Pat and Patty's Great New Galley Countertop Project
PostPosted: Mon Aug 30, 2010 10:00 am    Post subject: Pat and Patty's Great New Galley Countertop Project Reply with quote
Photos are here. Will write up details soon, but it DID involve power tools! Here is the final result:
You will notice the Wallas is NOT installed, it is working fine, but have not decided whether to put it back in or not.
PostPosted: Mon Aug 30, 2010 10:10 am    Post subject: Re: Pat and Patty's Great New Galley Countertop Project Reply with quote
Pat and Patty,
The results look great! I especially like the Formica counter top. I do wonder a bit about the tile back splash - it looks great but I am concerned that it make crack easily as tile and grout have no give at all and I think there may be flexing in that area when one drives over rough water.
Don and Brenda
City/Region: Camano Island, Wa
C-Dory Year: 2011
C-Dory Model: R-27 Tug
Photos: C-Quest
PostPosted: Mon Aug 30, 2010 10:11 am    Post subject: Reply with quote
Very nice work! Really brightens up the cooking area.
PostPosted: Mon Aug 30, 2010 10:14 am    Post subject: Reply with quote
Looks good, Pat! If you don't re-install the Wallas, what are you considering for heat?
The countertop really adds some warmth to the plain interior. Thumbs Up
Mike...
Photos: Accelerando
PostPosted: Mon Aug 30, 2010 10:21 am    Post subject: Reply with quote
That came out very nice. Why did you switch to a shallower sink?
Love the idea of a portable burner. Putting it away really gives you lots of usable counter space.
mike
PostPosted: Mon Aug 30, 2010 10:31 am    Post subject: Reply with quote
The Wallas MAY go back in, short term the Mr Heater Buddy works great (used it this weekend), long term Espar or Webasto would be my preference, but it is about the $$$.
Next up per Patty - we re-do the dinette to match. It was pretty easy actually, it is Wilsonart laminate over 3/4" plywood.
Roger - we will just have to see on the tile, it is glass tile not ceramic.
PostPosted: Mon Aug 30, 2010 10:36 am    Post subject: Reply with quote
The sink is shallower and moved a bit to the left to give more room below and turned 90 degrees to give more space behind. No need for the deep sink.
So far, big thumbs up on the GasOne butane stove.
mike
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Excellent job, nephew. Couple of comments:
Roger, I don't know if Pat's installer used it but there is a silicon grout product that remains slightly flexible after it's used. It's also far more stain resistant than typical grout and doesn't need sealing/resealing and constant grout cleaning. Expensive but worth it.
Back to you, Pat. Come on, fess up. Who did the sink cutout for you? If you did it all yourself, my sincere apologies and a huge congratulations for a job well done, especially without the loss of any appendages. I didn't know you even owned dangerous power tools....
Don
Mary & Don Anderson
Brat #483
PostPosted: Mon Aug 30, 2010 10:39 am    Post subject: Reply with quote
NEW GALLEY COUNTERTOP PROJECT
STEP ONE.
We cut a half sheet of ¾” plywood to 42” x 33” – the measured dimensions of the existing countertop in place (correct method would have been to pull sink and Wallas, remove the old countertop, remove trim, and then measure the old piece - my dimensions are NOT correct, we have a bit more gap on the head end than desired). We marked the rear side, put painter’s tape on the front side, and cut from the back side. Very clean cut. Then we cut a piece of Wilsonart laminate to the same size, and used Wilsonart contact cement to fasten the laminate to the plywood. Patty did an excellent job on the laminate, looks very good.
STEP TWO.
We removed the sink and the Wallas from the existing countertop, unscrewed the countertop from all the L brackets holding it in place, and removed it. There were some fasteners holding the cable bundle that we did not see, and inadvertently broke the rear brace. Will either glue it or replace it. Finally we carefully removed the existing teak molding pieces, they came off intact – they are held in place by a small bead of some kind of adhesive like 4200 and a couple of brads. We removed it by starting with a wide chisel very carefully tapped down between the molding and the plywood, and when we had it started, we used a long piece of angle aluminum tapped down to separate and pry it off. We sanded, stained and re-oiled the molding. It looks new.
STEP THREE.
