Wallas light stays on
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Thu Apr 29, 2010 7:08 pm    Post subject: Wallas light stays on Reply with quote
I noticed yesterday that the light under the ceramic cooktop on my Wallas was staying on dimly even after the stove had cooled. In other words, the light is bright when the stove is operating, but never quite goes off. It dims, but stays on even 24 hours later.
I talked with Mike at Scanmarine. He did not have an explanation; he will check with the techs in Finland.
Any ideas from y'all?
The stove is 3 1/2 years old and functions just fine. It has only been fed Kleen-Heat...
Alok
PostPosted: Thu Apr 29, 2010 8:56 pm    Post subject: Reply with quote
Sounds like a little electrical "leak" or a ground problem. If in doubt, "if it ain't broke, don't fix it"
PostPosted: Thu Apr 29, 2010 9:20 pm    Post subject: Reply with quote
As I recollect that light indicates that the stove is "hot" and is activated by a thermal sensor. Is it possible that sensor has gone bad?
toyman
City/Region: Lake Livingston
Vessel Name: Fan-C-Dory
PostPosted: Thu Apr 29, 2010 10:06 pm    Post subject: Reply with quote
Charlie ! Haven't you heard - "if it ain't broke, fix it till it is" ! Very Happy
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
Alok
Photos: Top Cat
PostPosted: Thu Apr 29, 2010 10:51 pm    Post subject: Reply with quote
Bob: The light is bright while the cooktop is hot. About 20 minutes after switching off the stove, it goes dim- so it looks like the heat sensor is doing its job.
Charlie: Mike at Scanmarine, while not sure why the light would stay on, also suggested that it might be a ground problem. That makes two of you.
I will leave it alone since the stove works and the current draw should be negligible. If I fool around with it I might end up following Dave's advice!
PostPosted: Fri Apr 30, 2010 3:54 am    Post subject: Reply with quote
Dave, yes I have and every time I follow that advice, I regret it! Rolling Eyes
Page generation time: 0.0305s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
