Fresh Water Tank Level on 25?
Goto page Previous  1, 2, 3
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat Mar 18, 2006 10:19 am    Post subject: Reply with quote
Yep, think you're right Pete -- don't hook your water hose to THAT tank... Crook
My same thoughts on the water heater also, I opted to have them leave it out, I rarely dock except to launch/retrieve.
After I cut the hole above the left part of the tank, I'm hoping I can re-level it (slim), then I'll liquid foam it in place, both sides. It's a plan anyway...
Steve
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Fri Aug 12, 2011 11:10 pm    Post subject: Reply with quote
Today I added a small, clear, inspection cover to the wall hiding the bow positioned water tank on our 2005 25'. The cut was a pain with only an inch of clearance between the tank and the wall but some drilling and a roto saw did the job. I ran the water out until the pump sucked air at the dock and started refilling with a 1 gallon jug from that point. At 5 gallons I marked the first line visible through the cover. At 8 gallons I marked the second and at 10 I marked the third. At lower and higher measures, the small port does not allow viewing but I really wanted just the lower end anyway and that is why I positioned it low. The tank only took 16.25 gallons so that is our usable capacity. At least we have a warning when things get on the low side. Hoped for more but we do keep at least a couple of extra gallon jugs in the anchor locker if things get tight. We use a good filtering pitcher to assure the tank water is drinkable.
http://www.c-brats.com/modules.php?set_albumName=Changes&id=0812111212_G&op=modload&name=gallery&file=index&include=view_photo.php
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
jerry97230
City/Region: Portland
Vessel Name: C NILE
Photos: C NILE
PostPosted: Fri Aug 31, 2012 7:26 pm    Post subject: Reply with quote
The sight tube must be higher than the fill hole or ir will run over when you fill.
Otherwise this works very well.
Jerry
Page 3 of 3
Page generation time: 0.025s (PHP: 59% - SQL: 41%) - SQL queries: 16 - GZIP disabled - Debug on
