tom cat ceiling
kevin ware
City/Region: Mount Vernon
Vessel Name: El Gato Thomas
PostPosted: Sun Oct 30, 2016 6:40 pm    Post subject: tom cat ceiling Reply with quote
Has anyone covered the rough fiberglass ceiling onn a Tom Cat 25.5 with some form of headliner? If so what did you do and how did you attach it?
FYI I was up at the factory in Bellingham a couple of months ago and noted on their new TC model that a fabric material with teak 1 1/2 inch boards had been installed as a headliner, and looked pretty good. I think they glued the material to the ceiling, then used short screws through the teak to the underlying fiberglass ceiling.
Kevin Ware
El Gato Thomas
Mount Vernon, WA
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Oct 30, 2016 7:11 pm    Post subject: Reply with quote
I'd like to see some pics of that. Is it like the Venture 26 headliner? Or different?
<><><> Jason <><><>
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Sun Oct 30, 2016 8:14 pm    Post subject: tom cat ceiling Reply with quote
In the past the factory glued up some plywood strips and screwed the material on to them.
D.D.
PostPosted: Sun Oct 30, 2016 10:49 pm    Post subject: Reply with quote
There are several ways of putting the ceiling vinyl to the ceiling--both gluing it on and using the "door skins"--about 1/8" thick work.
Be careful with foam backed vinyl. You can get mold growing in that foam. Also the foam can delaminate and the ceiling sag.
The wooden battens support the fabric.
Page generation time: 0.0322s (PHP: 62% - SQL: 38%) - SQL queries: 17 - GZIP disabled - Debug on
