Props
Juanasi
City/Region: Happy valley goose bay
State or Province: NL
C-Dory Year: 2011
PostPosted: Wed Aug 06, 2014 9:48 pm    Post subject: Props Reply with quote
What size stainless props would i need for twin 60 high thrusts on the 23 venture c-dory?
PostPosted: Wed Aug 06, 2014 10:13 pm    Post subject: Re: Props Reply with quote
Welcome, Juanasi Thumbs Up
Are you in Newfoundland? If so, wow, pretty country.
Edited to add: I had to look it up. Wow, look at all that water around you Shocked It must be amazing! I hope you will share some of your local boating experiences with us.
Perhaps someone knows specifically (same boat/engines/loading/altitude), but here are a few questions for you. The answers to these questions will help people here to make good suggestions.
I realize you may not have tested these things out yet, but they really do help in figuring out how to prop.
1) What size props do you have on now, and what material?
2) What is your current RPM at WOT (wide open throttle)
3) What altitude did you test them at for WOT, and is it the same altitude you plan to run at?
4) What loading did you test them at for WOT(heavy boat or light boat) and is that typical for how you run?
5) What is the recommended WOT RPM range for your engine(s)? (In the owner's manual, typically.)
The props sort of act as transmissions (gears) on your outboards, and it basically revolves around what RPM you can achieve at WOT as compared to mfgr's recommendations (then you tweak from there, as necessary). If you haven't tested them at WOT, it would be good information to obtain.
Even if you never run at WOT, if you don't make the recommended RPM at WOT it's bad for your engines at all speeds (not just at WOT). Sort of like lugging a car (accelerating when in too high a gear).
Again, welcome Beer
Tom on Icarus
City/Region: Campbell River, Vancouver Island
Vessel Name: Tranquil~C
Photos: Tranquil~C
PostPosted: Thu Aug 07, 2014 11:29 am    Post subject: Reply with quote
Welcome Juanasi
Labrador is incredible. I have fly fished on the upper Eagle River when my Dad was a founding member of Camp 1155 there. Beautiful!
Sorry I don't have any answer to your prop question but I'm sure someone here will.
Cheers
Tom
22 Cruiser "Icarus" 2005 - 2011
25 Cruiser "Tranquil~C" 2011 - 2019
30 Commander (to be named) 2019 -
Page generation time: 0.0401s (PHP: 41% - SQL: 59%) - SQL queries: 20 - GZIP disabled - Debug on
