Solar powered vent size for Airhead Composting Toilet
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Mon Apr 17, 2023 4:10 pm    Post subject: Solar powered vent size for Airhead Composting Toilet Reply with quote
We are ordering an Airhead Composting Toilet for our new-to-us 2004 25 Cruiser.
I know there was a discussion not too long ago about the specs being changed for the roof mounted Solar powered vent size and maybe fan size.
The vent hose from the toilet is 1 1/2" ID. Do all the roof top vents have that size to accept the vent hose?
Wondering what I need to order to make our system efficient and odor-free.
There are so many different solar powered vents on Amazon that I just can't decide. Seems like the Marinco used to be the only one a few years ago, now there seems to be countless options.
Thanks in advance!
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Mon Apr 17, 2023 6:16 pm    Post subject: Reply with quote
The fan for the Air Head, only draws 0.08 amps or in 24 hours, about 2 amp hours. The Nicro (now Marino) solar vent is the "standard" which has been used for years. I don't know if the cheaper ones will be comparable in noise, durability etc.
On our 25 the Micro solar vent was in place, but it was powered by the 12 volt boat's battery. At some point these solar vents give out--and you may get away with just replacing the batteries (I would use "Enlope" to replace), but I suspect that the solar cells were not producing enough power, so someone along the chain of ownership, had just cut the solar and AA batteries out and hard wired the fan. In fact when I sold the boat, I included new Nicro solar fans, for the main cabin and forward V berth area in SS.
The fan is necessary. Many times these are installed in either applications where it is not practical or safe to use a solar fan, and are used with an inline small computer fan.
My advice is just use the mini fan, and a small solar charger for your battery bank or a good smart battery charger (which I used) and skip the solar fan. If you want to go with solar, then the Chinese may be just as good-and you can buy 3 of them for the price of one genuine Nicro solar fan. But I don't really know how well the cheapies hold up on the boat--and we all know that Amazon "ratings" may be not accurate.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Apr 17, 2023 7:43 pm    Post subject: Reply with quote
My experience with the Nicro solar vent has been positive. I absolutely do not want anything connected to a boat battery, then I am not on the boat. My Air Head came with the 12VDC muffin fan at the top of the vent hose... I removed it and put a 4" Marinco Nicro solar fan above the head compartment and installed the same on the forward hatch. The forward hatch brings air in and the one in the head take air out. When you buy the vent it comes with two different fan blades, that you get to choose the direction of air flow.
Now 4 years and zero odor and the fans are still operating properly. They fans do slow down in the winter, due to less sunlight, but still run 24/7 in Virginia.
On a similar note, I installed the same fan on my trimaran sailboat 15 years ago and aside for replacing the battery 3 times, it still runs like the day I installed it.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon Apr 17, 2023 8:22 pm    Post subject: Reply with quote
Airhead no longer recommends using a solar powered vent, due to the fact they will not run long without sunshine. (You might get a nights run out of them, but if the next day is cloudy, it will stop working.) I have not had the same experience as Steve has with regards to the Marinco Solar Vents I've owned. They're nice when they work, but unless you have sunlight every day, they will die after a cloudy day. So airhead now recommend using their small (computer) fan, and any of several 3" vents. This was their tech's reply to me earlier:
I've seen some hook it up to their solar vents. However, there are times the solar vent fan stops working, with cloudy days.
We do not recommend solar vents anymore. In the beginning we did. They can let wind in when it gusts. They do not run 24/7 after a cloudy day, and can expose the system to insect invasion. They also do not prevent water ingress. They are designed to circulate air through the cabin but for that application, it was never critical for the unit to run 100% of the time.
We recommend the following, in connection to the battery:
1. Nicro Air Vent 500, 3"
2. Vetus UFO 3"
3. Mushroom vent, 3".
I went with no. 1 and it works great. The airhead comes with the little computer fan in an end fitting that fits on the end of the vent hose. I simply made a small spacer on the Nicro Air Vent, below my ceiling, to attach that end fitting to. I tied the fan in with my lighting circuit, since wiring was already in the head for the light. The minimal amount of current it draws has not been a problem. Of course when I'm not on the water or plugged in when on the trailer at home, I shut the circuit down. Any breeze over the vent still draws air out of it, and the boat isn't sitting long before use during the season. BTW, I found Airhead to be very responsive to all my questions. I emailed them at: support@airheadtoilet.com.
Colby
Salmon Fisher
PostPosted: Tue Apr 18, 2023 4:11 pm    Post subject: Reply with quote
Thank you Bob, Steve and Colby.
Just the information needed for the switch over.
C-Brats are Awesome!
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems All times are GMT - 5 Hours
Page generation time: 0.0996s (PHP: 49% - SQL: 51%) - SQL queries: 18 - GZIP disabled - Debug on
