5/16" barb to 3/8" barb adapter
Ken O
City/Region: West Yellowstone
State or Province: MT
C-Dory Year: 1990
Vessel Name: Ravens' Roost
Photos: Ravens’ Roost
PostPosted: Tue Jan 18, 2022 7:11 pm    Post subject: 5/16" barb to 3/8" barb adapter Reply with quote
This may seem trivial, but does anyone know of a source for a 5/16" barb to 3/8" barb gasoline fuel line adapter (brass preferred)? I cannot find one anywhere (except questionable ones on Amazon). I don't want to put gasoline in questionable fittings. Last year I replaced all fuel lines with new 5/16" ID lines, which meets the spec for my older Honda BF90. I want to install a fuel flow sensor, and the recommended Navico unit has 3/8" barbs. This unit should be installed after the fuel filter/water separator. I can easily change out the "out" fitting at the filter, but I want to keep most of my fuel lines the same size, so I need to get back down to 5/16" to get to the motor. All I need is one adapter, but I can't seem to find one. Any ideas? Thanks!
"If it were easy, everyone would be doing it." --Circumnavigator and author Larry Pardey.
PostPosted: Tue Jan 18, 2022 8:41 pm    Post subject: Reply with quote
Check out a local hardware store that has a large selection of fittings. Also, can you find a 5/16" fitting that will go right into your fuel filter base? I do see both brass and stainless steel barbed fittings that are 5/16" x 3/8" on Amazon. I think they would be fine.
PostPosted: Tue Jan 18, 2022 9:35 pm    Post subject: Reply with quote
There are direct adaptors hose barb 5/16 to 3/8 in nylon (Although nylon is resistant, I don't use it in fuel lines) and brass. Another way to do it is to get the 5/16 and the 3/8 barb to 1/4" pipe thread and a close coupling and made your adaptor.
For the fuel flow, I have just just put a fine mesh filter in line before the turbine flow meters. That works fine. They are concerned about larger debris. Same for fuel pumps.
You do have to be sure that the directions for "up" and fuel flow direction are followed.
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Tue Jan 18, 2022 10:29 pm    Post subject: Reply with quote
If you heat up the 5/16 hose in a pan of boiling water, you might be able to slip it over the 3/8 barb.
Ken O
C-Dory Year: 1990
PostPosted: Wed Jan 19, 2022 9:35 am    Post subject: Reply with quote
Thanks for the helpful thoughts. I did finally find an adapter at my favorite hot rod shop:
https://www.jegs.com/i/JEGS/555/15946/10002/-1
This part is intended for fuel lines, so I'm OK there.
BTW, Jegs is not a marine supplier by any means, but they have been a very good vendor to deal with for anything automotive.
Page generation time: 0.0276s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
