shrimping
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Wed Jun 24, 2015 6:24 pm    Post subject: shrimping Reply with quote
the WDFW gave us a 4 hour window of an opening to shrimp in area 8-1 & 8-2 today.
Byrd and I went out and got 6 shy of our limits .here is a pic of me pulling a pot.
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Wed Jun 24, 2015 7:47 pm    Post subject: Reply with quote
We really need a "like button" on here!
That's great Roger and Byrdman, I'm really jealous and had to work today.
You were right about those stacking net pots from our local dealer. The Honda gas puller would pull so hard the shrimp fall right through the netting on the way up. I could see them falling out as the pot gets close to the surface. Angry I switched to different pots and we're killing it now.
PostPosted: Thu Jun 25, 2015 12:01 am    Post subject: Reply with quote
yep it was a ok day. Susan and I played hooky and got a limit and a half. Friend tracy got two full limits to his boat.
PostPosted: Thu Jun 25, 2015 5:52 pm    Post subject: Reply with quote
I'm out of town but Joyce and I pulled about 7 limits in the San Juan's over a couple of weekends earlier this month. We are well stocked on shrimp for now.
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Thu Jun 25, 2015 6:05 pm    Post subject: Reply with quote
Oh, the great memories of shared times, Roger!
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Fri Jun 26, 2015 1:31 am    Post subject: Reply with quote
Thumbs Up Thumbs Up
Larry H
A C-Brat since Nov 1, 2003
tcr_pnw
City/Region: Puget Sound
Vessel Name: Sea Star
Photos: Sea Star
PostPosted: Fri Jun 26, 2015 3:54 pm    Post subject: Reply with quote
Fun stuff!
We pulled our limits plus a few that went back off Mukilteo. Nice to have the bonus day! Gotta get the lay of the SJ's and pull a few more during those bump tides before the season closes.
SENSEI
Vessel Name: SENSEI
PostPosted: Wed Jul 01, 2015 2:14 am    Post subject: Reply with quote
we went out to area 6 this last week several times and were able to fill limits every day. here is a pic of Byrd and a close friend with a couple of the bounty
and here is a pic of one four pot pull. we had just shy of 5 limits in the tub
SENSEI
Vessel Name: SENSEI
PostPosted: Fri Jul 10, 2015 2:45 am    Post subject: Reply with quote
we went out to area 6 today and were able to put 4 more limits of spots in the cooler.
it was a little harder today, took 4 sets of the pots at one hour soaks. persistence paid off ....lol.....
PostPosted: Fri Jul 10, 2015 11:24 am    Post subject: Reply with quote
Is that the stop I shrimped with you last year? what are the good tides? and which current station do you look at? Might go out sunday.
Pulled three limits of crab yesterday
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Fri Jul 10, 2015 11:26 am    Post subject: Reply with quote
Wow !....Just Wow! What a neat thing.... I have kinda given up on Fishing.. and not catching ..... but Wow that looks like fun... Roger (C-Hawk) each bought 6 lobster traps and were going to try that down here in Southern California....but then darn ole Roger got a job in Oregon.... (wherever that is) and so we have not ever tired it... I wanted to try out by Catalina this year... but without ole Roger it would be no fun...
I am really impressed with yer haul... and shrimp too ! Wow !
Joel
Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
PostPosted: Tue Jul 14, 2015 11:20 am    Post subject: Reply with quote
for MA6 curious what weight your using and floatation. had no problem last year with ladner pots but lost 3 pots this year and found one 2 miles from where i set it..
PostPosted: Tue Jul 14, 2015 12:24 pm    Post subject: Reply with quote
I'm using the smaller (30"), weighted Ladner pots with no additional weights and a couple of the collapsible wire ones (Danielson) with about 10-15# of lead in them. For floats, I use two of the standard foam floats on a piece of plastic pipe + a big orange scotsman buoy on a trailing line. On bigger exchanges, I may add a couple more floats on a trailer line also. I try to set at site where there is a bit of a back eddy on the larger exchanges so that the local current is reduced. Setting 2 pots on one set of floats also helps keep them in place. Another trick is to put a 10-15# down rigger ball on the line about 15' up from the traps. This reduces the vibration of the line against the pot in the current and increases the catch. It also helps keep the pot from moving.
SENSEI
Vessel Name: SENSEI
PostPosted: Tue Jul 14, 2015 12:39 pm    Post subject: Reply with quote
we try to watch the tidal action and only set when there is less than 2 foot of change from high to low. we start about 1/2 hour before high and work the outgoing tide till low slack. we sometimes will use an 3 lb anchor on about 4 ft of line attached to the pot.
our shrimp pots weigh in at about 27 lbs
we use the ladner style pots with the stainless frame. we use a 3/4 inch polly water pipe cut to the same circumference as the bottom of the pot. we fill it with lead shot and use a plastic ribbed coupling to make the circle. we then tie with zip ties to the bottom ring of the pot
PaulNBriannaLynn
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Jul 14, 2015 12:56 pm    Post subject: Reply with quote
Were using SMI square pots weighted with rebar to 36 lbs, and rubber inflatable polyform LD-2 buoys. The buoys are low drag, but big enough to float the pot if the current takes it.
That's totally overkill for Puget sound, but seems to do the trick where we go. Lots of water to move around. We also time it with the tides and only pick days with very little tide change. That makes a big difference.
Our last trip to area 7, we had our 3 limits in the first 3 pots and had to rail dump the last pot. Good times!
Page generation time: 0.0426s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
