V berth portholes
dutch123
City/Region: Prince George
Vessel Name: Reel Action
Photos: Reel Action
PostPosted: Sun Mar 25, 2018 11:49 am    Post subject: V berth portholes Reply with quote
Good morning all, it's that time of year to get exited about the upcoming cruising season here in the PNW. This topic has been talked about numerous times but without looking for the thread can someone please remind me which porthole was the right fit on a 22. I was looking at the vetus portholes and thought the pm20 was the one that fit. Maybe there is a better option? Thanks for the help.
My dream boat has arrived!
PostPosted: Sun Mar 25, 2018 2:17 pm    Post subject: Reply with quote
Vetus has changed the numbers since I put mine in. Basically you need the smallest oval one. Because the berth trunk is curved a port that is too long will not sit properly. If you go with the round ports you can use a bigger diameter port. In the end the area of the opening is about the same though.
The port needs to go on the flatter part of the trunk a little forward of the nav light.
Be sure to order the proper sized screen inserts as well. They are sold separately.
For the oval port, use the right size hole saw for the radius at each end, then use a hack saw blade to cut the FG between the two holes. A round port just needs the right size hole saw. Because the Vetus ports are metric, I had to order the correct metric size hole saw online. Installation is pretty easy, but cutting big holes in the side of the boat is a little unnerving.
There is a gallery on this site somewhere showing a step by step installation by someone on their boat.
Page generation time: 0.0251s (PHP: 64% - SQL: 36%) - SQL queries: 15 - GZIP disabled - Debug on
