Isolating the outboards
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Tue Jun 23, 2009 6:26 pm    Post subject: Isolating the outboards Reply with quote
I have a 2 bank battery system with a combiner for charging. My 90 etec is isolated on the #1 battery. Almost everything else runs off the #2 house bank.
I have a 9.9 Johnson Kicker with e-start and 6A alternator. Can I just run it off the house side (so I don't have dueling alternators) or am I still running a risk to my electronics with the small alternator? Do I need a second switch for starting the kicker? Thank you,
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Jun 23, 2009 8:14 pm    Post subject: Bats Reply with quote
Perhaps I'm missing something, but do you have two bats connected to one selector switch? Meaning, can you choose 1, 2, or Both? If yes, I would always have the switch set to both so you're charging both bats while underway. When on the hook, switch over to your dedicated house bat.
Captain Matt
PostPosted: Tue Jun 23, 2009 9:12 pm    Post subject: Reply with quote
I don't think you'll have "dueling alternators" unless you have both engines running at the same time.
cemiii
City/Region: Alamo
PostPosted: Tue Jun 23, 2009 9:24 pm    Post subject: Reply with quote
Matt, yes, that is how it is set up, but I always leave it on 1. There is a Yandina battery combiner between the #1 and 2 banks so that (I am told, and seems to be so) both battery banks are being charged whenever the system senses a charging source, no matter what position the selector switch is in (even off, as with a home battery charger).
What I am more concerned about is the possibility of damage to the electronics if I start the kicker without turning the electronics off first. I read this somewhere and it has me concerned, though I have not had any problems yet. [one of the dangers of reading too much!]
Charlie, you are probably correct on the dueling thing, but I can't find any articles on duel set ups where they run them off 1 battery or 1 switch because apparently something bad can happen if an alternator does not sense a load. Though I don't normally run them together, there have been times in combat trolling conditions or being blown into shallow water, where I needed more power to get out of T, and did start the big motor before shutting the kicker down.
Chris
PostPosted: Tue Jun 23, 2009 9:34 pm    Post subject: Reply with quote
What usually happens, if you have your electronics on, when the voltage drops at a start, the electronics sometimes will kick off. My Garmin 545S shuts down but the Raymarine E-80, 4KW radar and Depth Sounder stay lit off... Depends on the sensitivity of the unit I guess.
Don't think you can damage the electronics in this situation, if you got a voltage surge, maybe but undervoltage, probably not.
Page generation time: 0.0376s (PHP: 64% - SQL: 36%) - SQL queries: 22 - GZIP disabled - Debug on
