Suzuki 90 Won't Start
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Jun 27, 2016 11:06 am    Post subject: Reply with quote
Maybe I miss reading it
Did you check the safety neutral switch in the throttle binnacle for voltage? and also for adjustment?
Brent Barrett
RichardM
City/Region: Akron
State or Province: OH
Vessel Name: Pangur Ban
Photos: Pangur Ban
PostPosted: Tue Jun 28, 2016 2:55 pm    Post subject: Reply with quote
FOUND IT! My electrician friend and fellow C-Dory owner Bob came over this morning and spent about two hours following wires around. Bob doesn't hesitate to follow colored wires from here to there, use test leads to pierce insulation and test for power, etc.
The problem was a broken wire in the wiring below the motor remote control at the helm. From the neutral sensor switch inside the shift unit there are two brown wires running to the motor. At the helm end, from the neutral switch going down, these wires originate as a pair about 16 inches long -- then there's a pair of spade terminals allowing them to be disconnected (maybe you'd want to do that if replacing the shift mechanism, for example). Those 16 inches of brown wires are further enclosed in a black plastic sheath.
One of those wires had a break in the middle of its length. Nothing was obvious on the outside of the insulation, though on very close inspection you can see that both brown wires had been pinched at that point, maybe when the shift mechanism was screwed down to the fiberglass base by the helm seat. One wire had lost all continuity. The other one, when the insulation was removed, had a couple of broken strands and a clear bend at the same point. The fact that this happened suddenly suggests that the wire had been breaking one strand at a time, and finally broke completely while the boat was being trailered the last time.
Bob says he can count on one hand the times he's seen a broken wire in the middle of its run in any electrical system. After replacing the 16 inch "pigtail" with new wire, the motor starts and runs perfectly.
Thanks again for your advice and encouragement. This was a hard one.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Tue Jun 28, 2016 3:50 pm    Post subject: Reply with quote
No kidding! I have "played" with electricity in many capacities since I was a kid. Altho a broken wire inside an insulation sheath is always a possibility, I can't think of a single time I ever seriously considered that in a theory as to what's wrong. You don't get a harder problem to find than that!!!
BrentB
Photos: BrentB
PostPosted: Tue Jun 28, 2016 3:58 pm    Post subject: Reply with quote
Thanks for the update
RichardM
City/Region: Akron
Photos: Pangur Ban
PostPosted: Tue Jun 28, 2016 5:00 pm    Post subject: Reply with quote
Brent and Bob, you were both close. It was in the binnacle control and in the neutral switch circuit there, and it was a "factory crimp type" problem. And yes, it was one of those that could drive you to drink....
Anyhow it is running again and ready to go into the water for only the 4th or 5th time in my ownership. Now I need to find a way to mount the new kicker, a 6 hp Tohatsu, to the boat so it doesn't interfere with the Suzuki and still misses the trim tabs. On the transom directly, when set so it clears the trim tabs, it interferes with the Suzuki. I'm looking at TyBoo's motor mount design which can be bent from a piece of stainless and is a fixed mount (the lifting mounts force you to lean way over the transom to lower or raise the motor).
A simple fixed commercial mount sells for about $75 also. An important issue is whether the motor will tilt out of the water without hitting the transom or hydraulic steering mechanism. Think I'll need to build a wooden mockup to find out.
Thanks again for the online advice, experiences from others and fact checking. It's worth a lot to own a boat with an owners' group like this one.
PostPosted: Tue Jun 28, 2016 5:08 pm    Post subject: Reply with quote
Glad you found out the problem. That old volt meter in the hand, always seems to find where the issues are, and the brains in the head of the helper knows where to go!
I guess I am not to surprised that a screw from the installation is the cause of the problem. My Tom Cat was about the same era as your boat, and I had several electric issues due to less than 100% attention at the factory...
Good thing now is that you will never (we hope) have that problem again!
AK Angler
City/Region: South Central
Vessel Name: Rod Holder
Photos: Rod Holder
PostPosted: Tue Jun 28, 2016 5:10 pm    Post subject: Reply with quote
RichardM wrote:
FOUND IT! My electrician friend ... doesn't hesitate to follow colored wires from here to there, use test leads to pierce insulation and test for power, etc.
Be sure to repair all that pierced insulation, or you'll be replacing corroded wiring in the not-too-distant future.
-Rod
BrentB
Photos: BrentB
PostPosted: Sun Jul 03, 2016 10:29 pm    Post subject: Reply with quote
Good job better buy your buddy lunch
Was the bad spot noticeable on the outside?
Page generation time: 0.0296s (PHP: 66% - SQL: 34%) - SQL queries: 21 - GZIP disabled - Debug on
