Inflatable Dingy Repair
PostPosted: Fri Jan 15, 2016 3:57 pm    Post subject: Inflatable Dingy Repair Reply with quote
I have an Alaskan(sort of) Inflatable and I need to get some repair done on it. It has an Air Floor, and when it is pumped up hard it is great, but it is leaking and I can’t tell if it is the valve or the seal around the valve where it is leaking from. I’m thinking of taking it in for some repair and wonder if….
Has anyone had any experience with Ballard Inflatable Boats in Seattle?
Service or otherwise? New, used or other? How was it?
PostPosted: Fri Jan 15, 2016 6:37 pm    Post subject: Reply with quote
I have heard good things about Ballard Inflatable boats.
Have you filled it with water or used soapy solution to look for the place where it is leaking? Is this an 11PSI drop stitch air floor, or lower pressure rolls, type? Is this a Hypalon or a Decitex boat? Bonding agents are different for the different materials.
PostPosted: Sat Jan 16, 2016 3:32 am    Post subject: Reply with quote
I have tried the soapy water and have narrowed it to either the valve itself or where the valve is glued into the floor material. And honestly, I don't remember if it is Decitex specifically, or not, but it is the same as the Alaska Series so i believe it is. The floor is a high pressure floor, but i don't know the pressure listing.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Sat Jan 16, 2016 12:21 pm    Post subject: Reply with quote
If you get into the portland area the Inflatable Boat Center is pretty competent as well.
PostPosted: Sat Jan 16, 2016 1:19 pm    Post subject: Reply with quote
I do, and I will look them up. Thank you.
Page generation time: 0.0417s (PHP: 63% - SQL: 37%) - SQL queries: 18 - GZIP disabled - Debug on
