Choosing Between Various Heaters and Stoves
PostPosted: Sun Oct 05, 2008 12:20 am    Post subject: Reply with quote
siddfynch-
This is one of those topics that we go around on yearly about now, in the fall, when the weather turns cold.
First, look through all the cabin interior photos of different heater installations. The ones on my boat, Sea Wolf, which features a Cozy Cabin heater and a three burner propane cook top, have full explanations of how and why everything was done, including safety measures, and the tank placment. Start HERE.
Then you can go to the Cabin, Interior Forum and read about the topics on heaters and stoves. Forget about the Wallas, Webasto, and Espar if you don't want to spend $2500-$3000. The Toyotomi is about $1500 (a few years ago anyway), but will drive you crazy cycling on and off all night, as it's output is too great for a CD-22, and it can only cycle on and off to maintain a temperature, there being no multiple output level settings.
There will be discussions of the pros and cons of using a Mr. Buddy Heater (unvented) as well. Read them carefully!
Let us know what additional questions you have.
Good Luck!
Patrout
City/Region: NORTH POLE
C-Dory Year: 1983
C-Dory Model: 22 Classic
Vessel Name: C-FARER
Photos: C-FARER
PostPosted: Sun Oct 05, 2008 1:06 am    Post subject: Reply with quote
It dropped to about 12 degrees last night here in North Pole. There's maybe an inch or two of snow on the ground and the pond out by our lane has a thin film of ice on it. Winter is a-coming, alright.
I have a small Danielson on the C-Farer. It fits right in the back corner of the cabin. I like the sealed air intake-exhaust system just fine. The fan circulates the air enough to keep the windows from fogging up when it's rainy and the temps drop into the 50's and below.
I got 3 nights of heat this August out of a one-pound bottle of propane and I was very glad to have the stove on those cool nights out on the water. The stove came mounted on a nice stainless steel heat shield that we cut to fit the cabin, too.
If you search the message threads, you'll find someone's propane box that was installed in the cockpit on the starboard side next to the bulkhead. That's a nice place to put your tank and provide a step up, too.
Pat
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Oct 06, 2008 12:20 pm    Post subject: Reply with quote
The Espars I have had were all mounted in the cockpit lazarettes, which although outside the cabin area, were still too close to the living area. The do such a good job that they go through the start up cycle, hot air blows, then a couple minutes later the living space reaches the temperature you set and they shut down. But on boats the living space cools down so fast that the heater then cycles on again. A bit noisy.
Chester
City/Region: home
Photos: Chester
PostPosted: Mon Oct 06, 2008 1:42 pm    Post subject: Reply with quote
Here is the link journey on referred to; http://dragonfly-trimarans.org/wallas_diesel.htm
Has anyone found instructions on how any to go deeper into the unit. The thing is built like a Chinese puzzle.
PostPosted: Mon Oct 06, 2008 2:22 pm    Post subject: Reply with quote
Hey Milehog, Here's a great Pictorial on going deep into Mr. Wallas...
PostPosted: Mon Oct 06, 2008 2:56 pm    Post subject: Reply with quote
Charlie-
Nice find on the Wallas instructions from the Dragonfly Forum!
Two or more things really need to be done regarding these heater / stove topics.
1.) A separate forum for Heaters and Stoves needs to be established to separate them from the rest of the Cabin, Interior topics.
2.) The forum needs to be divided into
A. Wallas Stove Topics, with a Documents and Manuals Section. Photo section included.
B. (an) Other Stoves and Heaters section. Photo section included.
I know this might be a lot of work, but finding information on specific stove and heater problems can be difficult.
This A/B division might be complicated or impossible if some of the threads contain discussions of both Wallas and other stoves and heaters, but cutting them out of the rest of the cabin, Interior Forum would be useful itself, including their photos.
Just another crazy idea for $0.02 (minus, of course, a %-age for 700 points off the Dow Jones Industrial Average so far, today)! Sad
Joe. Teeth Thumbs Up Thumbs Down Question
PostPosted: Mon Oct 06, 2008 3:09 pm    Post subject: Reply with quote
Concur Joe. Of course, we don't have to do it. I'd be glad to give it a crack if I had the permissions....
Dow Shocked Shocked
Sure glad I'm gonna work for another 5 years or so and don't need my retirement accounts right away! Maybe they'll be back up by then! Wink
PostPosted: Thu Oct 16, 2008 1:32 am    Post subject: Reply with quote
I'm bringing this topic back up to answer an email that won't transmit for me:
Re: Propane heaters and stoves:
Do you have a photo of the installation for these, or have you shown this
> previously. I do not like my Wallas, I prefer propane.
> MikeC
Mike-
The photo story of my installation is in the detail photos that are under the "Cabin, Interior" Forum. My installation starts on the second line of photos and has full details:
See here:
http://www.c-brats.com/modules.php?set_albumName=Cabin,Interior&op=modload&name=gallery&file=index&include=view_album.php
Let me know if you have questons. There is a specific thread about the installation somewhere, but it's hard to find.
Joe.
Westfield 11
City/Region: Woodland Hills
PostPosted: Thu Oct 16, 2008 11:09 am    Post subject: Reply with quote
Two thoughts regarding propane: Composite tanks are now available and might be a valid alternative to Alloy.
Also propane contains a lot of moisture that is released as it burns, if used in a non-vented installation you may have condensation issues.
