Closing off the anchor area on a 22 Cruiser
Hayesie Daze
Vessel Name: Hayesie Daze
Photos: Hayesie Daze
PostPosted: Tue Nov 04, 2008 8:30 pm    Post subject: Closing off the anchor area on a 22 Cruiser Reply with quote
Hello,
I was looking for some recommendations, solutions, etc. on how to close the exposed anchor area off in the v-berth. I would like to fabricate (or at least try to as painful as it may be) something like you see in the 25 cruiser with a hatch to access the chain/line. Thanks in advance.
Byron
mcc272
State or Province: CT
Vessel Name: C-Star
Photos: C-Star
PostPosted: Tue Nov 04, 2008 8:49 pm    Post subject: Reply with quote
I have been thinking of doing the same thing to my CD-22. Thinking that I might ultimately need to have relatively good access to the area for future repairs or to clean it, I am contemplating using epoxy to fasten wooden cleats to the hull and the underside of the deck and then screwing a bulkhead to the cleats. I would put a hatch in the new bulkhead that would be useful for untangling the anchor line but judging by the dimensions, I will be unable to have a hatch that is large enough for good maintenance access. Just a thought. I will be interested in seeing all the replies as I am sure that we will get some good ideas and advice.
Connecticut Side of LI Sound
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Tue Nov 04, 2008 8:53 pm    Post subject: Reply with quote
I cut me a piece of luan (or very thin plywood) and bolted it to the anchor locker bulkhead. I cut a hole for access to the anchor rode, used a removable cover from the pluming department to cover the hole...covered the whole mess with hull linner...gots a picture of it in the innerds photo album......just one of many solutions
Ken
1999 22' boaterhome
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Tue Nov 04, 2008 9:06 pm    Post subject: Reply with quote
I followed Ken's example, but with a bomar hatch for access.
PostPosted: Tue Nov 04, 2008 9:09 pm    Post subject: Reply with quote
For visualization help:
CD-25 stock set up:
B~C's set up on CD-22: (Cat Optional)
NOTE: Entire cabin interior has been sprayed with sound proofing insulation.
See: Pain free insulation solution
PostPosted: Tue Nov 04, 2008 9:18 pm    Post subject: Reply with quote
Another thought:
I like to see the rode come in and stack up as well as (but to a lesser degree) feed out through the windlass operation.
Perhaps a custom clear Lexan cover would accomplish this.
On the other hand, without a closed in bulkhead, the rode dries out a lot quicker, though you have to put up with some draft from the chain entrance hole and sometimes some smell from the rode.
A cover door could be easily enough opened and closed as needed, though.
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Nov 04, 2008 9:31 pm    Post subject: Reply with quote
I just used a simple piece of Sunbrella with snaps on the top and bottom. Keeps the odor out still allowing some ventilation.
marvin
Hayesie Daze
PostPosted: Tue Nov 04, 2008 9:53 pm    Post subject: Closing off the anchor area on a 22 Cruiser Reply with quote
Thank you all for sharing what you have done and the great ideas, I'll post pictures when I finish.
Byron
mpmccoy
City/Region: La Habra Heights
Vessel Name: Sea Queen
Photos: Sea Queen
PostPosted: Tue Nov 04, 2008 11:02 pm    Post subject: lexan Reply with quote
I used a piece of clear lexan. I have a windlass and I like to be able to see the rode. Mostly I wanted a splash guard and not have the three hundred feet I carry wonder all over the v-birth . With a few stainless screws the hole job took less than an hour. I didn't enclose the opening all the way to each side so I can get my hand in there if the rode were to foul.
Sea-Ya
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Wed Nov 05, 2008 1:26 am    Post subject: Reply with quote
After pulling the anchor from a very nasty smelling bottom and spending the night with that smell I did the same. I just used a piece of cushion or seat foam cut to approximate size and wedge in between the short bulkhead and the overhead.
Easy to remove and replace if needed but not as fancy as painted wood or lexan.
Steve
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Wed Nov 05, 2008 1:04 pm    Post subject: Reply with quote
I have two new lazaret hatch covers which I have not installed yet. Looks like the old lazaret hatches could be recycled for the anchor locker cover? There should be a lot of those available soon if they will fit.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Wed Nov 05, 2008 9:39 pm    Post subject: Reply with quote
I would prefer "floating" the divider (not a true bulkhead), from the underside of the deck and the lower part of the anchor locker bulkhead which is already glassed in. You can also use one of the round screw in inspection ports--8" diameter would be large enough to get the hands in and see what is going on.
If you want to completely seal this off (and I agree that you want to allow ventillation in this area), I probably would use foam along the sides of the hull, so that hull and can flex in this area, if it needs to. You don't want to have "hard spots" where bulkheads attatch to the hull.
teflonmom
City/Region: Red Lion
Vessel Name: Snickers AUG 08
PostPosted: Thu Nov 06, 2008 10:27 am    Post subject: Anchor Area Reply with quote
We had our canvas man make a canvas cover for the opening on our 22 footer. Our cat loved to get in there and smell the bay bottom mud left on the chain. Then we had two problems a smelly cat and the smell of the mud. The simple canvas cover helped a lot.
Fred, Pat, and Mr Grey(the cat)
Pat & Fred Messerly
PostPosted: Fri Nov 07, 2008 9:11 am    Post subject: Reply with quote
Sunbrella is very professional looking and breathes well.
Lots of materials can be used in this application, since no-ultra violet light deteriorates the fabric or material.
If you buy a snap kit to set the snaps in the material and mount them it the bulkhead with the complimentary screw heads, you have many choices of materials that will work.
With woven materials, a good sewing machine would make for nice boarders, though a utility knife, scissors, or hot knife might be a useful alternative for some others.
Ventilation can be adjusted by he number of snaps closed, or open, and even sold flexible plastic can used rather than woven fabrics.
Anyone with basket weaving, macrame, sheet metal, wood cabinetry, or some other skill can design their own hatch door.
The 10' x 24 Original Equipment internal cabin internal locker door in my Sea Ray v-berth is a polished metal mirror surface. But they're a kinky type of folk, as we all know.
How about an ultra thin TV/video screen for a high end solution?
Joe. Laughing
Page generation time: 0.0465s (PHP: 62% - SQL: 38%) - SQL queries: 27 - GZIP disabled - Debug on
