Winterizing in NJ
jrslost@aol.com
PostPosted: Thu Jan 04, 2024 1:12 am    Post subject: Winterizing in NJ Reply with quote
Need Advise to winterize water system etc on 2005-25’ stock cruiser in NJ. TY
PostPosted: Thu Jan 04, 2024 2:25 pm    Post subject: Reply with quote
The easiest method is to just pump all the water out of your tank, then close your water heater valves, dump a couple gallons of the pink antifreeze (RV antifreeze for potable water systems) into your water thank, and run that through the system by turning on your pump and opening each spigot, one at a time, until you see the pink antifreeze coming out. Then insure your water heater is drained completely. IN the spring flush out with clean water, and open your water heater valves back up, flushing out what little bit of pink antifreeze got into it's lines. Don't forget to add antifreeze to your shower drain and water heater drain box.
Page generation time: 0.0387s (PHP: 37% - SQL: 63%) - SQL queries: 19 - GZIP disabled - Debug on
