updated gas tanks
wailedcentipede
City/Region: canada
Vessel Name: Blue Jay
PostPosted: Sun Jan 01, 2006 7:21 pm    Post subject: Reply with quote
your first application was the fiberglass ...
your second application was the gel coat ...
would the first application not have to cure for 30 days???
their may be a reaction between the two applications ...
the first is still giving off solvents ...
different systems have spacific recoat times
if nothing else you have everyone guessing .. lol
PostPosted: Sun Jan 01, 2006 8:56 pm    Post subject: Reply with quote
Steve-
I've just done some reading on this topic, and, in general, applying polyester gel coat over epoxy is not recommended.
The polyester gel coat won't set up properly on epoxies especially where unused epoxy catalyist provides amines which interfere with the polyester bonding to the epoxy and the polyester hardening itself.
To properly apply a polyester gel coat to an epoxy resin, the surface must be sanded to remove any wax and amines, washed with solvents, and allowed to breathe in the air. Then a "tying coat" of epoxy paint is recommended, followed by sanding again and then the application of the polyester gel coat.
But some gel coat manufacturers don't recommend it, period.
Here's a couple of links where some of this is discussed:
http://www.epoxyworks.com/22/polyester.html
http://www.systemthree.com/faqs.asp
Enjoy! Joe.
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Jan 01, 2006 9:17 pm    Post subject: Reply with quote
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Mon Jan 02, 2006 12:37 am    Post subject: Reply with quote
Well there you go! My friend that helped me with this has worked with epoxy a far bit but probably not the gelcoat. Wish I had known this before.
Since I want to get the boat back together I will leave it as it is and see if the gelcoat will harden further. Basically it is sound, it's just a matter of if water could eventually penetrate the wood cleats.
Thanks for the research.
Steve
dogon dory
PostPosted: Mon Jan 02, 2006 12:44 am    Post subject: Reply with quote
PostPosted: Mon Jan 02, 2006 12:45 am    Post subject: Reply with quote
Steve-
Your installation of the tanks and hinged anchor light looks great!
Here's a link for those who would like to see the photos in your album:
http://www.c-brats.com/modules.php?set_albumName=album68&op=modload&name=gallery&file=index&include=view_album.php
Joe.
AstoriaDave
City/Region: Astoria
PostPosted: Mon Jan 02, 2006 1:09 am    Post subject: Reply with quote
seabran wrote:
I don't understand what the difference is. It does seem that the gelcoat has a harder time setting up when it is applied over epoxy and glass versus the vinylester and glass. The gelcoat that is just on the original part of the boat is hard as nails.
Oh, man! I did not pick up on this in your earlier posts ... polyester resin will not set up if applied over epoxy, unless you lay down a barrier coat first. No wonder this was not working. They have the product you need at the marine supply store (or, they should). West Marine has it for sure.
Wish I had picked up on this in the beginning -- could have saved you some work and hassle. Sorry about that.
Dave Kruger
Astoria, OR
Page generation time: 0.0345s (PHP: 64% - SQL: 36%) - SQL queries: 20 - GZIP disabled - Debug on
