Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu May 14, 2015 12:40 pm Post subject: Electric Over Hydraulic - Needed????? |
When we bought our new truck, and came screaming into the age of neat things like tow-haul features, I've been wondering if I should change the trailer over to EOH, or just plan on replacing pads on the surge brakes every now and then. I am not sure where the ROI point is for EOH, versus more maintenance.
Anyone out there with surge hydraulics and using tow haul for braking? Are you seeing excessive brake wear or heating of the disks/drums (We have disks)?
Even though I would like to have EOH, I am not sure it's worth it from a cost perspective.
Your thoughts???? _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Thu May 14, 2015 1:06 pm Post subject: |
Hi Steve-I'm not sure this qualifies as "thoughts", probably more like "feelings".
Just from being a C-Brat junkie for so many years and reading probably each and every post, I suggest that you should get the EOH brakes.
 _________________ MartyP
Mike_J
Joined: 26 Mar 2012 Posts: 373 City/Region: Victoria, BC
C-Dory Year: 2011
Vessel Name: Natural C-lection
Photos: Natural C-lection
Posted: Thu May 14, 2015 1:50 pm Post subject: |
I switched to EOH, mostly because they made me feel more confident about the braking and have been very happy with the result. _________________ Mike and Monica Jackson, Victoria, BC
http://naturalc-lection.blogspot.ca/ |
Posted: Thu May 14, 2015 2:27 pm Post subject: |
I'd say that EOH are not needed for a 22 with good tow vehicle and a well-maintained surge braking system, combined with appropriate driving. I've been towing my 22 with surge brakes for awhile now, including plenty of mountain passes, curvy highway driving, etc. Both of my tow vehicles (3/4 ton and 1 ton van rigs) have stopped better with the trailer hooked up than without it, thanks to the tandem/disc/surge trailer brakes (not that I have ever had different brakes on the trailer).
That said, I do need to be aware of the surge brakes when coming down mountain grades. I can't just "throw on" the brakes willy-nilly, because they may not release again, which could cause them to heat up, work less well, and/or become damaged. I typically use engine braking the whole way down anyway. I will use the brakes to slow down ahead of the downgrade (when I know they will still release because I can still "power" forward), but then move to engine braking for the body of the grade.
I suppose that I go a bit slower at the tops of grades than I would/could with EOH brakes, because with those I would know I could increase my braking during the downgrade. It's okay for me because I don't feel like I need to go a whole lot faster (and I am not going down slowly enough to be a hazard - still usually a bit faster than big trucks).
Still, EOH would be a nice feature. I was actually set on getting them before I first towed, but then the shop was totally unfamiliar with them (Florida) so I decided to wait until I got to the west coast -- but by then I felt fine with the surge brakes, so I have stuck with them. So for me now I would say they are a "desire" for a good tow rig with a 22, and would certainly be appreciated, but are not a necessity. I'm sure if I had a 25 I'd want them as a baseline.
That said, one can always make a tow rig better (even bigger truck, better brakes, more redundancy, etc.), but I guess eventually most folks decide that a certain rig/features work well and safely and are a good balance. One thing I like about the 22 (vs. something bigger) is that it's just at that point (for me) where I can do a a lot with it, but can also keep it simple (have had more complicated boats in the past, and they can be fun too, but I'm enjoying this stage now).
PS: I don't have the "tow/haul" transmission (I have a beefed up 4R100), but I basically do the same thing on downgrades but just "manually." |
BrentB
Joined: 15 Jul 2006 Posts: 4420 City/Region: Greenwood
State or Province: IN
Photos: BrentB
Posted: Thu May 14, 2015 3:10 pm Post subject: |
here is an article
To a lot of people, the idea of using anything with the word "electric" in the water is a non-starter. But electric over hydraulic brakes on boat trailers are now an option on models built by EZ Loader, Magic Tilt, Pacific Trailers, and Loadmaster, to name just a few.
Like a purely hydraulic system, an electric over hydraulic (EOH) braking system is activated whenever the tow vehicle brakes are applied and the trailer surges forward. Unlike the older system, however, the EOH actuator is electric, so the trailer’s brakes are applied instantly, with almost no lag time.
