Fire Extinguisher Location
bartender66
Vessel Name: Alaea
Photos: Alaea
PostPosted: Tue Feb 01, 2005 9:37 pm    Post subject: Fire Extinguisher Location Reply with quote
Hi All,
We purchased a new 22 Cruiser this past September and are still in the process of outfitting & customizing. I am looking for suggestions on where to hang the fire extinguisher. Any input would be appreciated. Thanks!
Terry
Luna C
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
PostPosted: Tue Feb 01, 2005 9:44 pm    Post subject: Reply with quote
I have mine just inside the door on the starboard side.
Now with Panthera 255 TC
katkt
C-Dory Model: 24 Tomcat
Vessel Name: Katie Kat
Photos: Katie Kat
PostPosted: Tue Feb 01, 2005 9:58 pm    Post subject: Reply with quote
Same as Luna C. It just fit on the right side of the
cabinet door a little below the counter top.
Its just inside the door and easily accessible
from the cockpit Smile
PostPosted: Tue Feb 01, 2005 9:59 pm    Post subject: Reply with quote
Ditto - it's out of the weather and as close as possible to the cockpit and the stove (the two most likely sources of fire).
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Tue Feb 01, 2005 11:36 pm    Post subject: Reply with quote
Same for me. And I have a second one in the port lazzerette.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Chivita
City/Region: Hansville
Vessel Name: Chivita
Photos: Chivita
PostPosted: Wed Feb 02, 2005 1:36 am    Post subject: Reply with quote
One to the right of the Captain's leg (while seated), one (big guy) above the water tank under the cushion of the chair across from the Wallas, one in the cockpit by the port lazzerette. This way I figure I have one nearby no matter where I'm at, having read about too many boats destroyed by fire.
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Wed Feb 02, 2005 7:18 am    Post subject: Reply with quote
My orginal mount was in front of the Captains seat (delaer installed) right leg. But it did not allow me to open the small compartment at the footrest. I moved and mounted the fire extinquiser on the instide wall in the cabin just above the door. I used a 1x4 piece of oak, stained it to match the other "woodwork", and used the mounting screws that hold the header above the door. It is secure, accessable, visable, and mid cabin. You won't hit your head on it and out of the way from hitting your knees. Wink
If you go to the Swee Pea album you will see what I did. It works for me.
Swee Pea
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Wed Feb 02, 2005 11:21 pm    Post subject: Reply with quote
Hey Swee Pea John,
How do you like the cobb bbq? I have seen it on the web and woundered how it works. Looks very useable on a C-Dory.
Steve
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Thu Feb 03, 2005 7:38 am    Post subject: Reply with quote
The Cobb grille works great. Just received the frypan and wok combo. In addtion, they came out with a special briquette that is clean and easy. In addition, it cooks cool to the touch, no open flame, no dripping grease. I even figured a way to mount it via a magma bbq holder.
Lastly, you can remove the grille and use it at home, on the beach, use it on trips, bake with it etc. And it doesn't cost an arm and a leg.
"Try it, you'll like it" Laughing
Swee Pea
bartender66
Vessel Name: Alaea
Photos: Alaea
PostPosted: Fri Feb 04, 2005 12:01 pm    Post subject: Reply with quote
Thanks everybody for all of the tips & ideas Smile Swee Pea, I just happen to have a piece of 1x4 oak in the basement! Did you buy an off the shelve stain, or did you mix your own?
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Tue Feb 08, 2005 1:05 pm    Post subject: Reply with quote
I used an off the shelf stain, but I don't remember the color. It may not be perfectly matched, but its close enough for government work. (no offense to government workers). If you have a router, you can sweeten up the edges. Good luck!
Swee Pea
chinook
City/Region: Swan Lake, Pengilly
State or Province: MN
Vessel Name: Chinook
Photos: Chinook
PostPosted: Tue Feb 08, 2005 1:25 pm    Post subject: Reply with quote
For a stain color, MinWax Natural Teak works well on white or red oak if you wipe it fairly soon after application. Has the right red tone.
Riverrat on Chinook
AnchortownJim
Vessel Name: Coho
Photos: Coho
PostPosted: Mon Feb 14, 2005 6:00 pm    Post subject: Reply with quote
Mine is located to the right of the door on the outside of the rear bulkhead, just below the window. Quick access in the middle of the boat if needed.
_____________
22' Cruiser Coho
jimandlaurie
City/Region: Puyallup
Photos: Laurna Jo
PostPosted: Tue Feb 15, 2005 7:29 pm    Post subject: Reply with quote
We put 2 on our 22. One just inside the cabin doorala some of the others here. But we also put one in the berth,agianst the wall on the port side.
Just a hint ,when you put them in mount them laying on their side. If they are mounted in a verticle position, the retardent will settle and cake on the bottom of the unit, and clog the feed tube and may not fire off without vigorous shaking.
Commodore Jim & Adm. Laurie
Former C-Dory Christener.
2004 C-Dory Skiff- Little Poit Dhubh
2005 C-Dory 25 Cruiser -sold 2103
2002- C-Dory 22 Cruiser- Sold 2005
bartender66
Vessel Name: Alaea
Photos: Alaea
PostPosted: Wed Feb 16, 2005 9:31 pm    Post subject: Reply with quote
Thanks everybody for all of the tips, advise, and suggestions! I appreciate it Wink
Page generation time: 0.0516s (PHP: 50% - SQL: 50%) - SQL queries: 28 - GZIP disabled - Debug on
