Fuel tank maintenance
Stormydos
City/Region: Florence
State or Province: MT
Vessel Name: Stormyuno
PostPosted: Thu Apr 07, 2016 7:31 pm    Post subject: Fuel tank maintenance Reply with quote
Had to pull my tank to repair a poor job on installing cleats.
First wondering what was used to "bed " the tanks, looked like deteriorating tar paper to me. I'm sure it's been there since installed,what a mess. Should I put something under it to reinstall?
Second I found what appeared to be small balls of rubber in the tank. Suspected fuel line but not sure if it's filler line or supply line back flushing. Anyone see this before?
PostPosted: Thu Apr 07, 2016 7:52 pm    Post subject: Reply with quote
Since the tanks are flat on the bottom, and are supposed to be completely supported -- yet the hull is not exactly flat in that area -- I wanted to do something to try to help support them. I also wanted to give water a way to drain, and then also avoid any hard spots from gelcoat lumps, etc.
Upshot is I bought some medium hard rubber stripping from Mcmaster Carr (it was something like 2-3" wide) and cut a bunch of them to fit under each tank. I ran the gaps athwartships, IIRC, but I can't remember for sure. At any rate I put the gaps whichever way they made the most sense for drainage. This way there is some support under the whole bottom, perhaps (?), and also a way for water to flush through, to some extent.
I saw where some people had used Dri-Deck but that was a bit higher than I wanted, and plus it gets a bit oddly floppy in hot weather (at least underfoot in the cockpit).
capt. meares
City/Region: Tillamook
C-Dory Year: 1988
Vessel Name: Vianey
Photos: Vianey
PostPosted: Thu Apr 07, 2016 9:41 pm    Post subject: Reply with quote
I also explored ideas to make it easier for moisture to dry out under the tanks with spacers. My conclusion was that there wasn't much that could be done because if you raise the tanks even 1/4" they wont fit all the way back under the splash well.
PostPosted: Thu Apr 07, 2016 10:32 pm    Post subject: Reply with quote
That's a good thing to check for. But it won't be the case with all generations of tanks and cockpit styles. There have been a few variations (different heights of tanks in the "plain hull" boats; plus the variable of the raised "liner" in the later boats with the permanent flat cockpit).
Page generation time: 0.0527s (PHP: 48% - SQL: 52%) - SQL queries: 21 - GZIP disabled - Debug on
