Captain Starbucks
Photos: Captain Starbucks
Posted: Mon Feb 26, 2024 4:15 pm Post subject: The OFFICIAL TomCat Permatrim BEFORE AND AFTER thread!! |
I wanted to lower my planing speed as much as possible. I operate almost entirely in the ocean in the PNW and conditions aren't always favorable for using the TomCat's legs. I knew at the end of last year, I was either going for new stern lifting props, or Permatrims, or both. After several conversations with Ken at PropGods, he talked me into trying the Permatrims first, and I'm sure glad I did.
Anyways, last fall prior to storing for winter maintenance, I thought I'd get some baseline data. To be perfectly clear, the conditions before and after weren't identical but I'll try to line out the differences as much as possible (noted in the image below).
I'm a bit suspect of the GPH figure on the With Permatrim side at the 4,000 rpm point. I'll have to double check that next time I'm out.
A few things of note: The boat was 300 lbs or maybe more lighter on the With Permatrim side. Also, the water had a slight ripple on it on the With Permatrim side. Ripple has a great drag reduction factor, ask any floatplane pilot.
![](http://www.c-brats.com/albums/album3453/Permatrim_snip.sized.png) _________________ 2009 C-Dory TomCat 255 Yamaha F150's
2001 Shamrock Mackinaw 270 - Sold 2022
1996 20' Wooldridge Xtra Plus - Sold 2012 |
![](templates/subSilver/images/spacer.gif) |
Joined: 02 Nov 2003 Posts: 20875 City/Region: Pensacola
Posted: Mon Feb 26, 2024 10:36 pm Post subject: |
Thank you and interesting take. I had a 2006, TC 255, with the Suzuki 150s. Stern lifting props (4blade), SS. I also added the Permatrims to attempt lower the planing speed, and cruising speed in semi displacement mode. I don't remember doing as an exhaustive analysis on the RPM/Speed, fuel consumption. (My impression was that the fuel gauge/flow meters were not that consistent--I was pulling data off the turbine type of gasoline flow meters, not the engine computers.
My impression was that the Permatrims threw a bunch of water up, on the sides/at speeds in the 9 to 10 knot range, Almost to the point I considered it possibly dangerous.
I also got lower high end speed, and decreased fuel use at the higher speeds. What makes your fuel/speed somewhat "suspect" (not being disrespectful, but wondering if other factors were in play????). Because most folks who use Permatrims find that the higher end they have a slightly increased drag and slightly raise the fuel consumption--many have found that they cannot achieve the same high end speed at WOT. (My WOT were at 6,000 RPM and very close to what yours are at 5700 RPM, which is exactly where you want to be with the Suzuki (Different gearing and using considerably greater pitch props--my recollection was I was running 21" pitch props. I had two sets one at 19 the other at 21. I rarely got over 2 mpg. An exception was where I ran almost 200 miles at a constant speed "Best efficiency" run. I am sure my boat was heavier than yours, with extra batteries, Honda Generator, full fuel tanks, full water tanks, etc.
So I am interested in if you sustain these numbers over longer distances, and longer periods of time, running two ways over the same course--distance, etc. I understand that GPS will give us numbers without having to use a measured mile--but GPS gives us speed by position and can be different that speed thru the water. This is why I like to use a measured mile, both ways. to get my most accurate mile.
I don't know if you were using the engine computer for "mileage" or an external Lawrence, like I was using. How did you determine you had 18 or 17 gallons of fuel in each tank? That is just to "pat" a number.i??
There are just so many variables.
Again, Thanks _________________ Bob Austin
cmetzenberg
Joined: 04 Jan 2014 Posts: 367 City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
Posted: Wed Feb 28, 2024 11:49 am Post subject: |
I ditched my permatrims on my tomcat. I don't notice much of a difference. I'd be interested in adding a foil wing between the hulls aft to create lift....if there was such a thing off the shelf. _________________ Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
![](https://cdn.shopify.com/s/files/1/0763/4927/t/2/assets/logo.png) |
nwboater
C-Dory Year: 2017
Vessel Name: FastCat
Posted: Wed May 15, 2024 5:08 pm Post subject: |
Cap' Starbucks,
Are the fuel consumption figures in your chart for 2 engines? My Tomcat 255 with Suzuki 150s displays between 1.9 - 2.2 GPH when cruising between 18-21 mph, but I'm thinking the electronic display is reading just 1 motor...What say you -- _________________ Richard Soto
Tomcat 255 "FastCat"
American Tug 34 "Salty"
Selene 47 "Kika"
Willard 40 "Northstar"
Classic Monk cruiser "Annie B" |
Joined: 27 Oct 2012 Posts: 3396 City/Region: SW Michigan
Posted: Wed May 15, 2024 5:21 pm Post subject: |
cmetzenberg wrote: | I ditched my permatrims on my tomcat. I don't notice much of a difference. I'd be interested in adding a foil wing between the hulls aft to create lift....if there was such a thing off the shelf. |
https://foilcat.com/
https://pontoonhydrofoil.com/ |
Posted: Wed May 15, 2024 11:58 pm Post subject: |
A number of us who have owned the T om Cat 255 have talked about increasing performance. (The 2.0 S miles/gallon) is reasonable for both engines, and running at a moderate speed. I averaged 2 S M/Gal in the run from Apalachicola to Pensacola about to 200 niles.
A foil would definitely be a possibility, but there are a number of issues--all of which could be resolved. Especially if a new boat was built with the beefed stress points.
If serious I would consult with Morrelli & Melvin who are located in Newport Beach, Ca. They would be some of the best in the World in predicting the effect and costs. They have developed and converted a number of boat (both sail and power) to more modern propulsion, faster speeds, and better rides. |
Captain Starbucks
Posted: Thu May 16, 2024 9:29 am Post subject: |
nwboater wrote: | Cap' Starbucks,
Are the fuel consumption figures in your chart for 2 engines? My Tomcat 255 with Suzuki 150s displays between 1.9 - 2.2 GPH when cruising between 18-21 mph, but I'm thinking the electronic display is reading just 1 motor...What say you -- |
Yes sir. My fuel burn figures I posted in the charts above reflect fuel burn totals for both engines based on the factory installed 2009 era Yamaha digital gauges. |