"Electric over hydraulic brakes have the same hydraulic brake lines going to them," says EZ Loader's Rick Norman, whose company also offers electric drum brakes, "but instead of ending up on the forward end of the trailer with the familiar hydraulic actuator, they end up with a motor on the actuator that's powered by electricity from the tow vehicle. The result produces the necessary hydraulic pressure to activate the brakes." Depending on the brand you buy, an electric over hydraulic system is available for either disc or drum brakes. Like surge, there's an actuator designed for either, but be aware that 1,000 psi on an EOH brake system is used for hydraulic drum brakes while a higher 1,500 psi is used for disc brakes. Conventional surge brakes use a lower psi (400-800) but most brake lines can handle the higher pressure. And if you're leaning toward EOH, this is a question you need answered: Is the brake line burst strength strong enough for the increased pounds per square inch of brake fluid moving through the system? Federal law also requires a breakaway kit, including battery, installed on any trailer with EOH brakes so that the trailer brakes will activate in the event it becomes separated from the tow vehicle. Trailers with the standard surge brakes use a breakaway cable to do the same, should a separation occur.
Water and EOH
"You can't get the electric over hydraulic actuator wet," observes Trailering Club member Jim Favors, who has pulled his Ranger 27 tug from Washington state to Florida and back home to Michigan. "That's why the actuator is placed as far up the front of the trailer as possible. I have my wife Lisa stand outside when we back the trailer down the ramp to let me know when to stop."
This doesn't mean the actuator on an EOH system should be kept out of the rain. It's built to handle heavy weather while on the road, but manufacturers ask that it not be submerged at the boat ramp. Of course, in these days of power washes at boat ramps to remove any invasives (quagga or zebra mussels, to name two), boaters have expressed concern about using a high-pressure hose on a trailer with electric over hydraulic brakes. Since these actuators aren't designed to be submersible though the housing is weather-tight, most will tell you light rinsing is fine. As for power washing, avoiding the actuator altogether makes sense because it's not supposed to be in the water.
Brake manufacturers suggest using electric over hydraulic if the boat being pulled exceeds 3,500 pounds. This becomes all the more important when one considers that a boat that size being backed down a boat ramp with the conventional surge system is using only the tow vehicle brakes. Most of the time, it's not an issue, but as the boat gets heavier, more strain is put on the tow vehicle brakes. EOH uses both tow vehicle and trailer brakes when the boat is backed onto the ramp.
the rest at
http://www.boatus.com/magazine/trailering/2013/february/electric-over-hydraulic-brakes.asp
maybe this will help _________________ Brent Barrett |
williwaw
Vessel Name: Williwaw
Photos: Williwaw
Posted: Thu May 14, 2015 5:20 pm Post subject: |
I recently installed EoH on my EZLoader trailer and can affirm that the improvement in braking response is significant. I like, for example, that my brakes are applied backing down the ramp and that I can lightly touch the brakes in traffic and feel the trailer respond instantly.
But is it required? Clearly not as lots of people tow with surge brakes. Is EoH safer on trailers weighing several thousand pounds? No doubt it is but whether the extra margin of safety over surge brakes is important is a personal decision.
From a strictly financial standpoint, lots of these safety related things have a bad ROI (like zero) unless you need them. It's just about your tolerance for risk. |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Thu May 14, 2015 5:30 pm Post subject: |
When I got the "new" trailer, it had no brakes on it. I have been towing this C Dory on a single axle trailer with surge disc brakes, and they were effective, but I know that the boat was back there, when stopping. I would question the "stopping better than vehicle alone"--that depends on a lot of factors. There is always a slight delay when the trailer brakes apply.
I use engine compression-both on the diesel truck, the RV (which has a transmission retarder and an exhaust brake) I only touch the service brakes when coming to a complete stop, and don't use the service brake often on a steep down grade. But these do set up the surge brakes for potential over heating. I did have this happen in Idaho a couple of years ago with the 25. Normally I check the hub and disc temps after a long down grade, but didn't because there was no easy place to pull over. I fried a bearing set doing this. So this put me on the path of E/H for the "new brakes" even on the C Dory 22.
As for speed for starting down steep grades. There is a manta in the RV world, don't start downhill any faster than you you were able to pull up to the top. Many times this may be 35 mph. This gives you a lot of cushion, and avoids over heating any brakes. Many times you will see signs for "trucks" 35 mph down grade speed limit on long grades.
