Reliability of WALLAS 85DU/270
PostPosted: Sat Nov 08, 2008 11:56 pm    Post subject: Reply with quote
I will repeat my prior statement - there are only two kinds of Wallas owners: those who have had problems, and those who are going to have problems. No two ways about it, if you have not had problems to date, your time is coming...
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Nov 09, 2008 12:59 am    Post subject: You're Right! Reply with quote
But, while the statement that you give about the Wallas is scary, everything made by man is this way; your Toyota Tacoma is that way, your Accord, even your Swiss watch, as are the honda 45s on the back of my CD 22. Yep, you're right, they are all gonna break. But, who knows when, how often, or even if it will during your lifetime. Don't be fooled, these are good, well made stoves.
Susan E
Vessel Name: Susan E
PostPosted: Sun Nov 09, 2008 2:13 am    Post subject: Reply with quote
if i had to depend on my wallace to get to work instead of my toyota tercel... i would have been fired by now and surely missed the morage payment.
susan
as i said before ,.... the wallace is a great anchor
T.R. Bauer
PostPosted: Sun Nov 09, 2008 11:38 am    Post subject: Reply with quote
Actually, the wallas is a very poor anchor and you will not hold your position. On the other hand, your tercel would do that job much better.
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Sun Nov 09, 2008 2:13 pm    Post subject: Reply with quote
Pat and Patty,
Not to make light of your pain — we've had our own issues and know emotions can run high — but what we're wanting to gather here is data. We are guessing your stove is a 95 like ours, based on when you bought Daydream. How has your stove been running after the service you wrote about last April? We've read about the circuit board replacement in your post on the "Taking Apart The Wallas 95DU" thread.
Susan, we're guessing you have the 95 also but let us know if you've upgraded to the 85.
Judging by the scarcity of replies about the 85DUs we're guessing that it is new and dependable enough that most people haven't had problems. Though it is tempting to upgrade, at this point we're choosing to continue with the 95DU based on Scan Marine's recommendation. When it comes to service and repair, we're still in the learning curve and we appreciate the time the SM folks have spent troubleshooting. We plan to add an hour meter to keep track of usage so we'll know when to service it.
Dene, thanks for your suggestion about the quartz heater. We try to keep our electrical use low to operate the windlass, start/run the wallas and watch movies on the computer. We usually do not have shore power and sometimes will stay in the same place for several days. We have the Honda2000 generator but Tom would rather use the weight capacity for carrying beer!
- Rene & Tom
(Primative)
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Nov 09, 2008 3:00 pm    Post subject: Re: Reliability of WALLAS 85DU/270 Reply with quote
Dene wrote:
It has excellent reviews,so that was a factor. Also, it has no fan, nor needs one, and that was appealing, especially for sleeping at night. Finally, it radiates heat at low wattage. Most ceramic heaters, including the WM one we have, require 1200 to 1500 watts. That's quite a load on an alternator and/or inverter's house batteries. The 400w setting is plenty sufficient for warming up the cabin.
I've been meaning to ask you. I made a brief appearance at the Anacortes Trawler fest when some C-Brats were there. Met Trinity, Dr. Bob, and a 3rd person who owned a C-Dory. Was that you? If so, you're a heck of a nice guy. If not, you're a heck of a nice guy. :>
All good reasons! Thanks.
I don't know if I met you at TrawlerFest or not -- I am not very good at remembering the names that go with faces (and sometimes not even the faces! Embarrased) but here is a photo of me in Mexico (the hair is shorter now, but I don't remember if that happened before or after the CBGT) -- now you can tell me if we met or not!
Doryman
M/V Lori Ann
Anacortes, WA
Dene
City/Region: Kalama
Vessel Name: Fear Naut & Terra-Sea-Ta
PostPosted: Sun Nov 09, 2008 4:27 pm    Post subject: Re: Reliability of WALLAS 85DU/270 Reply with quote
Nope. The mystery continues. :> However, I'll try to look you up at the next one.
-Greg
Susan E
PostPosted: Mon Nov 10, 2008 2:03 am    Post subject: Reply with quote
yup,
my hubby says we do not have the upgrade. I will have to look into it. may be I will want to ask Santa for it.
susan e
The problem with socialism is that you eventually run out of Rich people's money...Margaret Thatcher
macmac
PostPosted: Wed Apr 29, 2009 5:49 pm    Post subject: Throttle control on Wallas stoves Reply with quote
The Wallas 95D series stoves will respond best to several control disciplines to reduce internal sooting:
1. Start with the throttle on high.
2. Make gradual power changes when running.
3. Do not run for long periods on the lowest setting with the lid down.
Using good kerosene or Klean Heat will reduce problems associated with ignoring these disciplines. Turning the power to high before shut down will simply hasten the cool down process.
The Wallas 85D stoves do not require any of the above observances, since they use a more complex start cycle, processor controlled speed change buffering and the lid fan speed changes with throttle changes to prevent overcooling. These features make them more capable of burning diesel under all circumstances and it makes diesel the fuel of choice for the 85D.
Thanks for using Wallas and don't hesitate to ask if you have any questions.
Doug at Scan
1-888-606-6665
Page generation time: 0.0397s (PHP: 65% - SQL: 35%) - SQL queries: 26 - GZIP disabled - Debug on
