007 6:07 pm    Post subject: Reply with quote
I don't know if this would be a factor for your boat, but on the TC, if the memory foam was too thick it would make it real difficult to get into the three lockers in the bow. The bottom of the hatches is right at the level of the factory pad, so the memory foam pad would have to be rolled out of the way to provide access.
Tom, the fleece cover that Susan made sounds like a great idea!
PostPosted: Fri Oct 26, 2007 6:16 pm    Post subject: Reply with quote
We thought that 2" was enough for us--and we have used 2" on two RV's, our bed at home and our boats. The weight is a problem when opening the hatches under the bunks...
Page 1 of 4
Page generation time: 0.0622s (PHP: 56% - SQL: 44%) - SQL queries: 32 - GZIP disabled - Debug on
