Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
Posted: Tue Feb 16, 2016 11:41 am Post subject: cabin door seperating |
So went out to check on the boat after being parked for the majority of fall and winter. Noticed the bottom of door looks to have swelled and started delaminating going up the door towards the door knob. Does anyone know if these wood doors repair well or should I start looking for a replacement? It looks like I could fill with some epoxy and c clamp it back but I think this is only a patch job and the water damage has been done. Plus it’s a 89 model. Any ideas for replacements would be appreciated.
Thanks |
Joined: 02 Nov 2003 Posts: 21499 City/Region: Pensacola
Posted: Tue Feb 16, 2016 1:34 pm Post subject: |
Temporary is best to inject with epoxy, as you noted, clamp--probably put wood batons on each side, and then multiple clamps on the wood, to avoid marking the surface. Be sure and seal all of the edges of the door. It may last some time.
Some of the newer boats have "Starboard" doors They tend to warp to some degree, but are impervious to water damage. _________________ Bob Austin
tbag
Vessel Name: TBA
Photos: tbag
Posted: Tue Feb 16, 2016 3:12 pm Post subject: |
I have 89 and I am sure the door has been replaced or glued and repainted white. I will try and investigate and take some pics... |
Joined: 07 Nov 2003 Posts: 7937 City/Region: marysville
Posted: Tue Feb 16, 2016 3:46 pm Post subject: |
Building an new door is not that hard. I just used good marine ply and sealed it really well with 8 coats of paint on the out side and a stain on the inside. I removed the old window and used it on the new door. I am not a wood worker and used basic tools. If I can do it anyone can. _________________ Thomas J Elliott
Posted: Wed Feb 17, 2016 2:30 am Post subject: |
M y 05 has a Starboard door. It's not perfect, but I think it beats the full length glass door. I guess that could be a personal choice, but I don't think my starboard has warped .... yet.
SleepyC
capt. meares
Joined: 04 Jul 2013 Posts: 146 City/Region: Tillamook
C-Dory Year: 1988
Vessel Name: Vianey
Photos: Vianey
Posted: Wed Feb 17, 2016 6:48 pm Post subject: |
Exactly what StarCraft Tom said....It would be just as easy to build a new door than mess with all that repair epoxy c-clamp mess. Buy one sheet of 5/8 Marine Plywood & 1 piece of Oak screen molding for the edge, use old door as template, cut, sand, and stain and you have a better than new factory C-Dory door from 1989. |
Jake B
Vessel Name: PLUS 3
Photos: PLUS 3
Posted: Tue Mar 15, 2016 12:51 pm Post subject: |
I think I am going to go the new door out of marine plywood idea. as the separation is pretty bad, any ideas on where to locate marine grade plywood in Port Angeles? my concern with a new door was getting the door knob and lock to line up correct but shouldn't be too hard. |
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
Posted: Tue Mar 15, 2016 2:44 pm Post subject: |
Edensaw lumber in Port Townsend has lots of quality marine grade plywood. If you have not been there it is worth the trip just to see the candy store of exotic wood they have on hand. You probably will not find any in Port Angeles that is worth using. Google their website and check it out.
Doug _________________ Doug & Susan |
Posted: Tue Mar 15, 2016 2:55 pm Post subject: |
Jake,
I don’t know about PA, but Edensaw in PT is a very good source. Marine Ply in metric thicknesses. 6, 9, 12, 18 etc.
Edensaw Woods is a supplier of marine plywood and boat building lumber in ... Decking in Seattle and WA Top Quality Richlite Surfaces - Port townsend WA
http://www.edensaw.com/MainSite/Store1/Content/SiteContent/1/Home/Main.aspx
211 Seton Road
Port Townsend, Wa. 98368
Toll-Free: (800) 745-3336
Email:info@edensaw.com
On Edit: Looks like Doug beat me to it. H
SleepyC
Posted: Wed Mar 16, 2016 1:17 am Post subject: |
Edensaw is a great store to shop (and buy) in. Bring a drool bib!  |
