Help with freshwater tank install 89 Cruiser
gcrown22
City/Region: Northwest
Photos: gcrown22
PostPosted: Fri Aug 17, 2018 5:49 pm    Post subject: Help with freshwater tank install 89 Cruiser Reply with quote
The previous owner of my boat took out the tank in my boat and cut the hoses out of my 89 cruiser, I have never had a chance to see how the freshwater tank was originally installed under the dinette seat. I want to get it all hooked up but not even quite sure how the tank actually sat in its cubicle whether it was on it side or standing up?
I assume the large fill hose goes to the large opening on tank with some kind of adapter? I see a spot for a smaller hose on the tank which I think runs over to sink area? I want to hook to eventually have this hooked to sink and install electric pump for sink.
Anyone have any pictures of this freshwater setup so I can get an idea of what I need to do? Thanks for any and all help appreciate it!
PostPosted: Fri Aug 17, 2018 5:55 pm    Post subject: Reply with quote
The large fill hose should direct connect to the "fill" hose. Usually 1 1/4 to 1 1/2 ", there is Vent on the top or upper side--and that goes to the "Vent" on the side of the hull. Usually 1/2 or 5/8" tubing
The outlet is at the bottom of the tank. As I recollect this is 1/2". and will be the lowest side of the tank--a little deeper than the outboard edge. So deepest edge inboard, with outflow hose there.
Page generation time: 0.0352s (PHP: 36% - SQL: 64%) - SQL queries: 15 - GZIP disabled - Debug on
