Posted: Sat Nov 24, 2007 8:49 pm Post subject: Choosing Between Various Heaters and Stoves |
I ran across this source of links to a whole bunch of different stoves and heaters for boats that I thought I'd share with all of you.
While the Wallas is the Gold Standard of choice for factory installations in the C-Dory, lots of other choices exist for boats that came without one.
Take a look HERE. (A few of the links are dated and now non-existent, so be patient.)
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Sun Nov 25, 2007 12:02 pm Post subject: |
Thanks Joe...coulden't be at a better time for us.... Sue is retiring and we are going to be able to travel and use our boat much more this coming year.....we plan on buying a heater at the Seattle Boat Show this year.....probably end up with the Wallas.... like you said...it is the gold standard.
Joel
SEA3PO |
RichardW
Joined: 13 Oct 2005 Posts: 110 City/Region: Huntsville
State or Province: AL
Vessel Name: C Eagle
Photos: C Eagle
Posted: Sun Nov 25, 2007 6:04 pm Post subject: |
Joe
Thanks for the link to stove and heater alternatives.
One heater that might be considered is made by Espar. They make compact, efficient diesel fired heaters for trucks and marine applications.
Richard _________________ Richard and Cheryle Porter |
tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun Nov 25, 2007 7:45 pm Post subject: |
RichardW wrote: | Joe
Richard |
Same with Wabasto  |
Posted: Sun Nov 25, 2007 8:11 pm Post subject: |
You guys are right on with the Espar and Webasto!
Great heaters that burn diesel or kerosene.
Kinda like a shop heater, but with externally vented exhaust and a sophisticated forced air heat distribution system.
They're not cheap, running from $1400 on ebay to as much as $2600 retail.
The only concerns besides complexity and cost, is that they start at about 10,000 btus (as I remember), so are a bit overpowering on a 22 or smaller. They would wind up cycling on and off constantly in all but the most severe conditions.
The average gas cooking stove burner puts out about 6000 btus, which is about equal to a 1800 watt heater on the high setting. Here in California, at least, I find it necessary to have a setting of from 2000 to 3000 btus output, and that's sometimes too much!
However, sitting in your C-Dory in Fairbanks in the winter and wishin' you were salmon fishing the long summer days away with your dog(s), you might want the Big Torch style heater! Any single digit weather yet up there?
Joe.  |
Joined: 02 Nov 2003 Posts: 21504 City/Region: Pensacola
Posted: Sun Nov 25, 2007 9:21 pm Post subject: |
The Small Webasto 2000 is about 6000 BTU on high output. The Toyoset NS 2800 puts out 4900 to 9800 BTU. We used hydronics heaters (diesel fired, hot water circulation) in the larger boats.
For our use, the Wallas and several fans are fine in both the CD 25 and TC 255. One can always put insullation on the inside of the windows and decrease the heat loss during the evenings. We have always turned off the heaters when we went to bed and relied on blankets etc to keep warm. Who ever gets up first to walk the dog, turns on the heater. _________________ Bob Austin
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Mon Nov 26, 2007 2:46 am Post subject: |
Quote: | Who ever gets up first to walk the dog, turns on the heater | Brrrr... I think I'll sleep in. _________________ Pete
Posted: Mon Nov 26, 2007 5:18 am Post subject: |
Bob-
Thanks for looking up the specifications!
So that others can see them, here are links to these three heater types:
Webasto 2000ST
Toyoset NS 2700
Espar Airtronic 2
Morning Cheer!
Joe.  |
lloyds
Joined: 02 Aug 2005 Posts: 1724 City/Region: sublimity
Vessel Name: undecided
Posted: Mon Nov 26, 2007 11:49 am Post subject: |
You don't want the Espar. The cycling on and off will drive you nuts on a small boat. You need one that runs on low almost continuously, like your Webasto stove top. Quieter. |
dogon dory
Vessel Name: DogOnDory
Posted: Mon Nov 26, 2007 3:38 pm Post subject: |
Forty Two
Joined: 16 Nov 2004 Posts: 114 City/Region: Prince William Sound
C-Dory Year: 2017
Vessel Name: Black Cat
Photos: Barrel O Monkeys
Posted: Tue Nov 27, 2007 2:59 am Post subject: |
I installed a Webasto Airtop 2000 last spring. Now we use the Wallas for cooking and the Webasto for cabin heat. Both are fueled from the same tank. The Webasto fan is less noisy than the Wallas, and the Webasto has a thermostat. Also, I was able to install a couple of vents to defrost the windshield. These are the positives.
