siezed windows
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Jul 08, 2008 1:04 pm    Post subject: Window latch Reply with quote
I had to loosen up another stuck window the other day and in the process I ended up pulling the window handle off. What's the best stuff to use to stick the handle back on the window?
Thanks!
Captain Matt
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Tue Jul 08, 2008 4:29 pm    Post subject: Reply with quote
I've just used plane old household clear silicone seal (caulking). Key is that you may want to get it off at some time in the future. A marine variety is probably a better choice if you have some laying around but I doubt its worth the cost and trip if you have standard silicone seal around. a little dab'll do ya.
chris
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Tue Jul 08, 2008 5:06 pm    Post subject: Reply with quote
Matt, there is a clear gel repair stuff "Goop" for shoes, for this, for that, that works well for repairs.
The key to unsticking the sliding windows is to LIFT the glass a bit by using the aforementioned putty handle knife or wood/plastic piece about 5/8" x 1" x 6" by putting the base up against the inside window frame and the side UNDER the window handle and carefully PRYING WITH EMPHASIS UPON LIFTING THE GLASS UPWARD. This more upward pressure lessens the chance of handle breakage and all you want is 1/16 - 1/8" upward movement to loosen things up.
We had a lot more problems with this in salt water and none of the sprays, silicone, whatever helped since they all seem to trap dust and debris. Keeping the channels clean is important.
Also, the outside drain flaps build up with spiders, bugs, dust, etc., but allow a good access point to force water backwards, up and out to keep things clean and to allow some space for any debris that accumulates to slide into. I spray a hard stream of water up these outside vents weekly and often seen lots of junk come flying out from the bottom of the window channel.
The best spray I found was "BOESHIELD", an expensive spray developed by Boeing for aircraft sliding components, BUT it also seemed to trap and hold dust and salt crystals. Lots of clear water flushing backwards thru vents and inside channels when open is the key. If stuck, LIFT UP on the front of the glass pane instead of pulling back. And,yes, somethimes you have to close the window more in order to release the latch.
Page generation time: 0.0845s (PHP: 21% - SQL: 79%) - SQL queries: 16 - GZIP disabled - Debug on
