Up Gradeing our vee Berth Foam mattress
Jeff & Mimi
City/Region: Vancouver
Vessel Name: Kristen Rose
Photos: Kristen Rose
PostPosted: Sun May 29, 2011 10:23 pm    Post subject: Up Gradeing our vee Berth Foam mattress Reply with quote
Hi Folk's
We have up graded our vee berth foam rubber mattress with a new one cut to fit which is made out of memory foam. What I was wondering is if it would work better to just use the new mattress as a replacement by itself or put the new mattress on the bottom and put the old mattress on top and use both. Thank you for your Information in advance.
Jeff
Jeff, 1987 C-Dory 22FT. Angler The Kristen Rose
tomherrick
Guest
PostPosted: Sun May 29, 2011 10:42 pm    Post subject: Reply with quote
Sounds like a sea trials opportunity to me. As I get older I learn how differently we react to the forces that act on our no-longer-18 bodies. I'd certainly add an air circulating fabric below whatever you end up with to ensure that moisture doesn't build up between the mattress and V-berth platform.
Put 'em both together and try it for a weekend. If you're comfortable lying down and still have enough headroom, it sounds like you're gonna be a happy boat camper.
Good luck...
PostPosted: Sun May 29, 2011 11:30 pm    Post subject: Reply with quote
I believe that you would loose the effect of the memory foam if you put the old matress on top. If anything, I would put the old matress on the bottom. I have memory foam on top of all of my beds now. Some are topper pads (such as the Tom Cat and our RV.). The home matress is a Sleep Number with about 3" of memory foam on top.
Sam Walker
City/Region: Wherever the RV is today
State or Province: SD
PostPosted: Mon May 30, 2011 2:41 pm    Post subject: Reply with quote
I agree w/ Bob. Topper on top. I did that in one of our motorhomes. It worked out great. Thumbs Up
Sam on C's The Day or maybe Marinauty (Someday)
It does not matter how many moments that you take a breath, It is how many moments take your breath away.
Jeff & Mimi
PostPosted: Mon May 30, 2011 10:55 pm    Post subject: Reply with quote
I want to thank everyone for your input. I put the memory Foam on top of the original matterss today and crawled up in the vee barth and gave it about a hour and a half test and I think it is going to be very comfortable, I had a great nap..
Jeff
sweet pea
City/Region: Gulfport
State or Province: MS
C-Dory Year: 1998
Vessel Name: Sweet Pea (SOLD 10/2012)
Photos: Sweet Pea
PostPosted: Tue May 31, 2011 1:02 pm    Post subject: Reply with quote
I just replaced our entire mattress foam this weekend. I purchased a 4 inch King size memory foam mattress from Walmart. (2 inches true memory foam 2 inches open cell foam).
Took the old mattress out of the Sunbrella cover and used it as a template. After marking the pattern on the new foam, I used an electric filet knife (electric carving knife) to cut the foam. Very easy project for just under $150.00 and it feel GREAT!
Capt. Charles
Page generation time: 0.0502s (PHP: 49% - SQL: 51%) - SQL queries: 18 - GZIP disabled - Debug on
