mounting Scotty 2500 prawn /crab trap puller on a 22 cruise
PvL
City/Region: Sunshine Coast
Vessel Name: Lately
Photos: Latley
PostPosted: Wed Jan 05, 2022 10:01 pm    Post subject: mounting Scotty 2500 prawn /crab trap puller on a 22 cruise Reply with quote
I am buying a Scotty 2500 prawn /crab trap puller and would appreciate pictures and/or mounting information for a 22 cruiser. I currently use Scotty manual down riggers with the slide in mount for 1050 and 1060 down riggers.
Thanks in advance
PvL
PostPosted: Wed Jan 05, 2022 11:10 pm    Post subject: Reply with quote
PvL, Hey it is good to see you on the site. And to see the (JC) Lately here. I'm the neighbor across the street from Paul. Looks like you are treating that boat well, and putting it to good use. Sorry, I can't help with your question, not fishing or crabbing on my boat.
PvL
Vessel Name: Lately
Photos: Latley
PostPosted: Thu Jan 06, 2022 9:46 pm    Post subject: mounting Scotty 2500 prawn /crab trap puller on a 22 cruise Reply with quote
Good to hear from you Harvey. Last time we crossed paths was at the Powell River gathering a few years back. We try to keep (JC) Lately the way Paul and Verna would have wanted. We sure remember your help when we bought our 22.
PostPosted: Thu Jan 06, 2022 10:19 pm    Post subject: Reply with quote
Well you have two choices and neither is good. The slide in mount will not work with any of the current products. So your choice is a separate mount for the Puller or New down riggers. Which ever you do Use a backing plate, stainless steel hardware and back fill your hole then redrill them. That means drill the holes for the mount. Remove the wood between the fiberglass at least a 1/2 inch. tape the bottom and fil with epoxy. Then redrill you holes to the bolt size. This will strengthen the mount and stop any water from entering the wood core. I like to use starboard as the backing because it does not compress or rot. easy to cut to size. Hope that helps.
PostPosted: Thu Jan 06, 2022 10:22 pm    Post subject: Reply with quote
Oh and if you have not bought that puller yet I would not. Its shit. I used one once and it was almost useless. That was the first year they can out so maybe they got better. My pots are minimum 40 lbs because of the current in the sound and the San Juan's.
davidJ
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
Photos: davidJ
PostPosted: Fri Jan 07, 2022 12:57 am    Post subject: Reply with quote
If you are going to be shrimping, I think Starcraft Tom is probably right. I usually shrimp at 200 to 350 feet deep with 400 ft. of line in the San Juans, and you better have a heavy pot and a heavy-duty puller. If your handy you can build your own puller using a wheelchair motor and rent a hydraulic pipe bender to make a davit to go with it for a bit less $. There are instructions on page 4 of the All C-Dorys all the time section of this forum, and pics. in my album. good luck.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Fri Jan 07, 2022 2:55 am    Post subject: Reply with quote
The puller might be fine for his use. It's hard to say since he didn't elaborate. A lot of people tried to steer me away from an Ace line hauler and I have used it hard for years. It is still holding up fine and going strong. The scotty one might be ok too depending on what you're doing.
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Mon Jan 10, 2022 11:00 am    Post subject: Reply with quote
I have an aluminum bracket that was fabricated up on my boat mounted on the gunnel with four bolts. Happy to send you a picture if you if PM me your cell.
PostPosted: Thu Jan 13, 2022 1:47 am    Post subject: Reply with quote
T.R. I have the ACE line puller . My second one and would recommend it over the scotty. My old one is for sale to who ever wants it. works great but just decided to up grade to the hands free option.
PvL
Vessel Name: Lately
Photos: Latley
PostPosted: Wed Jan 19, 2022 1:43 pm    Post subject: mounting Scotty 2500 prawn /crab trap puller on a 22 cruise Reply with quote
Thanks everyone for the input. It is appreciated.
