Fuel-filler grounding on 22 Cruiser
Goto page Previous  1, 2, 3
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Fri Jan 25, 2013 12:24 pm    Post subject: Fuel-filler grounding on 22 Cruiser Reply with quote
I'm now selling my damn boat too dangerous to put fuel in it. Or maybe I'll just have the fuel attendant do it while wait for the process to be over in some other zipcode. I think grounds in a car are tied to the negative side of the battery. Remember cars used to have accessory ground strap hanging underneath. I think I get one of those for the boat. Very Happy What happens if you fill the boat while it's on a trailer? I guess the battery ground is all you have.
D.D.
PostPosted: Fri Jan 25, 2013 1:07 pm    Post subject: Re: Fuel-filler grounding on 22 Cruiser Reply with quote
It seems this thread has annoyed some readers. Let me just clarify my intent:
1) I have zero interest in telling anyone what they should do, or how they should set up their boat. To each their own.
2) Emurph came up with a question about grounding fuel system components, and the discussion was going on in a thread started for a different purpose, so I moved it to its own thread. I thought others might find it of interest (vs. Emurph and I discussing via PM).
3) If I had a planned trip tomorrow on my C-Dory and my fills were ungrounded would I still take the boat out? You bet I would. On the other hand, am I going to purposely reinstall the fills without grounding them? Probably not given what I have learned and how little effort it will take to ground them.
4) However, I don't expect that ungrounded fills are going to blow up very often, if ever; and I don't expect other people to set up their boats the way I do, or even change things based on this thread. I consciously did not suggest that another setup is "A dangerous accident just waiting to happen!!!" I dislike that sort of alarmist writing and the "you should do what I do or else" implications it carries.
I'm going to ground the fills to the negative bus as suggested, so that will be using the battery/ground.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Fri Jan 25, 2013 1:25 pm    Post subject: Fuel-filler grounding on 22 Cruiser Reply with quote
Sunbeam,
Just a little humor. Maybe your taking this too seriously. Sorry if I offended your reporting on what your doing. I meant no harm. Your projects are always on the forum, great info. If your suggestions were for someone in particular there is always a PM. But his thread was real interesting. Keep up the good work.
D.D.
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Tue Jun 10, 2025 11:02 pm    Post subject: Reply with quote
Well lets revive this thread. I'm no electrical wiz but there are grounds and there are grounds. What I mean is that the negative post on a battery is a "ground" for a CD22. BUT when on a trailer that terminal is not grounded (think connected) to the ground (think earth), so for the CD22 electrical system it is the "ground" but for the rest of the earth it is the detached (or not connected) electrical system for the CD22. The gas station fuel nozzle is grounded to the earth but to prevent a spark with the CD22 the CD22 needs to have its negative electrical system (including a connection to the metal fuel fill) connected to the earth. However, when in the water especially salt water the negative electrical system of the CD22 is connected to the earth via the motors when they are in the water and the gas pump nozzle is grounded to earth and the earth to the water hence nozzle and fill are at the same potential - therefore no spark possible.
I have a 2002 CD22 with no filler wire and what I plan to do is when fueling anywhere loosen the metal cap all the way, touch the nozzle to the fill, remove the cap, insert the nozzle and make sure to keep the nozzle in contact with the fill until finished.
shad
Vessel Name: C-Squatch
Photos: C-Squatch
PostPosted: Wed Jun 11, 2025 11:31 am    Post subject: Reply with quote
I grounded my fuel fill by clamping a ground wire between a hose clamp directly to the top of the metal tube. Then ran the ground wire to a battery negative bus terminal.
Assuming the following is from the current code revision, clamping metal-to-metal should suffice. They just do not want people sandwiching the wire in between the hose.
Wire ends shall not be clamped between the fill pipes and hose.
Replacing one of the fill screws with a through bolt is a cleaner option.
Page 3 of 3
Page generation time: 0.0453s (PHP: 43% - SQL: 57%) - SQL queries: 18 - GZIP disabled - Debug on