So, now I have Electric over hydraulic on the 22 trailer. It was a few hundred dollars more than the surge, but I believe worth it. _________________ Bob Austin
Posted: Thu May 14, 2015 7:20 pm Post subject: |
I towed a 22' sailboat for years, even down in Mexico, without brakes. So any trailer brakes are just wonderful, whatever the actuation.
For surge brakes, the actuator uses force from the trailer to apply the brakes. When one is slowing down the force comes from the trailer inertia (force = mass X acceleration). When you're going downhill, the force comes from the weight of the trailer (weight * sine of the downhill angle). The former is what you want, the latter is good in that it slows down the trailer, though it can be hard on the brakes. And, of course, when you back up the trailer the force against the surge actuator is coming from the truck, and you don't want that so a back-up lock out is provided. All of this is independent of the trucks braking system/mechanics. Anyway you slow down the truck, such as shifting down or the brakes, hitting a stone wall, applies the trailer surge brakes as does going downhill and backing up.
On the other hand, an EOH uses a hydraulic pump to generate the hydraulic pressure to apply the trailer brakes. And that pump is controlled by the amount you step on the trucks brakes via a electric controller. So, you have better control over the trailer brakes and if you've got disk brakes you can (probably) apply more pressure to them. All this comes for the princely sum of $600 plus installation and a truck controller.
Now, Journey On is a 25 and on the trailer weighs between 8000 to 9000#. I got EOH and have never regretted that. However a 22 weighs about 1/2 of that and for the cost and hassle of installation, I would not spend the money. But, I wouldn't argue with anybody that has, since it gives better control of the trailer. And if you don't have a truck, but you're trying to tow it with a smaller SUV, you might want EOH. I used surge brakes for years and yes I replaced pads, shoes, etc, but everything worked well.
Your choice.
Boris |
Joined: 01 Mar 2005 Posts: 7485 City/Region: from island boy to desert dweller
Posted: Thu May 14, 2015 7:39 pm Post subject: |
Hi Steve,
You have electric brakes on your Airstream, I imagine. Most travel trailers of any size have 'em. We had the stock surge brakes on our CD-25 originally - the change to electric over hydraulic was significantly better.
I am not a fan of surge brakes on any downhill stretch - engine braking on your tow vehicle will have the surge brakes engaged... all the way down the hill.
Just like having an anchor that you can be comfortable with overnight, having trailer brakes that work when you want, and don't engage when you don't want it, will make your trailering more pleasant and safer.
Jim |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1051 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Thu May 14, 2015 8:16 pm Post subject: EOH/direcLink |
We traded in the old EZLoader in Dec for a Marc Grove (Wefings)/Bob Austin clone aluminum Float-On, except with EOH brakes for the TC255. Love 'em. What really makes this package elegant, though, is the DirecLink cab brake controller (SN # 00000049, I must be an early adopter or a Beta tester). www.direclink.com
The DirecLink in cab controller just plugs into the truck's OBD port (I did it myself), identifies the ECM, shakes hands, and displays a green "OK" on the display to show they are playing nicely together (a red 'NC' if the trailer is not connected). Now the controller knows when the truck is backing uphill, or in engine braking mode going downhill, and the trailer brakes stay off. You have an option to have the trailer brakes stay on (adjustable) when stopped at a red light, or on the ramp. All braking is proportional to pedal pressure, not full-on or full-off feeling like surge brakes. They release immediately, not just when the truck starts to pull on them. When a regular stop becomes a panic stop, or the truck's ABS brake mode is activated, the trailer brakes are told instantly what to do. You can activate trailer brakes only and proportionally with the display trigger when going down steep hills. Unlike any other controller, this one sounds an alarm and gives a DIGITAL readout of your transmission oil temp if high (GM and Ford only). How cool is that? Even my dashboard tranny oil temp gauge doesn't do that.
