Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Fri Oct 11, 2019 10:12 pm Post subject: Sharrow Engineering Prop |
Boat Test.com of the Sharrow prop.,. Although the test boat is a Bayliner, it uses a 90 HP Merc, and a prop size most of use. (15 x 15).
This appears to be a game changer in prop design and efficiency. The question is how much this will cost, the durability and repairability. The recreational boat division is just starting, but the biggest savings seem to come from large vessels.
 _________________ Bob Austin
pcg
Vessel Name: C-Quest
Photos: pcg
Posted: Fri Oct 11, 2019 10:58 pm Post subject: |
Wow, sounds very promising. Thanks for posting this. _________________ Paul |
NORO LIM
Photos: NORO LIM
Posted: Sat Oct 12, 2019 12:07 am Post subject: |
Looks like a cross between an egg beater and a Mobius strip.
That is really interesting! Thanks for posting. _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
Chester
Photos: Chester
Posted: Sat Oct 12, 2019 3:50 am Post subject: |
High aspect ratio blades and reduced vortices seem to greatly improve the efficiency. |
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Sat Oct 12, 2019 2:14 pm Post subject: |
Wonder how the price compares.
One advantage to the C-Dory is shallow water operation. This can risk the prop. I have grounded my prop a couple of times. If my AL prop gets too messed up a replacement is relatively inexpensive.
Doubt it'll be the same with this one. |
Posted: Sat Oct 12, 2019 3:27 pm Post subject: |
No where is the price of the recreational prop noted. They talk about "additive manufacturing--some have interrupted this as being 3 D printing in metals, since they say that any material which is used for current props can be used on these.
There are some University of Michigan test photos which show much less tip turbulence with the Sharrow prop.
I would sure like to try one out to see if it would reduce my RPM at cruising speed with a load. I have a 4 blade aluminum which came with the boat and has never been used (as far as I can tell). |
Joined: 07 Nov 2003 Posts: 7937 City/Region: marysville
Posted: Tue Oct 15, 2019 10:08 pm Post subject: |
I watched the video and then filled out the information questionnaire at the end. This means that when the props are starting to go on the market I get contacted. let you know when that happens. they wanted to know what size boat, motor, current prop, etc. _________________ Thomas J Elliott
Discovery
Joined: 08 Dec 2003 Posts: 1245 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Mon Dec 23, 2019 8:03 pm Post subject: |
Sharrow Props are available to pre-order. $9,000 each in stainless, but they're sold out. $4500 each in aluminum. $18,000 stainless or $9,000 aluminum to outfit a TomCat. What a deal!
https://www.sharrowmarine.com/?mc_cid=a5f871b86d&mc_eid=9b3d672ee6 _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