I will stay with the Scotty line puller for a number of reasons:
1. recommendations from fellow boat owners in our marina
2. small size and ease of storage
3. deal I am getting from a fellow C-Brat
The Ace puller is certainly good. I have used one on my friend's 21 foot Ranger Tug many times.
Below is some information I received from Scotty Customer Service.
The 2500 needs a mounting surface of 6"x6" to mount..... From the photos I found online of your boat, it shows your gunnel to be close to that size.
The only other option for mounting and being able to remove the mount when not in use, is our 1025 side gunnel mount.
Unfortunately we do not have any instructions for mounting this unit that I can send you....
Here is a link for a video showing the mount. ( this video is on the 1025 page)
https://youtu.be/sDhwJfsdx6w
https://scotty.com/product/1025-right-angle-side-gunnel-mount/
The scotty 1010 slide in brackets will Not work with the line puller.
You will also need to use 10 gauge wire to supply power to the unit. (also a 30 amp fuse)
the female recptacle is included
Cheers
Scotty Fishing & Outdoor Products
2065 Henry Ave West
Sidney, British Columbia, V8L 5Z6
Toll free: 1-800-214-0141
[/i]
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Wed Jan 19, 2022 2:28 pm    Post subject: Reply with quote
I just read the following in Scotty's 2500 product description:
"Its high torque 12V motor pulls 1 crab trap and up to 4 prawn traps with ease."
Clearly Scotty doesn't understand shrimping in the PNW. That 1 crab trap pull is the same load as 4 shrimp traps is nuts. The "prawns" they are thinking of are certainly not the spot shrimp we fish for in Washington state or in BC.
Sandy McKean
Purchased Tosca in 2014
johnr
City/Region: Bellingham
Vessel Name: Stillwater
Photos: Surf Scoter
PostPosted: Thu Jan 20, 2022 4:56 pm    Post subject: Reply with quote
I have the 2500 and it's great for pulling crab traps. It's ok for shrimp pots, not ideal, but way, way, way better than not having a puller at all. I'm still pretty strong and my son is stronger, so that may be a factor as well. You have to help the 2500 with some muscle if you're using it for shrimp pots.
PostPosted: Fri Jan 21, 2022 6:42 pm    Post subject: Reply with quote
this is correct if you know that in b.c area where they shrimp there is LESS current in the bays and inlets where they shrimp/ prawn then in the san juans. Most folks up there use the stackable wire pots with No weight. They also are allowed to long line 4 pots on one buoy . Scott is based in Canada out of Vancouver Island. So they do know how to do it in their waters. This is why I would not use a scotty pot puller here in the Sound or straits.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Sat Jan 22, 2022 5:00 pm    Post subject: Reply with quote
Very interesting Tom.....I learned something.
Frankly, it's hard for me to imagine shrimping without current since current has always been the #1 factor I deal with (and screw up over Wink Laughing ).
You'd be just the guy to likely know the answer to this question....I've always thought that shrimp prefer to live in areas with heavy current flows. I assumed that they hide under ledges or in cracks on the bottom until near slack, and then they come out to feed on whatever the previous current just brought in. This must be a mistaken assumption on my part if shrimp live happily in low current bays and inlets. Do shrimp really care about current?
NewMoon
City/Region: Holladay
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
PostPosted: Sun Jan 23, 2022 9:12 am    Post subject: Reply with quote
In our primary cruising areas of BC and SEAK, the best shrimping locations we've found are tucked away from big open water, where there is some current but not a great deal, and not so many predators. We weight lightweight stackable pots with 12lb of lead. Staying in WA waters in 2020, our setup worked well in Dabob Bay, but we got surprised and lost two pots in the San Juans, not realizing how strong the current was going to be.
As non-residents who can't string a bunch of pots on one line, the Scotty puller works for us. On our NT it's conveniently stowable, and swappable with Scotty downriggers.
We use this skinny line - works great and 400 feet stows in a small tub:
https://www.go2marine.com/Round-Braid-Nylon-Twine-1-lb.-5-lb-Rolls?quantity=1&color=338&size=738&weight=58
Richard Cook
"Cruising in a Big Way"
Page generation time: 0.057s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
