First cruise on CD-25 Deja La
alainP
City/Region: TUCSON
C-Dory Year: 2011
Vessel Name: deja la
PostPosted: Mon Jul 03, 2017 2:00 pm    Post subject: First cruise on CD-25 Deja La Reply with quote
I just got back from 10 days or so in Lake Powell, this was my maiden cruise on "deja la". The Yamaha F-150 has a 15 x 15 1/4 alu prop. During the test ride with the PO last November, with a virtually empty boat with only a 1/4 tank of gas we reached 5300 rpm at WOT. i thought that was a bit low at the time but did not give it further thought until this lake Powell trip.
The boat was now fully loaded for a two week cruise, tanks full, plus 2 5gl. jugs one for extra water the other for the Honda 2000 and kicker fuel.
I added Permatrim, the 9.8 kicker and bracket, the honda generator, the inflatable dink, fair amount of tools, more chain on the rode, 2 spare anchors, food, drinks etc..
It was obvious right away that i needed to raise the water line..
In terms of performance it was also clear I needed a different prop, the first day i would top out at 4200. After playing with the permatrim a bit and the trim tabs and with a little lesss fuel in the tank i was able in super flat water to reach 4500 rpm, still not good and my best speed was with the trim tabs all the way down, as soon as i tried to raise them a bit the speed would drop. the Permatrim was up about 30% for best speed. I was very stern heavy and felt like i needed to add weight to the bow so i did not have to rely so much on the trim tabs. Do any of you C-25 owners go through the same thing? what did you end up with prop. wise? Any insight appreciated. Alain Provost
PostPosted: Mon Jul 03, 2017 4:24 pm    Post subject: Reply with quote
We had a C Dory 25 with the 130 Honda (same block as the 115, so less torque than the 150). We started with a 15 " pitch, and had about the same experience or worse. We dropped to a 13", and it was better, still a struggle to get on a plane. I talked with Ken at Prop Gods, and he suggested an 11" pitch. We sold the boat to a C Brat who keeps it on Powell, and he has stuck with the 11".
It is very possible that the 13" pitch may be enough for you. With the 11" you are reving up fairly high still at displacement speeds. But we did get the boat up to the 5500 RPM and on a plane at 17 knots WOT.
Looks as if you got two threads going. I'll copy and put this on the other one.
Page generation time: 0.0287s (PHP: 58% - SQL: 42%) - SQL queries: 15 - GZIP disabled - Debug on
