Floorboards c-dory 19Ft
Goto page Previous  1, 2, 3
WeekiTiki
City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
PostPosted: Sun Oct 11, 2020 5:05 pm    Post subject: Reply with quote
I still like my 3/4" Bedrug in both the cockpit and cabin
It's loose and you can dump it easily
And it's way great to walk on too
Wish I could get the corrugated material like what fits in my truck bed where the water would actually run under it; that would be way good
I bought ten by six piece for about a c note and cut it to fit
What was left is really nice to kneel on while working in the driveway
Weeki Wachee
PostPosted: Sun Oct 11, 2020 8:57 pm    Post subject: Reply with quote
One note, both the hydraulic steering system and the trim reservoir were very low on fluid, and topping them up made a huge difference. I used OMC hydraulic fluid (In the 10 ounce tube, which I keep on board) to top them off. It meets all the listed specs, and at $8, was pretty easy to get.
Where were you able to verify that the OMC trim and tilt hydraulic fluid meets Mil. Spec 5606?
This is what is called for by Sea Star hydraulic steering systems.
Scuppers
City/Region: Knotts Island
C-Dory Model: 19 Angler
Vessel Name: Scuppers
PostPosted: Tue Oct 13, 2020 12:03 am    Post subject: Reply with quote
here's a list of all the hydraulic oils that are curently qualified as MIL-PRF-5606. The are most likely a lot of other fluids that would meet it that their manufacturers haven't gotten tested against the mil spec. From QPL-5606-31 rev's 0, 1 and 2. 0JWS4 Arpolube 5606 MLB 02-27 4 Sept 02 Distributed by: Arpol Petroleum Company 2275 Tucker Industrial Rd. Tucker, GA 30084 98308 Brayco Micronic 756 MLB 02-15 21 Mar 02 Castrol Industrial North America Endurance Technology 1001 West 31st Street Downers Grove, IL 60515 Plant: 5511 District Blvd. Los Angeles, CA 90040 04BH0 Chevron Aviation Hydraulic Fluid G Texaco Aircraft Hydraulic Oil 5606G MLB 01-08 5 Oct 01 MLB 01-08 5 Oct 01 Distributed by: ChevronTexaco Global Lubricants 6101 Bollinger Canyon Rd., T3066 San Ramon, CA 94583 1PWD8 Invarol FJ 13 MLB 99-02 15 Jun 99 ESSO Saf 2, rue des Martinets 92569 Rueil-Malmaison Cedex, France Plant: ESSO Raffinage S.A.F. Usines Lubrifiants de Port-Jerome/Gravenchon BP70 Notre-Dame-de-Gravenchon 76330 France Distributed by: Exxon Mobil Corp. 3225 Gallows Rd. Fairfax, VA 22037 1PWD8 Mobil Aero HF MLB 02-22 6 Aug 02 Distributed by: Exxon Mobil Corporation 3225 Gallows Road Fairfax, VA 22037 QPL-5606-31 8Y842 Technolube FB003 MLB 01-04 16 Jul 01 Lubricating Specialties Company Technolube Products Division 8015 Paramount Blvd Pico Rivera, CA 90660-4888 Plant: 3365 E. Slauson Ave. Vernon, CA 90058 F4101 Hydraunycoil FH 51 MLB 01-06 26 Sep 01 Nyco SA 66, Avenue Des Champs-Elysees 51, Rue de Ponthieu 75008 Paris France Plant: Societe Touraisienne de Produits Chimiques Z.I. de Tournai Ouest Rue de l'Ancienne Potence, 22 7503 Tournai Belgium 0HDS4 Petronomics Plus MLB 02-27 4 Sep 02 Distributed by: Petronomics Mfg. Group, Inc. P.O. Box 644 Hutchison, KS 67504-0644 07950 Royco 756 MLB 02-12 6 Mar 02 Royal Lubricants, Inc. P.O. Box 518 215 Merry Lane East Hanover NJ 07936-3920 3AD00 SENT-5606 MLB 00-10 3 Jan 01 Sentinel Canada Div SLC/LCLS 7300 Rue St-Jacques Montreal, Quebec H4B 1W1 Canada QPL-5606-31 KA832 AeroShell Fluid 41 MLB 02-19 29 May 02 Distributed by: Shell Aviation Ltd. Shell Centre York Road London SE1 7NA United Kingdom 04BH0 Chevron Aviation Hydraulic Fluid G Texaco Aircraft Hydraulic Oil 5606G MLB 02-36 26 Dec 02 MLB 02-37 26 Dec 02 Distributed by: ChevronTexaco Global Lubricants 6101 Bollinger Canyon Rd., T3066 San Ramon, CA 94583 04BH0 Chevron Aviation Hydraulic Fluid G MLB 02-36 26 Dec 02 Texaco Aircraft Hydraulic Oil 5606G MLB 02-37 26 Dec 02 Distributed by: ChevronTexaco Richmond Technology Center 100 Chevron Way Richmond, California, 94802
May 20, 2006
The basic spec is a highly refined mineral based light viscosity oil. I will let you know if there are any problems. OMC hydraulic fluid is approved for marine hydraulics, so I am guessing there are flame requirements to meet. Much like two stroke oil and engine oil, options exist. Would I use it in my hydraulics in my airplane? No, but my C-dory is not certified. nor is it going above sea level.
it has an iso viscosity level of 15 and is thin compared to most oils so it can flow at a colder temperature. This is needed for planes flying in the sky, where it's cooler.
Pressure busts pipes.
Page 3 of 3
Page generation time: 0.0291s (PHP: 61% - SQL: 39%) - SQL queries: 16 - GZIP disabled - Debug on
