Permatrims: My 2 cents
Goto page 1, 2, 3  Next
C Sniper
City/Region: South Padre Island
State or Province: TX
Photos: C Sniper
PostPosted: Mon Dec 27, 2021 8:14 am    Post subject: Permatrims: My 2 cents Reply with quote
I have read most of the stuff and was lucky my vessle can with permatrims on the twin 40's. Man that was sweet, not only could I smooth it out by stuffing the nose in but also level things out when I had an uneven load. Now after a repower I am down to a single 115 and put about 50 hrs on without one. Wow what a difference! To be fair I am teaching kiteboarding off the boat so I am often out in 20-30 knot winds ripping over a shallow estuary, so very tight bumpy chop. The first 50 hrs I was limited to about 3600 rpm (13 knots) when running into it on the way back in, any faster and the ride was too rough. Me and the my son just installed one the other day and finally got out yesterday to try it. He was kiting and I was watching/giving tips via the radio helmet from the cabin. The winds started out in the high 20's and backed off to mid 20's by the time we called it. The ride in was GREAT. We were cutting across the chop at about 45-60 degrees like I always have done but we we running more like 4500 rpms and 20+ knots. The ride was smoother than it used to be going waaaaay slower. Anyway now that I have actually tried with, on dual engine, and both ways on a single. I thought I could finally chime in and say I am a huge fan and have felt the difference first hand.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Mon Dec 27, 2021 8:39 am    Post subject: Reply with quote
You won't get any argument from me! I am a big fan and proponent of Permatrims. I made my first round trip to Alaska without them, and my next two with. Night and day difference - especially heading into short chop. With Permatrims on twin engines, I found no need for trim tabs.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
daninPA
City/Region: MOUNT JOY
C-Dory Year: 1994
Vessel Name: NAVIRE
Photos: daninPA
PostPosted: Mon Dec 27, 2021 8:45 am    Post subject: Reply with quote
Absolutely, positively yes on Permatrim!
A Yamaha 115 on the stern of our CD22 made the purchase just about mandatory.
C Sniper
Photos: C Sniper
PostPosted: Mon Dec 27, 2021 7:42 pm    Post subject: Reply with quote
can someone with permatrims and trim tabs chime in here as well. Even though the permas made a HUGE difference there is still alot of "gentle bumps" charging into it upwind, at a shallow angle to boot. The more I am using this boat for work the more I like it! I am wondering how much more I can smash the nose in and further smooth out the ride by adding tabs? My center console has tabs but not a foil... I think partly I miss being able to level the boat as well. ugh, single engine repower regret perhaps... why can't the passengers just stay seated! hahaha
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Mon Dec 27, 2021 8:19 pm    Post subject: Reply with quote
The Permatrims on my twin Honda 60’s are much larger than the ones on my replaced Honda 40’s. My now Permatrims would fit all Honda’s between 60 hp & 150 hp, yet I still have & use the Bennett trim tabs too. I run heavy & with the extra hp of the twin 60’s, find the combination of the larger permitrims & trim tabs very useful in varying boat weight & sea conditions.
C Sniper
Photos: C Sniper
PostPosted: Mon Dec 27, 2021 9:34 pm    Post subject: Reply with quote
ha, I knew I was justified adding tabs to the list of endless expenses/upgrades I want to do!!! damgit, I lose again Confused
davidJ
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
Photos: davidJ
PostPosted: Mon Dec 27, 2021 10:45 pm    Post subject: Reply with quote
On my 19 I have both trim tabs and a permatrim. The tabs are a must on the 19, as it is like a 22 with the back 3' cut off. Usually, I trim the permatrim for max revs. on the motor and use the tabs to adjust from side to side and to bring the bow down when going thru the bigger waves and also to come up on plane when running heavy. We have to slow down a bit in the waves when we trim down or else the boat gets a little squarely, but we still get bounced around some in the 3 and 4 footers as slow usually means 15 to 20 mph. I guess the only thing the permatrim does on my boat is to make the waves think I'm a 20- footer instead of a 19.
C Sniper
Photos: C Sniper
PostPosted: Mon Dec 27, 2021 11:01 pm    Post subject: Reply with quote
Would be great to try tab and trims all at the same time! Sounds like you like your setup! thanks for posting! another vote for me to break out another couple thou, ((sad face)). Where is that lottery ticket I bought last night??? haha
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Dec 28, 2021 9:12 am    Post subject: Reply with quote
We had a 22 with twin 40s with permatrims for a number of years, and later a 22 with a single outboard, also with a permatrim. Both boats had tabs. I'd say I could have possibly gotten by without the tabs if I had to, on the first boat with twins. The two permatrims on the twins kept the bow down and I could adjust side to side. On the boat with a single, I think tabs are an absolute necessity, unless you opt to move a lot of the weight off the stern somehow with saddle tanks and batteries forward. We had issues with the lenco controls a few times and the boat did not handle the way I wanted it to without tabs.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
C Sniper
Photos: C Sniper
PostPosted: Tue Dec 28, 2021 12:14 pm    Post subject: Reply with quote
another vote for both, thanks for the feedback
PostPosted: Tue Dec 28, 2021 5:07 pm    Post subject: Reply with quote
The advantage of either tabs or Permatrim is that you can drive the bow down into chop, but in following seas your can negate the tabs, (not so much the permatrim) so you decrease the chance of bow steering should you get some big lift from waves aft.
Much easier to flip a switch than to move ballast.
C Sniper
Photos: C Sniper
PostPosted: Wed Dec 29, 2021 9:39 am    Post subject: Reply with quote
Yes offshore in following seas I had a couple episodes of short lived excitement. In the laguna there is no concern for this as the shallow water does not allow true waves to form. We get following chop.
daninPA
C-Dory Year: 1994
Vessel Name: NAVIRE
Photos: daninPA
PostPosted: Wed Dec 29, 2021 10:35 am    Post subject: Reply with quote
I'm not sure why Permatrim would be less able than trim tabs? I've found that if I trim up and ride the backs of waves I have no problem. It's only an issue if I lose focus and get pushed over the top into the next trough (rare, but has happened).
PostPosted: Wed Dec 29, 2021 12:35 pm    Post subject: Reply with quote
As a person who feels both trim tabs and Permatrims are ideal, I would disagree that the permatrim does not help bring the bow up. My experience is that it does.
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Wed Dec 29, 2021 1:17 pm    Post subject: Reply with quote
I have experience with neither, but I thought the purpose of Permatrim was to lift the stern, i.e. bring the bow down.???
Paul
Page 1 of 3
Page generation time: 0.0424s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
