Esmi2
Joined: 26 Aug 2016 Posts: 96 City/Region: San Luis Obispo, CA
Photos: Esmi2
Posted: Tue Nov 06, 2018 4:59 pm Post subject: Duplicate duplicate posts? |
Either I am slightly losing my mind, or posts are occassionally showing up as new several days after their initial appearance.
For instance, right now there is a New Today post for a 2006 C-dory named “Miss Maria.” I am almost positive this exact same post was new last week. But I see no evidence of the previous post, just this new one.
Is it me? Or is something going on?
Posted: Tue Nov 06, 2018 5:03 pm Post subject: |
I noted the same item. Mostly new posters--maybe someone using two names. Most duplicates are a result of not checking to see if the post went thru--or accidentally hitting post a second time as one goes back. _________________ Bob Austin
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Tue Nov 06, 2018 6:05 pm Post subject: |
For me there seems to be a timer that prevents accidental duplicate posts. If I have finger trouble and a second duplicate post is sent I get a message that says something to the effect of a second post cannot be sent so soon.
However, it seems that it doesn't work for all people. There are a few users that end up with duplicate posts almost every time they respond to a forum. |
Posted: Tue Nov 06, 2018 6:06 pm Post subject: |
For me there seems to be a timer that prevents accidental duplicate posts. If I have finger trouble and a second duplicate post is sent I get a message that says "You cannot make another post so soon after your last; please try again in a short while."
It seems that if you hit submit, then preview, and then submit again, you can get duplicate posts.
Also, if you hover on the edit button on your latest post, the popup says "Edit/delete this post". However, once you go into edit mode, I don't see any way to delete it. AFAIK, you can only delete the text the posting contains, but not the actual posting. |
nordicstallion
Joined: 16 Dec 2007 Posts: 380 City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
Posted: Wed Nov 07, 2018 7:35 pm Post subject: |
I had the same problem, I just needed to give it another few seconds after hitting submit. |
Posted: Mon Nov 12, 2018 12:39 am Post subject: |
I am guilty of the same thing. Need to watch the little spinning circle,,,,
Until it stops spinning
Before we try to move on to the next activity:oops:
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
