Decragard or substitute?
Beflyguy
City/Region: Anderson Island
Vessel Name: Seven Please
Photos: Seven Please
PostPosted: Fri Sep 16, 2011 6:36 pm    Post subject: Decragard or substitute? Reply with quote
Does anyone know about any availability of decragard or a similar product? I would ideally like to match the interior of the Tomcat for a few modifications in 1/2" or 3/4" material.
Thanks
Brian
Seven Please
2009 TC255 2010 175 Suzukis
Anderson Island WA
PostPosted: Fri Sep 16, 2011 6:45 pm    Post subject: Reply with quote
Brian - Old Growth Dave had (has?) some decragard that he was willing to sell by the sheet to C-Brats. He has the pure white stuff which is a slightly different color than the slightly off white that the factory uses. I got a sheet from Dave and used it to make shelves within the cabinets and to make a shelf behind the aft dinette seat.
In the boats with the fiberglass interiors (like mine and yours), it's not so critical to have a perfect match to the decragard the factory used since it's only the cabinet doors and the counter top that are decragard. E.g. the places I put the pure white decragard are not directly adjacent to any off white material and without me telling you about the color difference, you wouldn't notice it (of course now that you know about it, it will stick out like a sore thumb). Also, I plan to replace the cabinet doors with wood at some point and probably will do formic on the counter top. At that point the only decragard you will see are my shelves.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Fri Sep 16, 2011 7:30 pm    Post subject: Reply with quote
I used the "white" formica available in Lowes or Home Depot on some projects. I picked up MDO plywood at the lumber store, and used contact cement to glue to formica to the face of the MDO.
MDO has a tan paper-like finish on the plywood, and is smooth on it's face. It's an extra step than Decragard, but easier to get (and could be done in a color to match the boat.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Fri Sep 16, 2011 8:34 pm    Post subject: Reply with quote
Brian – I have Decragard here in Olympia. It is ¾ inch 4 x 8 foot sheets. If you want some, send me an email and I will get back to you. We use it in the Marinaut so will generally have some in stock.
www.marinautboats.com
Beflyguy
PostPosted: Fri Sep 16, 2011 9:54 pm    Post subject: Reply with quote
Thanks guys.
Dave,
I will check with you when I can get down to Olympia.
Page generation time: 0.0276s (PHP: 59% - SQL: 41%) - SQL queries: 22 - GZIP disabled - Debug on
