inside overhead CD25 rod holders
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sat Jan 03, 2015 5:26 pm    Post subject: inside overhead CD25 rod holders Reply with quote
In the process of installing overhead rod holders in the cabin. What has been holding me back is I'll need to remove the stereo from the shelf above the helm; I'll need the extra forward space to accommodate rod tips.
Replacing the stereo with a simple AM FM with Bluetooth and USB plugs will be another project.
I figure my long down rigger poles will mount to port so not to interfere with the bathroom door then store the shorter halibut type rods to center.
The plan is to fabricate brackets to attach to whatever rod holder I use and secure them to the top rail mount screws.
Having the ability to store the fishing rods in the cabin when not in use will be a huge convenience for us.
So in doing the math and making a few measurements I figure I can store 6 fishing poles out of the way against the ceiling of the cabin.
I've got a pretty good to fair idea how I want to approach the project but would welcome any constructive criticism or ideas. In looking through the albums I've yet to see anyone with overhead rod holders but I've only looked at a few dozen in search of pictures.
Boatless for now but looking
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sat Jan 03, 2015 6:03 pm    Post subject: Reply with quote
I have seen guys use lengths of pvc pipe for rod holders. Measure the dia. you will need to fit the largest eye(closest to reel). Just the reel and handle stick out and can be supported with a Velcro strap, small bungie, etc.
Don't know if this would work for you, usually I have seen them under the gunwales or in floor locker.
Regards, Rob
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Sat Jan 03, 2015 6:52 pm    Post subject: Reply with quote
Check out C-Critter pictures mine is only for three poles but could do more then one, one end is split and hinges down. 3M 5200 holds it in place very solid.
Richard
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Jan 03, 2015 8:39 pm    Post subject: Re: inside overhead CD25 rod holders Reply with quote
I used 2 Berkley sets @ $15.00, thru bolted, 5200 sealed,
holds 4ea 8.5' salmon rods & 4ea 6' Butt rods.
[url][/url]
[url][/url]
schiavolou
City/Region: Wilton Creek, VA
Vessel Name: Skimmer
Photos: Skimmer
PostPosted: Sat Jan 03, 2015 9:48 pm    Post subject: Reply with quote
Skimmer has this inexpensive rack installed in the overhead:
http://www.overtons.com/modperl/product/details.cgi?pdesc=Trac-Rod-Fishing-Rod-Storage-System&i=29987
It is off-center to port and the butts of 5.5' trolling rods and 6.5' spinning rods extend forward into the space over the shelf. The head door clears all rods.
Sorry, no pix.
Lou S.
Skimmer
Robert H. Wilkinson
Photos: Romakeme IV
PostPosted: Sat Jan 03, 2015 10:20 pm    Post subject: Reply with quote
Some rod holders are also great for securing your removable/pole type anchor/all around light.
breausaw
Photos: Triple J
PostPosted: Sun Jan 04, 2015 3:32 pm    Post subject: Reply with quote
These are what I had in mind attached to flat stock or aluminum channel then anchored in place using the existing top rail through bolts.
Like the looks of the Berkley install but want to avoid adding additional holes in the cabin roof, could make them work perhaps.
The Trac-A-Rod Fishing Rod Storage System holds promise.
I used 5200 to attach my shelves behind the galley so I know it would work for the rod holders. A little hot glue to hold in place until the 5200 cures and its permanent.
Thanks for the feedback.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sun Jan 04, 2015 4:22 pm    Post subject: Reply with quote
My boat came with the Trac-A-Rod system on each side of the ceiling. It is simply screwed into the roof core, not thru bolted. It is nice storing the rods inside, I must say. You can adjust each piece with an allen wrench to allow for spacing of rods. I use two piece rods and they store just fine.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Tue Jan 06, 2015 9:49 pm    Post subject: Reply with quote
If you go to my photo album, you'll see my overhead rod holders. I think I can hold 8-10 (will have to count), but they've worked great for all the years I've been using them. I like the extra spaces for when I have friends come along, they can put their rods nicely out of harm.
http://www.c-brats.com/modules.php?set_albumName=album664&op=modload&name=gallery&file=index&include=view_album.php
(Sorry, forgot how to do fancy embedded links...)
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Jan 06, 2015 9:51 pm    Post subject: Reply with quote
nice Penn reels
Brent Barrett
breausaw
Photos: Triple J
PostPosted: Tue Jan 06, 2015 10:21 pm    Post subject: Reply with quote
Nice, do you know the name of the brackets?
Also like how you held it in place while the adhesive dried.
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Wed Jan 07, 2015 9:58 am    Post subject: Reply with quote
Breausaw;
I installed a 6 rod rack in my Tomcat. I made the mount out of teak and used Taco rod holders. Teak blocks mounted to roof with 5200 adhesive and screwed teak board into blocks to hold taco rod holders. There are pictures in the reefmadness album. They came out very nice and I used them the way that you describe you want to. For long downrigger rods and halibut gear.
Gene
tight lines
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Wed Jan 07, 2015 1:27 pm    Post subject: inside overhead CD25 rod holders Reply with quote
I screwed the rod holders down to strips of oak then used 5200 to get them to stay on the roof of my trucks cap. Most of the fishing outlets carry something like this setup. Powder coated steel I believe. The coating is pretty thick as there doesn't seem to be any sharp edges. On the V'd end where I put the rod tips I use a rubber band to make sure they don't bounce out if we have to do any Duke's of Hazard type stuff.
D.D.
breausaw
Photos: Triple J
PostPosted: Wed Jan 07, 2015 3:18 pm    Post subject: Reply with quote
Gene Morris wrote:
Breausaw;
Gene
Gene,
I like the use of teak and that you used the same rod holders I had in mind. I think the Taco rod holders have a clean look, you get what you pay for.
Salmon Fisher
PostPosted: Wed Jan 07, 2015 11:31 pm    Post subject: Reply with quote
Gene,
Just have to say Dawson is one handsome fellow!
Our Sunshine, 1 1/2 year old Golden, could be his sister. She loves to boat and makes friends everywhere she goes, too.
Nothing like a Golden for a your dog, they're the best!
Patrick
Page generation time: 0.0448s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