Not a C-Dory owner but a lover of the forum and the spirit of adventure found here. This is the best small boat cruising resource I have found to date. The travelogues are very inspirational and a great reminder of why we go down to the sea in ships (or small boats).
PostPosted: Thu Oct 16, 2008 12:42 pm    Post subject: Reply with quote
Good idea! Although anodized aluminum has also been available for years, I just keep by 5 gallon steel tank painted reasonably well.
Of course, all combustion produces CO2 and H2O, that's why my Force 10 heater is vented and there's a vent over the 3 burner cooktop stove. This vent could be fan powered if necessary, though I haven't seen the need for it yet.
On my other, bigger, boat, I just run a Honda 1000i generator on the back corner of the transom and use an electric heater and microwave. The boat also has an alcohol/electric Kenyon combination cooking stove, but I prefer not to mess with the pressurized alcohol, and the electric heating elements take too much power for the small Honda generator, as do the electric heating elements in the water heater. They all work find on Shore Power, though.
We also have an electric toaster oven, refrigerator, coffee maker, TV, Stereo, electric blanket, etc. The only drawback to the generator is the noise and the occasional refilling of the gas tank. A Coleman propane transom stove also allows outside propane burners as well as a grille and griddle.
If you've got a lot of battery power, an inverter gives you another way to crank up the 120-V options. We have one of these on the 22 as well, and I use the generator on the 22 also.
I also just added a Mr. Buddy heater for use in the enclosed cockpits of either boat, where ventilation is not an issue.
I like the idea of having multiple systems to choose from for adaptability.
How about a towable dinghy with a 4 -6.5 kw generator sealed/enclosed in it and an electric motor for driving around? Add an extension cord and rigid v-bridle, and you could tolerate towing through some moderate chop as well. (On Edit: I know this would be impractical in the open ocean or large, rough bays, but on a relatively calm body of water, it would give you a nice power source removed from the immediate boat for noise control, and give you some added transportation to run around in when anchored or shore/docked. We tow a jet ski around with a v-bridle made of 3" PVC pipe and filled with flotation and elastic and rigid cords that allows comfortable towing and can even accommodate backing up, since the bridle is longer than the towed boat.) Never hurts to explore some new ideas just to see how far you can make them go and perhaps come up with something workable.
Joe.
Teeth Thumbs Up
Jeanie P
City/Region: Alexandria
Vessel Name: Jeanie P - sold 11/08
PostPosted: Fri Oct 17, 2008 7:57 am    Post subject: Reply with quote
All the Mr. Buddy heater adds say that they last 108 hours. Do they mean that the heating filament or something else will wear out sometime after that so that you have to replace the heater?
Allan
PostPosted: Fri Oct 17, 2008 10:57 am    Post subject: Reply with quote
Allan
Allan-
I think they're talking about the running time on a 20 lb (5 gallon) external tank.
The heater will run 3-6 hours on a 1 lb. propane disposable cyclinder (3 hrs on high, 6 hrs on low.)
It will burn 110 hrs on the 20 lb external tank with the adapter hose.
From their WEBSITE:
"Specifications:
• Model No. MH9B
• Stock No. F273400
• Output: 4,000 - 9,000 BTU/HR.
• Gas: Propane
• Operating Position: Vertical
• Valve Position: Pilot, Lo and Hi
• 1 lb. Cylinder: 3 - 6 Hours
• 20 lb. Cylinder: 48 - 110 Hours
• Overall Dimensions (LxWxH): 14 in. x 7 in. x 14 in.
• Shipping Weight: 8 lbs."
If you want to buy one, I'd recommend you use Amazon or some similar shopping service to find the cheapest source, since the price can vary from about $80-$110, plus shipping and/or tax. Free shipping and no tax (out of state), will also help save $$$.
You can also get one at Wal-Mart for $79.97. Shipping may be free from store to store, but you will pay your state tax.
or
Northern Toll and Equipment for $74.95 plus shipping, and tax if they have a store in your state.
Jeanie P
PostPosted: Fri Oct 17, 2008 2:44 pm    Post subject: Reply with quote
I thought I was reading it wrong. Embarassed It didn't make sense to have to buy a new one that soon.
Thanks Joe.
Allan
Alli Cat
Vessel Name: Alli Cat
PostPosted: Sat Oct 18, 2008 2:33 pm    Post subject: Heater Reply with quote
We are also considering adding another heater other than the Wallas cooktop. I am looking for advise/experience on the mounting location for a Webasto or Espar in our Tomcat 2007 and any pictures. The goal is to add heat/defrost to the windows as well as overall cabin heat.
Fred
Alli Cat
Fred and Allison
macmac
PostPosted: Mon Oct 20, 2008 10:38 am    Post subject: Wallas reference materials Reply with quote
Concerning any issues involving Wallas stoves, ovens or furnaces, please use only current, authorized reference materials. These can be found at one of two sites:
www.scanmarineusa.com Go to Tech Talk and look for the papers in .pdf.
or
www.wallas.fi Click the "English" option unless you are a Finn.
Current materials are very important. Changes and improvements to Wallas products are ongoing. Important features can be absent from outdated reference guides.
Finally, please contact us at Scan Marine for troubleshooting. We can help in most cases, M-F, 9-5.
Thanks for using Wallas!
Page 2 of 3
Page generation time: 0.0538s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
