Bomar Hatch
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Thu Apr 22, 2010 4:23 pm    Post subject: Bomar Hatch Reply with quote
This may be a stupid question but how do you open the Bomar Hatch in the V-Berth. I undid the dogs and loosened all the knobs but it still will not open. Did not want to force it much. Thanks Tug
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Apr 22, 2010 4:28 pm    Post subject: Reply with quote
On C-Cakes I just rotate the latches so they are not blocking the hatch going up and unscrew the tensioning sleeves on the vertical supports, then push the hatch up and re-tension the sleeves. If your hatch has not been opened in some time it may just be that the rubber gasket is sticking to the frame and a little judicious use of a penetrant and a putty knife may help.
Patti and Barry
formerly C-Cakes, now
rving around N. America
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Thu Apr 22, 2010 4:30 pm    Post subject: OPEN SESAME Reply with quote
Sometimes the windows can stick if not used often.
Loosen the knobs then push against the window on the side farthest away from where the window 'shocks' meet on the side of the hatch.
I splashed this past weekend and your note reminds me to reapply some lubricant on my windows.
Captain Matt
PostPosted: Thu Apr 22, 2010 4:32 pm    Post subject: Reply with quote
You may have some corrosion around the hinges. If the dogs and the tube are loose, then it should open right up with a push toward the front--or pull up from the deck, on the aluminum frame. I like to use on the teflon lubricants--such as SuperLube spray. This acts as both a lubricant and cleaner. I spray it on the hinges, and into the tubes, as well as taking the knobs off the tubes, and spray into the thread holes.
Remember that the dogs have to completely clear the frame--and the knobs in the tubes completely loose.
Work it very easily--so that you don't break anything--and be sure that each piece is free, as you move it gently.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Apr 22, 2010 4:40 pm    Post subject: Reply with quote
You might try a hairdryer on the inside
Brent Barrett
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Thu Apr 22, 2010 4:59 pm    Post subject: Reply with quote
I will apply some lubricant today and let it sit over-nite. Thanks for the information. Tug
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Fri Apr 23, 2010 5:43 pm    Post subject: Reply with quote
The Bomar hatch is OPEN...after letting it sit overnite soaking ( lubricant ) and with the help of a putty knife it opened up kinda easily. Thanks Again.. Tug
Page generation time: 0.0281s (PHP: 63% - SQL: 37%) - SQL queries: 20 - GZIP disabled - Debug on
