Weatherstripping
Chuckpacific
City/Region: SW PDX
Vessel Name: Big Sky
Photos: Big Sky
PostPosted: Sun Jun 13, 2021 8:15 pm    Post subject: Weatherstripping Reply with quote
Does anyone have a default weatherstrip suggestion? Currently have some leakage in my lazarette.
Chuck
There’s only one success – to be able to spend your life in your own way.
2003 CD-22 2002 - 2012
2000 Camano 31 2012
View user's profile Send private message Yahoo Messenger
PostPosted: Sun Jun 13, 2021 10:04 pm    Post subject: Reply with quote
If these are the top hatch on the 22, Here is a link to a different cover which does not leak
http://www.c-brats.com/viewtopic.php?t=9740&highlight=lazarette+hatch]Here
PostPosted: Sun Jun 13, 2021 11:24 pm    Post subject: Reply with quote
Yep, replace the hatches. First thing I did when I got my boat.
FWIW, new boats come with the hatches recommended in this thread.
PostPosted: Mon Jun 14, 2021 4:36 am    Post subject: Reply with quote
Chuck, If these are your current lazarettes, You do need to replace them. It is a pretty easy job and will make all the difference. It will be easy as doing weather strip and it WILL fix the problem.
That is one of the first things I did on my boat and even I could do it so it has to be easy.
BBlalock
City/Region: Ocean/ICW
C-Dory Year: 2013
Vessel Name: Finale
PostPosted: Wed Jun 16, 2021 10:47 am    Post subject: Reply with quote
I tried to pull that hatch on Finale to fix it leaking but it was stuck down with 5200 or something too strong. Only leaks when in bad weather and heavy spray, not rain.
Suggestions.
Benton Blalock
'13 25' Cruiser "Finale"
'12 22' Fiesta pontoon(sold)
PostPosted: Wed Jun 16, 2021 11:08 am    Post subject: Reply with quote
Suggestions.
It is not that hard to get the hatches out even when stuck on with 5200. Just takes a heat gun, a single edge razor blade, some solvent, and patience. The last one is most important.
PostPosted: Wed Jun 16, 2021 2:57 pm    Post subject: Reply with quote
I have used piano wire or guitar strings pulled back and forth with anti bond to loose 5200 attached objects. It is unlikely that C Dory used 5200 on the hatch--probably the same sealant used which was a Bostec compound for many years.
BBlalock
C-Dory Year: 2013
Vessel Name: Finale
PostPosted: Thu Jun 17, 2021 11:16 am    Post subject: Reply with quote
Thanks for the suggestions. Looks like I'll have to give it a go again. The SO didn't like the dripping on to her head after crossing the Albemarle Sound with decent chop and crossing wind last week.
Page generation time: 0.0371s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