The negative is that the Webasto do-it-yourself installation kit comes with about a zillion little pieces, pitiful instructions, and no parts list. _________________ John & Susan |
siddfynch
C-Dory Year: 1983
C-Dory Model: 22 Classic
Vessel Name: XerxSeas
Photos: Xerxseas
Posted: Sat Oct 04, 2008 4:58 pm Post subject: Q about a stove |
Looks like this is the official thread for discussing different stoves?
I'd like to put an externally-vented heater in our 1983 Classic 22'. The cabin on these, as you know, is small. I'm sure a cooktop stove (which I also don;t have yet) would help with the heat, but am afraid it would cause too many condensation headaches.
So in lieu of that, I've been doing a web search on cabin heaters. The most inexpensive ones I can find (budget is an issue) are propane ones. Sig marine makes a Cozy Cabin (model 10000) that West marine sells for $434. Anyone have an experience with these? I could pay twice as much for a Dickinson, or move to diesel and pay even more. So I have two questions:
1) Would the Cozy Cabin be suitable for my size cabin in terms of heat output, etc.?
2) Is propane an inherently worse choice than another fuel?
Thanks! |
Dene
Vessel Name: Fear Naut & Terra-Sea-Ta
Posted: Sat Oct 04, 2008 5:28 pm Post subject: |
lloyds wrote: | You don't want the Espar. The cycling on and off will drive you nuts on a small boat. You need one that runs on low almost continuously, like your Webasto stove top. Quieter. |
Are you sure about the Espar? My new boat has it and I was very impressed on how quiet it is, compared to the Wallas. One thing though....it's out in the cockpit part of the engine compartment. When inside, all we hear inside is the fan.
-Greg |
Posted: Sat Oct 04, 2008 5:43 pm Post subject: |
This seems as good a place as any to insert a link to the Wallas factory recommended service: Wallas Recommended Service . Don't worry it's in English.
Also, a couple of years ago, an English catamaran organization posted a service guide for Wallas stoves. I thought I saved a copy, but can't find it. Anybody remember where or have a copy?
Boris |
Posted: Sat Oct 04, 2008 9:26 pm Post subject: |
Propane give about 92,000 BTU per gallon. This would be a little over 15 hours of heat per gallon of propane. You have to fit the propane bottle so that it is sealed off from the cockpit and vents overboard--probably converting one of the lazarettes to this function would work the best--but not sure what size propane bottle you can get in this space. I suspect that you can get a 10lb bottle [2.4 gallons] (horizontal) in one of those lockers. These are listed at $255 at West Marine. I have always used aluminum propane bottles in boats, because of corrosion--and availability of the horizontal bottles in steel painted bottles. Also to be ABYC compliant you will need a selenoid valve (and I feel that you also need a propane sniffer)--add in another $319. Not sure how long the hose is going to be, but figure with fittings that the cost will probably be about $5 a foot.
You probably will want some type of fan--to circulate the warm air--add another $40. So the cheaper heater, may not be as cheap as it seems.
Propane is a great fuel--I have used it on all of my cruising boats for almost 50 years. But you do have to have the shut off vavle, sniffer, proper installation etc. You do not want propane in the cabin or in the cockpit (propane is heavier than air and will pool in these places.). I have also personally seen two boat blow up with propane, and know of another two boats which were lost with propane, and have treated two people who had injuries from propane explosion--plus treated several others with CO poisoning from unvented heaters... so it is a fuel not to be taken lightly. Each individual has to decide if they want all of the safety features, or take a risk. I have always used the safety features with Propane, and for small boats felt that it was a bit of a hassel--thus the Wallas as a good alternative.
I happen to love the Wallas (mainly because I have been very lucky and had no problems with the three I have owned). It is vented to the outside, it has a fan, and it uses relitatively safe fuel. There are other kerosene/diesel heaters which might be a better choice (cost wise and only heaters) Toyo makes a boat heater, but I am not sure who carries them in the US. Taylor also makes diesel boat heaters, as does. Webasto used to make some small heaters (of course there is Hi seas and Dickenson). The problem with drip pot burners is that they can back draft, unless forced draft, such as the Wallas. |
