murthog
Vessel Name: Lu-C
Posted: Wed Jun 14, 2023 7:48 pm Post subject: 2009 22 Cruiser. How to convert cabin table into bed? |
Yes I feel a bit silly, but I cannot, for the life of me, figure out how to convert the port side table to a sleeping area.
Are there instructions, and or diagrams anywhere? I know that it is not convertible on all years -does the 2009 22 Cruiser qualify?
Thanks in advance. |
srbaum
Joined: 30 Aug 2010 Posts: 909 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Wed Jun 14, 2023 8:44 pm Post subject: |
Murthog,
The table with leg removed or folded, rest between the two seat. The backs on the two seats, gets put on the table to make a leave bunk. _________________ Steve Baum
Homeport of Portsmouth, VA
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Wed Jun 14, 2023 9:37 pm Post subject: |
I have owned a 1993 and 2006 C Dory22 and both had the table which dropped down in the middle and make the bunk, as Steve noted. I would see no reason that the 2009 would be an exception. _________________ Bob Austin
djy887
Joined: 22 Feb 2008 Posts: 32 City/Region: Bainbridge Island
C-Dory Model: 24 Tomcat
Vessel Name: Still un-named (yeah, I know)
Photos: djy887
Posted: Wed Jun 14, 2023 11:48 pm Post subject: |
Depends on the bracket style holding the table to the bulkhead. Some are 'L' shaped that simply lift out allowing the table to be lowered to the seat level. The table on my 99 TC24 was 'hinged' to the bulkhead at some point in its past...so I need to replace those if I want to use the table as a bunk. Search my previous posts...I had an earlier string about the same thing and a couple of people posted pictures. |
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Wed Jun 14, 2023 11:59 pm Post subject: |
On my '08, the table is attached to the sidewall with split hinges and has two different posts. There is a threaded knob that holds the table in place on the side wall.
To change it from table to bed, you start by unscrewing the knob. The table is now free to move a bit. Remove the post. Then slide the table aft a bit to release it from the hinges. Put the short post in place under the table and place the table across the gap between the dinette seats. Basically, the table is just moved to a lower position, the orientation does not change. It is important to use the short post, the table/berth will not support much weight without it. |
murthog
Vessel Name: Lu-C
Posted: Fri Jun 16, 2023 6:38 pm Post subject: Table to bed |
ssobol: mine is the same setup. Does it make rather a short bed?
I don't see what fills the space where the port side passenger has their legs when sitting. |
Posted: Fri Jun 16, 2023 8:33 pm Post subject: Re: Table to bed |
murthog wrote: | ssobol: mine is the same setup. Does it make rather a short bed?
The table top spans the gap between the fore and aft seats. If you have the barber chair setup, the forward seat has to be in the forward position (person facing aft).
The converted dinette is actually longer than the v-berth and is not tapered. Problem with sleeping on the converted dinette is that if you get waked while sleeping there you could end up on the floor. |
Salmon Fisher
Joined: 07 Aug 2009 Posts: 874 City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
Posted: Fri Jun 16, 2023 8:38 pm Post subject: |
Murthog,
Do you have the forward facing port passenger seat? If so, you have to slide the seat forward on its track and lock in place. Your table must be hinged, so bring up the part that is hinged down and lock in place. You probably have some sort of slide support underneath that supports it in a flat, full table configuration. Now just follow the directions from SSOBOL and you should have a bed of about 6' in length or so.
It would be helpful if we could see pictures of your cabin. If you don't have a photo album you could ask for one from Tyboo or Danag, our C-Brat Web Owners. _________________ Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Honey, this REALLY will be my last boat, honest! |
