New Seats for my 16 Angler
PostPosted: Fri Aug 28, 2009 8:26 pm    Post subject: New Seats for my 16 Angler Reply with quote
I want to replace the seats in the CAPTAIN'S KITTEN. One has a broken back on it and they are generally worn and weathered. What have folks used? I don't need but wouldn't mind armrests. She's a work in progress and I'm busily looking at pictures of the 16 interiors.
Also, what is behind the cockpit sides? Looks like it may be flotation, can't get to it but haven't tried too hard yet. Could it be opened up and have storage there like the 22?
A new adventure... Laughing
Steve Grover
City/Region: Lake Tahoe
C-Dory Model: 19 Angler
Vessel Name: Tee Ten
PostPosted: Fri Aug 28, 2009 9:18 pm    Post subject: New seats Reply with quote
I changed out the seats in Tee Ten. I have the original ( gray ) which I will give to anyone. Cabelas has seats with armrests as well as armrests you can add to some seats.
On my 2006 Cruiser when I added Scotty rod holders which required me to drill into the gunnels on each side, I discovered foam.
PostPosted: Fri Aug 28, 2009 9:31 pm    Post subject: Reply with quote
Thanks Steve. Probably cost more to ship seats than to buy new! I'll check Cabellas. Will be at SBS 10 and when Sally goes to Shipwreck Beads south of Tacoma, there's a Cabellas store right there where I go hide.
I suspected that about the cockpit sides, I'm sure others will chime in. I don't care about the flotation. unless it fills up with water.... Cry
16Pounder
City/Region: Gallipolis
State or Province: OH
C-Dory Year: 1990
Vessel Name: 16Pounder
Photos: 16Pounder
PostPosted: Fri Aug 28, 2009 10:31 pm    Post subject: Reply with quote
I replaced the seats in my boat with the Garelick EEZ-In Premium model. It's has much better padding than the seats that C-Dory put in my boat. If I have any gripe at all about these boats, it's the cheap seats they put in them. Everything else is top notch but those seats were like sitting on a board. The Premium seats are a little wider and mine just barely touch the motor control box when I spin it that way but I usually just spin it the other way. The Premium model is a huge improvement.
Al
J & C
C-Dory Year: 1994
Vessel Name: TBD - previously "Plain D"
PostPosted: Fri Aug 28, 2009 10:55 pm    Post subject: Reply with quote
Its foam in mine. I unscrewed the underpanel and pulled out the foam on the starboard side today to get at the cable steering so I could unfreeze it. It was in 3 pieces originally, it is in 5 now Embarassed as I broke it taking it out. Not all my fault as it had been "modified" with ? gasoline to fit a surface mounted rod holder. I calculated about 500# of bouyancy for both sides, that seems too little to float a C16 Angler avec motor unless there is a bunch more behind the bow bulkhead. I'm debating replacing it as it allows excellent access to all the controls and wire runs on that side of the boat.
Chris
Anne-B
City/Region: Suburban Philadelphia
C-Dory Year: 1992
Vessel Name: ANNE-B
Photos: ANNE-B
PostPosted: Sat Aug 29, 2009 10:19 am    Post subject: Captain's Kitten Reply with quote
Congratulations on the new addition to your fleet!!!!!!
Doug & Anne
ANNE-B
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Mon Aug 31, 2009 4:16 pm    Post subject: Reply with quote
FYI...............
I had a seat made by the original manuf. of the C-Dory seats prior to sale to Sea Sport.
The seats were excellent.
Ann's Upholstery
360-793-0504
Dave Wilson
riverat357@comcast.net
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page generation time: 0.0665s (PHP: 50% - SQL: 50%) - SQL queries: 24 - GZIP disabled - Debug on
