Surfdad62
C-Dory Year: 1998
Vessel Name: Missy
Posted: Fri Apr 12, 2019 5:38 pm Post subject: Angler 16 Alaskan curtain/plastic drop down curtain |
Hello
Looking for a plastic or canvas with big window drop down curtain to keep the weather blowing in when the need arises. Possibly attached to the twist lock fasteners used for the mooring cover on the cab opening. THANKS! |
Joined: 02 Nov 2003 Posts: 21519 City/Region: Pensacola
Posted: Fri Apr 12, 2019 6:44 pm Post subject: |
Your best bet is to have a local canvas working build it for you.
Another DIY is with SailRite materials. This can be done without sewing, using Shelter-Rite vinyl scrim reinforced fabric, and clear vinyl for the window. @ $18 a yard. (2-3 yards) Clear vinyl 30 gauge 68" x 29" for $27. You can assemble the back curtain, just using HL66 Vinyl glue-- no sewing or zippers. Close the center with common sense fasteners. The common sense fasteners, and the turn the tab will cost about $12 for 10. You can hand cutout with an exact knife--or get a cutting tool for $70. (cheaper one for $27 on amazon--not as good.) You will probably want to use the rivet set (so you want a punch, and set) These can coast as little as $15.. These are easy to build and give you some new skills. Total cost is going to be in the Less than $100 to $200 if you buy some professional grade tools... and be set up for more projects in the future.
Overlap the flap in the middle and 3 fasteners would suffice to keep it closed.
Common Sense Fasteners:
[/b] _________________ Bob Austin
dgeorges
Joined: 04 Sep 2013 Posts: 182 City/Region: Highlands Ranch
Vessel Name: FRESH FISH
Photos: FRESH FISH
Posted: Sat Apr 13, 2019 11:44 pm Post subject: |
Sent you an email with some images.
Let me know if the photos are what your are looking for (could not get a photo posted in this response). _________________ "Ain't no nookie like Chinookie"---Ray Troll
CD 22 Cruiser "FRESH FISH: 2018 to present.
CD 16 Angler "OPA": 2013 to 2019. |