Surge brakes are adequate for this and most parts of the country. However, I contend (and agree with Sunbeam) that if you're dragging over 8- 10,000 pounds (mine is 11,500 in cruise mode and over 18,000# total rig) you need every extra safety margin you can afford. The EOH option was only an extra 1 to 1.5 Boat Units (I forget) on this trailer. The EOH/DirecLink combination is a high-tech, elegant and automated solution that makes my trailering smoother, less stressful and it's a bargain. I'd never go back to those clunky, jerky, beastly, primitive, stupid, inertia-dependent knuckle-dragging Neanderthal foul-smelling surge brakes (although Sunbeam seems to like his OK for a 22). Best thing since installing the backup camera and turn signal activated mirror-mounted side blind spot cameras. (The Blonde will let me buy almost any boating boy toy I want, as long as I can convince her it's safety related. Maybe that'll work with your Blonde, too).
Once purchased, I don't anticipate any difference in maintenance, other than a cheap rechargeable battery on EOH required as Brent posted for breakaway activation. On my GMC 2500HD diesel (Allison commercial transmission and 20k Park prawl), Tow/Haul mode lowers the RPM for upshifts and locks out overdrive; engine braking going down hills never seemed to activate my trailer surge brakes around here, but I might not know until they overheated enough to set off the valve stem mounted tire pressure/temp alarms. More of an issue in real Western mountains and our post-retirement life.
Have fun researching! Dr. Bob has forgotten more than I'll ever learn about this stuff, I'd listen to him!
Cheers!
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2 |
Larry Patrick
Vessel Name: Sea -Jo
Posted: Thu May 14, 2015 8:30 pm Post subject: |
Just towed first time with EOH,last trailer had surge breaks they were good with 19ft Montauk. Really like this trailer,I almost forget the boat is back there. |
Posted: Thu May 14, 2015 8:46 pm Post subject: |
thataway wrote: | I would question the "stopping better than vehicle alone"--that depends on a lot of factors. There is always a slight delay when the trailer brakes apply. |
Okay, I'll take that back. It feels that way to me (tandem trailer, all four wheels disc-braked), but I have done no scientific experiments, and don't want to lead anyone astray. I'm sure you have much more towing experience than I have. Aside from a few rafting trailers (no brakes), and couple of brief cross-country jaunts with travel trailers, I only have experience towing the C-Dory, and that only with two different tow vehicles. I shouldn't have spoken categorically (if it sounded like I was). |
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
Posted: Thu May 14, 2015 10:05 pm Post subject: eoh |
Sunbeam,
You're really not going to take the bait on 'foul-smelling'? I'm so disappointed! You are one tough fish to 'catch'. Appreciate your posts and experience.
Keep swimming!
Cheers!
John |
Posted: Thu May 14, 2015 10:24 pm Post subject: Re: eoh |
gulfcoast john wrote: | Sunbeam,
You're really not going to take the bait on 'foul-smelling'? I'm so disappointed! |
Well, that was just so over-the-top that there was no need
I'm sure I would like EOH - they sound fantastic - and if I ever decide an upgrade is in order, that's the way I'd go. But my surge brakes have been pretty well-mannered, so for now they stay.
Side topic: I'm so annoyed. I found a particular trailer tire I wanted (mine are three years old, so from what I read it's time for new ones) and called to see what the date code would be on the ones they had in stock. They were over a year old! However a new batch was coming in.... I called back after they'd been unpacked and... same date! Called another place that had them and theirs were even older. I mean, if I'm replacing them every three years that's like 35% gone before I even get started. Sheez.
The second place advised that they get a new batch in every week (using the term "new" loosely here, obviously), so I'm going to try back a few times and see if I have any luck. Reason I want these specific tires is that I have 13" wheels on my trailer, and with the typical Load Range C tires, I'm not over their rating, but closer than I would like. This one particular tire I seek is a Load Range D 13" tire.
(I looked into changing to 14" rims, but it's more complicated than that and much of the trailer/suspension would have to be replaced too. I haven't had any trouble with the Load Range C tires, and the whole rig trailers quite nicely, but I still want those Load Range D tires!
Okay, that's the side rant over  |
JayMac
Vessel Name: Sundance
Photos: Sundance
Posted: Fri May 15, 2015 8:02 am Post subject: Brakes or not |
I recently bought a used 16 cruiser with trailer, and it has electric brakes (2003)
Do I really need the brakes on a 16 foot boat?
Two options
1 have them rebuilt (brakes)
2 remove internal parts (no brakes)
What do you guys think that tow 16's ? |