Bought a nifty new sink, quite a bit shallower than the old one, carefully cut out the hole for it with a sabre saw, and put it in. The sink is now oriented the way most sinks are and was moved forward and to the left, giving us quite a bit more room behind and under the sink. It is held in place with some fasteners that ride in a channel on the underside of the sink and then screw down clamping tight to the underside of the countertop, very clever. This time we put the painter’s tape on the laminate, drilled a hole and cut through from the top side, also very clean cut. Put in the strainer and tailpiece with some putty, not sure we did this well enough. Put in the single handled Moen faucet. Reattached the molding. This part was harder than we thought it would be, but in the end, we got it “almost” right, it looks good as well.
STEP FOUR
Tried to replace the countertop, realized that there was one more cut to make on the right rear corner so the countertop could slide under the cabin wall. If I had used the old countertop as a template, I would have done this back in the garage, not in the boat! Made the cut, and replaced the countertop. Fastened it down with the L brackets. Reattached the sink drain and water supply lines, which are now re-routed along the back wall. With the shallower sink moved forward and to the left, the re-routing of the water supply lines and no Wallas, the area under the galley in now much more open and unobstructed. It is now sitting in place with no backsplash.
STEP FIVE
Now we need the backsplash. Patty attached some glass tile that nicely matches the Wilsonart laminate to a thin board I had cut to length for the backsplash. There is a double-stick product called SimpleMat tile setting mat that makes this much easier than using mortar. She glued the board in place and grouted the tile. Very good job, we are very pleased with the backsplash.
STEP SIX
The price paid for guessing at the measurement instead of using the old countertop as a template is that we are just a wee little bit off on the edge that sits against the wall of the head, and it is too wide to cover with caulking. We could put a molding here, but instead decide put the little Ikea wood storage containers that we used to have behind the sink along this side. The Wallas is not back in, but we are holding off on that decision for now.
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Mon Aug 30, 2010 11:02 am    Post subject: Reply with quote
Cool Job Pat & Patty
I love to see folks get out the drills and saws and make their boats into an extension of themselves. You did a great job and it appears Patty was very much in charge of this project which is most likely a very good thing. Smile
Now...guess we will have to have new drapes....
Mike Taylor
330-936-1030
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Aug 30, 2010 11:21 am    Post subject: Reply with quote
That's perfect, looks great. It is what I have planned for this winter. Now I know how, sort of.
PostPosted: Mon Aug 30, 2010 12:04 pm    Post subject: Reply with quote
Where is the new REC ROOM going?? Mr. Green
Great job both of you! Pat, guess the secret is to let Patty help!! Thumbs Up Hug
PostPosted: Mon Aug 30, 2010 2:59 pm    Post subject: Reply with quote
<stuff clipped>
Don
I'm aware of the silcon grout product and have even seen color matched silicon caulk. I'm hoping they used the flexible grout and if not, I'm hoping the board doesn't flex much. The glass tiles I had installed in my bathroom at home were actually glued to the wall with a silicone product but the grout was a non-sanded silconized grout the dries pretty rigid. When the installer did the slate tile around my jacuzzi tub, he used regular grout except for one tile section over an access panel. In this section he used a color matched silcone caulk so that it could easily be sliced out with a razor knife in the future. I can't see the difference between it and the regular grout. So Pat and Patty, if you have a problem with the grout cracking, you can always redo it with a flexible material.
PostPosted: Mon Aug 30, 2010 3:33 pm    Post subject: Reply with quote
Thanks, Uncle. I did indeed do the sink cutout all by myself. "Pat's installer" (Patty) will have to say what kind of grout she used, I just cut the backing board, she put the tile on it, grouted it and attached it to the boat.
Don
PostPosted: Mon Aug 30, 2010 4:17 pm    Post subject: Reply with quote
Pat - one more thing on laminate. Generally, one cuts the laminate oversize and glues it down. Then a special router bit is used to trim the laminate to size. The router bit has a roller on it that follows the edge and trims the laminate very precisely. I believe I still have such a bit for my router and could loan it and the router to you when you do the table. It's particularly useful for rounded corners. Also, if you laminate both the edges and the top, one does the laminate on the edges first and then applies the top. That way the top laminate overhangs the edge laminate and it doesn't catch when you slide something off the counter/table.
Page generation time: 0.0469s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
